Martin Blume wrote:> "Martin Blume" schrieb > >>>In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of >>>_The Scientist and Engineer's Guide to Digital Signal > > Processing_ > >>>Smith says "There are also FFT routines that completely > > eliminate > >>>the bit reversal sorting." >>> >>>Could someone point me to a description of one, preferably >>>with BASIC or FORTRAN sample code. >>> > > Another possible site is: > http://mathworld.wolfram.com/FastFourierTransform.html > (didn't see any mention at first glance of non-bit-reversal stuff, > but you might follow the links [*])Links were useful. Lead me to Hartley transform which matches my problem domain better as it has only REAL inputs -- in both senses of word. It is also explained with sines and cosines which I'm more comfortable with than with e. j. theta Google then turned up _An Algorithm for the Fast Hartley Transform_ , by Ronald F. Ullmann at http://sepwww.stanford.edu/oldreports/sep38/38_29_abs.html which includes code in RATFOR. I can read FORTRAN but no C or its variants ;/> > Regards > Martin > > [*] beware of the danger mentioned in http://xkcd.com/214/Including fact that "Perfection" has a 58.8% relevance to fast Hartley Transform ;) see page 2 of http://en.wikipedia.org/w/index.php?title=Special:Search&search=fast+Hartley+Transform
FFT algoritms
Started by ●November 24, 2007
Reply by ●November 24, 20072007-11-24
Ron N. wrote:> On Nov 24, 7:14 am, "Martin Blume" <mbl...@socha.net> wrote: > >>"Richard Owlett" schrieb> In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of >> >>>_The Scientist and Engineer's Guide to Digital Signal Processing_ >>>Smith says "There are also FFT routines that completely eliminate >>>the bit reversal sorting." > > > Why do you need to avoid sorting?Cause confuseth me it doeth ;) If I actually am forced to implement my own FFT (or more likely FHT) it will likely be in Forth. The bit reversal of the address become trivial ( an XOR ).> [snip]
Ron N. wrote:>>>"Richard Owlett" schrieb >> >>I'm not interested in the computation time but in whether or not I can >>follow what's going on. Eventually I want to experiment with using >>square waves instead of sinusoids as my basis functions. I suspect it >>will be a better model for my situation. > > > For experimenting with other basis vectors, you probably > want to stick with the N^2 DFT algorithm. The N*log(N) FFT > algorithm depends on the fact that sinusoidal basis vectors > have periodicity, symmetry and factorization properties. > > IMHO. YMMV. > -- > rhn A.T nicholson d.0.t C-o-MI don't see where square waves lack periodicity and/or symmetry where sine or cosine are used in code.
"Richard Owlett" schrieb> > > > I'm not interested in the computation time but in whether > or not I can follow what's going on. Eventually I want to > experiment with using square waves instead of sinusoids > as my basis functions. >Why didn't you ask for it in the first place? You might want to look at http://mathworld.wolfram.com/WalshFunction.html> > I suspect it will be a better model for my situation. >Describe your sitiuation and somebody more knowledgeable than I might help. Regards Martin
On Nov 24, 1:18 pm, Richard Owlett <rowl...@atlascomm.net> wrote:> Ron N. wrote: > > On Nov 24, 7:14 am, "Martin Blume" <mbl...@socha.net> wrote: > > >>"Richard Owlett" schrieb> In "Chapter 12 - The Fast Fourier Transform / FFT Programs" of > > >>>_The Scientist and Engineer's Guide to Digital Signal Processing_ > >>>Smith says "There are also FFT routines that completely eliminate > >>>the bit reversal sorting." > > > Why do you need to avoid sorting? > > Cause confuseth me it doeth ;) > If I actually am forced to implement my own FFT (or more likely FHT) it > will likely be in Forth. The bit reversal of the address become trivial > ( an XOR ).An XOR does a masked bit invert, not a bit reverse. To reverse the m-bit variable k in Basic : ki = k : rem temporary shift register kr = 0 : rem initialize result variable for i=1 to m kr = kr * 2 : rem shift left if (ki mod 2) = 1 then kr = kr + 1 ki = int(ki / 2) : rem shift right next i rem kr is k bit reversed m bits print k, kr If your Basic doesn't have the mod (modulo) operator, then (x mod y) = x - y * int(x / y) Code optimizations left as an exercise for the student. Chipmunk Basic does have a mod (modulo) operator: http://www.nicholson.com/rhn/basic IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Reply by ●November 25, 20072007-11-25
On Nov 24, 2:13 pm, Richard Owlett <rowl...@atlascomm.net> wrote:> > > PS: My ancient dead-tree version (from 1987) mentions other > > algorithms (other than bit-reversal) briefly (2 pages), but > > says that these are used for convolution using the FFT and > > that not doing the bit-reversal step doesn't save much time. > > I'm not interested in the computation time but in whether or not I can > follow what's going on. Eventually I want to experiment with using > square waves instead of sinusoids as my basis functions. I suspect it > will be a better model for my situation.there are drawings of it in Oppenheim and Schafer (any era of O&S) for the case of N=8. i think i can see a pattern in them but, they do not appear to me to be as efficient, for most instruction sets, as the simple FFT where you have to bit reverse before or after. you need to maintain many more pointers and i'm not completely sure how you manipulate them