Questions about equivalents of audio/video and digital/analog.
Started by Radium ●August 19, 2007
Jerry Avins <jya@ieee.org> wrote:
>I like your categories. It is possible in concept to >have a signal that is quantized in magnitude and >continuous in time, but (unless we resort to counting >electrons) I don't think it's possible in practice.
If you quantize the magnitude, it is digital. That is by definition. -- Floyd L. Davidson <http://www.apaflo.com/floyd_davidson> Ukpeagvik (Barrow, Alaska) floyd@apaflo.com
On Mon, 20 Aug 2007 04:57:03 -0800, floyd@apaflo.com (Floyd L.
Davidson) wrote:
>Jerry Avins <jya@ieee.org> wrote: >>I like your categories. It is possible in concept to >>have a signal that is quantized in magnitude and >>continuous in time, but (unless we resort to counting >>electrons) I don't think it's possible in practice. > >If you quantize the magnitude, it is digital. That is >by definition.
No it isn't. It isn't digital until you assign numerical values to those quantized levels. Until then it is simply a quantized analogue signal. d -- Pearce Consulting http://www.pearce.uk.com
On 20 Aug., 10:04, nos...@nospam.com (Don Pearce) wrote:
> On Mon, 20 Aug 2007 03:51:54 -0400, Jerry Avins <j...@ieee.org> wrote: > >Don Pearce wrote: > >> On Sun, 19 Aug 2007 23:26:16 -0700, dpl...@radagast.org (Dave Platt) > >> wrote: > > >>> "Digital" and "subject to aliasing" are two different things. > > >>> As I believe the term "digital" is usually meant, it implies a > >>> two-state (on/off) storage representation. It's not just that the > >>> signal amplitude is quantized, but that the quantization uses a > >>> power-of-two representation and storage system of some sort. > > >> My reading of the possible systems goes like this. > > >> analogue - a continuous representation of the original signal > >> sampled - a representation of the signal at discrete time points > >> quantized - a sampled signal, but with the possible levels constrained > >> to a limited set of values > >> digital - a quantized signal, with the individual levels represented > >> by numbers > > >> Aliasing is going to happen as soon as you move beyond the first line > >> of that list. > > >I like your categories. It is possible in concept to have a signal that > >is quantized in magnitude and continuous in time, but (unless we resort > >to counting electrons) I don't think it's possible in practice. > > Yes, I was thinking about that possibility while I was typing, but > since I've never come across such a system I decided it would > complicate things unnecessarily to include it.
Yannis Tsividis once asked in comp.dsp what signal processing practitioners thought of his continuous-time signal processing (filtering) scheme. As I remember, it didn't go down well with the crowd. After reading a paper from him explaining the concept I thought that the scheme had at least educational merit. There are some references on his webpage: http://www.ee.columbia.edu/fac-bios/tsividis/faculty.html Regards, Andor
nospam@nospam.com (Don Pearce) wrote:
>On Mon, 20 Aug 2007 04:57:03 -0800, floyd@apaflo.com (Floyd L. >Davidson) wrote: > >>Jerry Avins <jya@ieee.org> wrote: >>>I like your categories. It is possible in concept to >>>have a signal that is quantized in magnitude and >>>continuous in time, but (unless we resort to counting >>>electrons) I don't think it's possible in practice. >> >>If you quantize the magnitude, it is digital. That is >>by definition. > >No it isn't. It isn't digital until you assign numerical values to >those quantized levels. Until then it is simply a quantized analogue >signal.
If you quantize it, you *have* assigned a value to it, and that value is not from a continuous set, but from a discrete finite set, and therefore it is digital. A "quantized analogue signal" is digital by definition. (Emphasis added) QUANTIZATION: A process in which the continuous range of values of an analog signal is sampled and divided into nonoverlapping (but not necessarily equal) subranges, and *a* *discrete*, *unique* *value* *is* *assigned* to each subrange. http://ntia.its.bldrdoc.gov/fs-1037/ -- Floyd L. Davidson <http://www.apaflo.com/floyd_davidson> Ukpeagvik (Barrow, Alaska) floyd@apaflo.com
