OFDM - cyclic prefix ?
Started by alex65111 ●November 9, 2007
How in OFDM the size and type of a cyclic prefix gets out? What
characteristics of a liaison channel and a signal influence a prefix?
On Nov 10, 6:13 am, "alex65111" <alex65...@list.ru> wrote:
> How in OFDM the size and type of a cyclic prefix gets out? What > characteristics of a liaison channel and a signal influence a prefix?
The OFDM cyclic prefix duration provides a guard interval between consecutive OFDM symbols. Its purpose is to prevent energy from the previous OFDM being smeared into the current one. It depends how dispersive the communications channel is. The more dispersive the channel, the longer the CP needs to be. The CP also has another purpose. It helps to shape the frequency spectrum of the subcarriers, such that their main lobes are widened and more importantly, the side lobe heights are reduced. This means that any loss of sub-carrier orthogonality at the receiver(will always happen to some extent due to imperfect synchronisation, etc ), has less of an effect of inter-subcarrier interference. I think of it as the classic windowing scenario. Without the CP, the OFDM symbol has been multiplied by a rectangular window in the time domain. This, of course, is a convolution with sinc kernel in the frequency domain. By choosing a CP that rolls off to zero(?) it has the effect of applying a "nicer" window to the OFDM symbol. What is a liaison channel?
>By choosing a CP that rolls off to zero(?) it has the effect of applying >a "nicer" window to the OFDM symbol. >
As the size of a prefix influences on rolls off?
>What is a liaison channel? >
It is simply communication channel.
I don't understand the question. Why don't you try creating an OFDM symbol in matlab and experiment with adding different length prefixes.
In matlab I modelled. I have received results about what you spoke. About
dispersive the communications channel it is clear. And about shape the
frequency spectrum of the subcarriers - I see that dependence is, but I
can not mathematicly describe it.
For example, at me is 12 subcarriers, on everyone subcarrier - PSK4,
everyone has speed of transfer of 50 bod.
What length of a prefix should be if the interval between subcarriers is
100Hz?.
And what length of a prefix should be if the interval between subcarriers
is 60Hz?
How it can be mathematicly calculated?
>>And about shape the >>frequency spectrum of the subcarriers - I see that dependence is, but I >>can not mathematicly describe it.
Well if there is no cyclic prefix, then it is a rectangular window = rect(t). The fourier transform of this is sinc(f). So a single sub- carrier of frequency f1 in the time domain multiplied by a rectangular function, is a pair of impulses at +/- f1 in the frequency domain, convolved with a sinc function.
> What length of a prefix should be if the interval between subcarriers is > 100Hz?. > And what length of a prefix should be if the interval between subcarriers > is 60Hz?
I don't know the answer, but thinking out loud: If the time duration (including cyclic prefix) of the OFDM symbol is T, and assuming a rectangular window, then the main-lobe width of a single sub-carrier in the frequency domain is 1/T. So I suppose the OFDM subcarriers cannot be spaced any closer than 1/T Hz. So presumably it follows that a longer cyclic prefix, allows the sub-carriers to be spaced closer together. But, my understanding is the cyclic prefix is shaped such that it gives something other than a rectangular window to the OFDM symbol. This means a sub-carrier main lobe width is now > 1/T, but the advantage is the side lobes drop off with frequency at a faster rate, and/or the first side lobe is reduced. So in this case the sub- carriers must be spaced > 1/T. Windowing trades off main lobe width vs side lobe height and roll off rate. There are many different windows out there. Maybe there is a particular type that often gets used for OFDM applications? Disclaimer: I'm still learning about OFDM myself :) Cheers Andrew
On Nov 11, 9:21 am, Andrew FPGA <andrew.newsgr...@gmail.com> wrote:
> >>And about shape the > >>frequency spectrum of the subcarriers - I see that dependence is, but I > >>can not mathematicly describe it. > > Well if there is no cyclic prefix, then it is a rectangular window = > rect(t). The fourier transform of this is sinc(f). So a single sub- > carrier of frequency f1 in the time domain multiplied by a rectangular > function, is a pair of impulses at +/- f1 in the frequency domain, > convolved with a sinc function. > > > What length of a prefix should be if the interval between subcarriers is > > 100Hz?. > > And what length of a prefix should be if the interval between subcarriers > > is 60Hz? > > I don't know the answer, but thinking out loud: If the time duration > (including cyclic prefix) of the OFDM symbol is T, and assuming a > rectangular window, then the main-lobe width of a single sub-carrier > in the frequency domain is 1/T. So I suppose the OFDM subcarriers > cannot be spaced any closer than 1/T Hz. So presumably it follows that > a longer cyclic prefix, allows the sub-carriers to be spaced closer > together.
