Hi! I'm trying to design a digital preenphasis filter - so far without any luck. The other post about a preemphasis filter design I found couldn't help me. I'm working with LabView, where I read wav files (so my sampling frequency is 44,1kHz) which I want to filter. What I tried so far is to calculate coefficients for a FIR filter in MatLab using frequency sampling. My MatLab code looks like this: %------------------------------------------------ fs=44100; % sampling frequency tau=50; % time constant in microsecondy (50us for Europe, 75us for Amerika) N=30; % filter order %----- desired frequency response -----% fa=0:1:(fs/2); m=10*log10(1+((2*tau*fa/1000).^2)*10^(-5)); % corresponding magnitudes [dB] %----- design FIR filter (linear phase) -----% %fir2 for frequency-sampling b=fir2(N,(fa/(fs/2)),m); %b=b/sum(b); % if not in comments, the beginning looks fine but the rest doesn't [H,f]=freqz(b,1,22051,fs); % compute transfer function %----- plot everything -----% figure(1) plot(f,abs(H),f,m,'r') grid on axis([100 22050 0 35]) legend('designed', 'desired') set(gca, 'XScale', 'log') figure(2) freqz(b,1) %------------------------------------------------ Running this sequency you can see that the desired an designed plots don't fit. Could you point out my mistakes? Thank you a lot! Narax
designing a preemphasis filter
Started by ●October 4, 2007
Reply by ●October 4, 20072007-10-04
Thank you for your answer. The filter you have designed does not fit at all when plotting in MatLab. Increasing the order does in fact improve the fitting. But is an order 100 filter ok? Or can the high order cause any other problems? Another question is: when looking at the plot with both filter everything seems to be fine (N=100). But when looking at freqz() with the coefficients I designed, the total magnitude rise is about 40dB, which is more than double the rise I want to achive. Why is there a difference?
Narax wrote:> Thank you for your answer. > > The filter you have designed does not fit at all when plotting in MatLab. > > Increasing the order does in fact improve the fitting. But is an order 100 > filter ok? Or can the high order cause any other problems? > > Another question is: when looking at the plot with both filter everything > seems to be fine (N=100). But when looking at freqz() with the > coefficients I designed, the total magnitude rise is about 40dB, which is > more than double the rise I want to achive. Why is there a difference?Frequency warping steepens slopes as Fs/2 is approached. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
> > The filter you have designed does not fit at all when plotting in MatLab.I know. I just suggested a simple pre-emphasis filter> Increasing the order does in fact improve the fitting. But is an order 100 > filter ok? Or can the high order cause any other problems?Depends on the application. If delay is an issue, then that would be a problem.
Reply by ●October 5, 20072007-10-05
Narax" wrote:> Hi! > > I'm trying to design a digital preenphasis filter - so far without any > luck. > The other post about a preemphasis filter design I found couldn't help > me.Are you sure you looked hard enough? Robert Orban (yes, that Orban) has posted quite a few examples of digital deemphasis filters on comp.dsp. Here is one of his posts: http://groups.google.ch/group/comp.dsp/msg/4914352a383a2923 Greg Berchin also posted an example in another thread using his excellent FDLS filter design method. Regards, Andor
>Are you sure you looked hard enough?I was sure... not anymore, so shame on me!>Robert Orban (yes, that Orban) >has posted quite a few examples of digital deemphasis filters on >comp.dsp. Here is one of his posts: > >http://groups.google.ch/group/comp.dsp/msg/4914352a383a2923Thank you a lot for that link! I just took a look at it and it seems to be perfect! However, I have still some problems using MatLab so in one plot it is perfect and in the other plot it isn't, but I will ask my way through ;-)
