FFT algoritms
Started by Richard Owlett ●November 24, 2007
In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of _The
Scientist and Engineer's Guide to Digital Signal Processing_
Smith says "There are also FFT routines that completely eliminate the
bit reversal sorting."
Could someone point me to a description of one, preferably with BASIC or
FORTRAN sample code.
TIA
"Richard Owlett" schrieb
> In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of > _The Scientist and Engineer's Guide to Digital Signal Processing_ > Smith says "There are also FFT routines that completely eliminate > the bit reversal sorting." > > Could someone point me to a description of one, preferably > with BASIC or FORTRAN sample code. >
Maybe www.nr.com helps. Viewing the book on-line needs a plugin, which I'm too lazy to install right now, so I don't know if the answer is in there. HTH. Martin
Martin Blume wrote:
> "Richard Owlett" schrieb > >>In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of >>_The Scientist and Engineer's Guide to Digital Signal Processing_ >>Smith says "There are also FFT routines that completely eliminate >>the bit reversal sorting." >> >>Could someone point me to a description of one, preferably >>with BASIC or FORTRAN sample code. >> > > Maybe www.nr.com helps. Viewing the book on-line needs a plugin, > which I'm too lazy to install right now, so I don't know if the > answer is in there. > > HTH. > Martin > >
Installation repeatedly fails with a "file corrupt" message. I suspect that Windows version is dependent on using IE. I'll see if local library can get me a hard copy on inter-library loan. Thanks.
> > > > Maybe www.nr.com helps. Viewing the book on-line > > needs a plugin, ... > Installation repeatedly fails with a "file corrupt" message. > I suspect that Windows version is dependent on using IE. > I'll see if local library can get me a hard copy on > inter-library loan. >
You might want to look at the source code first to check whether they have an algorithm that works without bit reversal sorting. Regards Martin PS: My ancient dead-tree version (from 1987) mentions other algorithms (other than bit-reversal) briefly (2 pages), but says that these are used for convolution using the FFT and that not doing the bit-reversal step doesn't save much time.
"Martin Blume" schrieb
> > In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of > > _The Scientist and Engineer's Guide to Digital Signal
Processing_
eliminate
> > the bit reversal sorting." > > > > Could someone point me to a description of one, preferably > > with BASIC or FORTRAN sample code. > >
Another possible site is: http://mathworld.wolfram.com/FastFourierTransform.html (didn't see any mention at first glance of non-bit-reversal stuff, but you might follow the links [*]) Regards Martin [*] beware of the danger mentioned in http://xkcd.com/214/
On Nov 24, 7:14 am, "Martin Blume" <mbl...@socha.net> wrote:
> "Richard Owlett" schrieb> In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of > > _The Scientist and Engineer's Guide to Digital Signal Processing_ > > Smith says "There are also FFT routines that completely eliminate > > the bit reversal sorting."
Why do you need to avoid sorting?
> > Could someone point me to a description of one, preferably > > with BASIC or FORTRAN sample code. > > Maybe www.nr.com helps.
The FFT routine in my copy of Numerical Recipes in Basic uses a common decimation-in-time (presort) in-place FFT algorithm with a recurrence formula for the trig/twiddle factors. If you don't need to do your FFT in place (using the same array for input, output and intermediate data), you could try bit-reversed addressing (perhaps by table look up) instead of bit-reversed sorting. You could even hide the fact that you are doing bit-reversed addressing by using different dimensions of 2d arrays for each layer (essentially hiding each bit of address arithmetic behind a transposition of 2d coordinates). I have source code for a simple DIT in-place FFT in Basic for Chipmunk Basic: http://www.nicholson.com/rhn/basic which is an old-fashioned and fairly generic Basic dialect, if that would be of any value. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
On Nov 24, 10:30 am, "Ron N." <rhnlo...@yahoo.com> wrote:
> On Nov 24, 7:14 am, "Martin Blume" <mbl...@socha.net> wrote: > > > "Richard Owlett" schrieb> In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of > > > _The Scientist and Engineer's Guide to Digital Signal Processing_ > > > Smith says "There are also FFT routines that completely eliminate > > > the bit reversal sorting." > > Why do you need to avoid sorting? > > > > Could someone point me to a description of one, preferably > > > with BASIC or FORTRAN sample code. > > > Maybewww.nr.comhelps. > > The FFT routine in my copy of Numerical Recipes in Basic > uses a common decimation-in-time (presort) in-place FFT > algorithm with a recurrence formula for the trig/twiddle > factors. > > If you don't need to do your FFT in place (using the same > array for input, output and intermediate data), you could try > bit-reversed addressing (perhaps by table look up) instead of > bit-reversed sorting. You could even hide the fact that you are > doing bit-reversed addressing by using different dimensions of > 2d arrays for each layer (essentially hiding each bit of > address arithmetic behind a transposition of 2d coordinates).
Another option for hiding some sorting is to do the FFT by depth-first recursion (setting up the parameters passed can presort the data). This might be useful if multiple levels of caching or local memory are smaller than the data vectors.
> IMHO. YMMV. > -- > rhn A.T nicholson d.0.t C-o-M
Martin Blume wrote:
> "Richard Owlett" schrieb > >>>Maybe www.nr.com helps. Viewing the book on-line >>>needs a plugin, ... >> >>Installation repeatedly fails with a "file corrupt" message. >>I suspect that Windows version is dependent on using IE. >>I'll see if local library can get me a hard copy on >>inter-library loan. >> > > You might want to look at the source code first to check whether > they have an algorithm that works without bit reversal sorting. > > Regards > Martin > > PS: My ancient dead-tree version (from 1987) mentions other > algorithms (other than bit-reversal) briefly (2 pages), but > says that these are used for convolution using the FFT and > that not doing the bit-reversal step doesn't save much time. >
I'm not interested in the computation time but in whether or not I can follow what's going on. Eventually I want to experiment with using square waves instead of sinusoids as my basis functions. I suspect it will be a better model for my situation.
On Nov 24, 11:13 am, Richard Owlett <rowl...@atlascomm.net> wrote:
> Martin Blume wrote: > > "Richard Owlett" schrieb > > >>>Maybewww.nr.comhelps. Viewing the book on-line > >>>needs a plugin, ... > > >>Installation repeatedly fails with a "file corrupt" message. > >>I suspect that Windows version is dependent on using IE. > >>I'll see if local library can get me a hard copy on > >>inter-library loan. > > > You might want to look at the source code first to check whether > > they have an algorithm that works without bit reversal sorting. > > > Regards > > Martin > > > PS: My ancient dead-tree version (from 1987) mentions other > > algorithms (other than bit-reversal) briefly (2 pages), but > > says that these are used for convolution using the FFT and > > that not doing the bit-reversal step doesn't save much time. > > I'm not interested in the computation time but in whether or not I can > follow what's going on. Eventually I want to experiment with using > square waves instead of sinusoids as my basis functions. I suspect it > will be a better model for my situation.
For experimenting with other basis vectors, you probably want to stick with the N^2 DFT algorithm. The N*log(N) FFT algorithm depends on the fact that sinusoidal basic vectors have periodicity, symmetry and factorization properties. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
> > "Richard Owlett" schrieb > I'm not interested in the computation time but in whether or not I can > follow what's going on. Eventually I want to experiment with using > square waves instead of sinusoids as my basis functions. I suspect it > will be a better model for my situation.
For experimenting with other basis vectors, you probably want to stick with the N^2 DFT algorithm. The N*log(N) FFT algorithm depends on the fact that sinusoidal basis vectors have periodicity, symmetry and factorization properties. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