all for the different FFT passes. for some reason, way back when, when i wrote FFT routines in different contexts, i remember coming to the conclusion that the FFT form that has normal order in and out, was more of a mess than the regular FFT where bit reversing is sometimes needed. it was not needed in the case of fast-convolution, since i had a different iFFT from the FFT where one was decimation-in-time form and the other was decimation-in- frequency. the FFT had normal order in, bit-reversed out, and the iFFT had bit-reversed in, normal out. the transfer function could be pre-bit-reversed in order, so multiplying by it can be done with normal order indexing in memory (which is cheap in native C, some DSPs have built in bit reversing that is as cheap as incrementing in normal order). anyway, i'm still not sure that the normal-in, normal-out FFT is useful for anything. might be. r b-j
Richard Owlett wrote: (snip)> I'm not interested in the computation time but in whether or not I can > follow what's going on. Eventually I want to experiment with using > square waves instead of sinusoids as my basis functions. I suspect it > will be a better model for my situation.Square waves are not orthogonal, which makes the transform harder, but not impossible. Still, you might look at the ICT. It is a transform specifically designed to make the forward transform fast on a machine with no multiply instructions. You might find from there some of the properties of transforms on non-orthogonal basis functions. The ICT assumes that the inverse transform is done on a much faster processor (on earth). The forward case can be done fast on a CDP1802. -- glen
Martin Blume wrote:> "Richard Owlett" schrieb > >>I'm not interested in the computation time but in whether >>or not I can follow what's going on. Eventually I want to >>experiment with using square waves instead of sinusoids >>as my basis functions. >> > > Why didn't you ask for it in the first place?My first goal was to "grok" FFT. *THEN* I would go on to investigating if square waves were appropriate to a particular problem. My prime goal is understanding FFT. A secondary goal is gaining skill in programming a solution. The way my mind works, I have to pose a "problem" to work on. In this case it might be stated as "Why does everybody use sinusoids to analyze the output of a system excited by a two state source (larynx)?"> You might want to look at > http://mathworld.wolfram.com/WalshFunction.html > > >>I suspect it will be a better model for my situation. >> > > Describe your sitiuation and somebody more knowledgeable > than I might help.Well the more they know about the "problem", the more likely I'll be told "don't do that" ;) As I said above, the "problem" is somewhat a straw man. It's purpose is to serve as a framework to explore something I want to learn. Who knows, there may be useful fallout. Consider vulcanization and peneccillin.
glen herrmannsfeldt wrote:> Richard Owlett wrote: > > (snip) > >> I'm not interested in the computation time but in whether or not I can >> follow what's going on. Eventually I want to experiment with using >> square waves instead of sinusoids as my basis functions. I suspect it >> will be a better model for my situation. > > > Square waves are not orthogonal, which makes the transform > harder, but not impossible.Why would they be any less orthogonal than sets of sines and cosines? They should also span the space as well as sines and cosines.> > Still, you might look at the ICT. It is a transform specifically > designed to make the forward transform fast on a machine with no > multiply instructions. You might find from there some of the > properties of transforms on non-orthogonal basis functions. > > The ICT assumes that the inverse transform is done on a much > faster processor (on earth). The forward case can be done > fast on a CDP1802. >By ICT do you mean Inverse Cosine Transform? That was the only relevant Google hit I found. My signal is real but not necessarily even (or odd). I'd be interested in anything that eliminated multiplications.
On Nov 25, 4:30 am, Richard Owlett <rowl...@atlascomm.net> wrote:> glen herrmannsfeldt wrote: > > Richard Owlett wrote: > > > (snip) > > >> I'm not interested in the computation time but in whether or not I can > >> follow what's going on. Eventually I want to experiment with using > >> square waves instead of sinusoids as my basis functions. I suspect it > >> will be a better model for my situation. > > > Square waves are not orthogonal, which makes the transform > > harder, but not impossible. > > Why would they be any less orthogonal than sets of sines and cosines? > They should also span the space as well as sines and cosines.It depends on which waves. Even waves are orthogonal to odd waves (sinusoidal or square), periodic waves are orthogonal to waves at 2^N times the frequency (sinusoidal or square). But square waves are not orthogonal to square waves at three times the frequency (or other odd multiples), whereas sinusoids are. There are Walsh functions which do span a space and are orthogonal, but they are not purely "square" waves, if square means periodic with a constant 50% duty cycle. Since they are not completely constant in periodicity or duty cycle, using them to determine "frequency content", for more common usages of that term, might be problematic. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