No. T is the length of the OFDM symbol before the cyclic prefix has been added. In general, the cyclic prefix should be at least as long as the delay spread that you expect from your channel. In practice, it must be longer than that to allow for symbol timing uncertainty, etc. -- Oli
> No. T is the length of the OFDM symbol before the cyclic prefix has > been added.
Umm, what part of what I wrote is no? I can define T how I like, and I defined it to include the cyclic prefix. If there is no window applied to the cyclic prefix, then the channel and the maths does not care about the relative size of the original OFDM symbol and cyclic prefix? A rect in the time domain is a sinc in the frequency domain. Where do you think my logic is wrong? But, I suppose that in the receiver the cyclic prefix gets removed before the FFT demodulation. So as far as the FFT is concerned the cyclic prefix was never there, so now the sub-carriers are spaced closer together. Which raises the question, how does a shaped(windowed) cyclic prefix help reduce inter-carrier interference if it gets removed prior to the FFT demod? (I know the cyclic prefix is added to allow for a guard interval, to deal with spread from one OFDM symbol to the next. But I have also read papers describing how the CP is also windowed such that it brings an advantage to the shape of sub-carrier spectrum). Regards Andrew
On Nov 11, 7:21 pm, Andrew FPGA <andrew.newsgr...@gmail.com> wrote:
> > No. T is the length of the OFDM symbol before the cyclic prefix has > > been added. > > Umm, what part of what I wrote is no? I can define T how I like, and I > defined it to include the cyclic prefix. If there is no window applied > to the cyclic prefix, then the channel and the maths does not care > about the relative size of the original OFDM symbol and cyclic prefix? > A rect in the time domain is a sinc in the frequency domain. Where do > you think my logic is wrong?
Whilst you're free to define T any way you like, the maths only works (in the sense of retaining sub-carrier orthogonality) if T is defined as the length excluding the CP.
> > But, I suppose that in the receiver the cyclic prefix gets removed > before the FFT demodulation. So as far as the FFT is concerned the > cyclic prefix was never there, so now the sub-carriers are spaced > closer together. Which raises the question, how does a > shaped(windowed) cyclic prefix help reduce inter-carrier interference > if it gets removed prior to the FFT demod? (I know the cyclic prefix > is added to allow for a guard interval, to deal with spread from one > OFDM symbol to the next. But I have also read papers describing how > the CP is also windowed such that it brings an advantage to the shape > of sub-carrier spectrum).
The shaping of the CP is irrelevant when it comes to eliminating ICI. The standard explanation is along the lines of: The CP effectively converts the linear convolution of the channel into circular convolution over the non-CP section of the OFDM symbol. For a DFT, the convolution theorem states that circular convolution in one domain is equivalent to pointwise multiplication in the other domain. In other words, after the FFT in the receiver, the original data may be recovered simply by multiplying each sub-carrier symbol by a single complex value. There is no interaction between the sub-carriers. -- Oli
L. Cimini in "Analysis and Simulation of a Digital Mobile Channel Using Orthogonal Frequency Division Multiplexing" say "The act of truncating the signal [ofdm symbol] to the interval (0, Ndt) [where N is number of subcarriers, dt is the data bit time interval] imposes a sinx/x frequency response on each subchannel with zeros at multiples of 1/T [where T is defined as T = Ndt]. This spectral shape has large sidelobes, and gives rise to significant interchannel interference in the presence of multi-path." They later go on to say "due to the use of the DFT, each subchannel pssesses a sinx/x spectrum which has fairly large sidelobes, and which may cause problems if the orthogonality of the subcarriers is impaired. The sidelobes can be reduced ... by extending the frame of data in time [i.e cyclic prefix] and by requiring gradual rather than abrupt rolloffs of the transmitted waveform... shaped using a raised cosine" Which makes sense doesn't it? There will always be some loss of orthogonality, so the lower the sidelobes are, the less they will effect other sub-channels. So to me, the CP shaping does have an effect on ICI. Cheers Andrew
