Hi. Would someone please review my MATLAB code and tell my where I'm messing up? I want to simulate a continuous time signal and then apply Parseval's Theorem for the continuous time FT. I'm simply using the rectangular method to approximate integration. I've checked the values of Ex with another program, and the results are close enough. The problem is that the EX does not equal Ex. Is my formula for df wrong? If I substitute dt for df in the last line EX equals Ex, but theoretically that is not the correct formula. The values for tf, dt, and f0 (I've tried several variations) are just test values they are not significant. If anyone could help I'd appreciate it. Yardley tf = 13.2; % t final dt = 1/5021; % continuous time infinitesimal delta t t = dt*(0:((tf/dt)-1)); f0 = 433; % x = sin(2*pi*f0*t); Ex = sum((abs(x).^2)*dt) % area under abs(x).^2 L = length(t); Nfft = 2^nextpow2(5*L); X = fft(x, Nfft); X = X/sqrt(Nfft); % CT FT is being simulated so we need to normalize X(.) % to make it unitary because that is the form assumed % for the CT Parseval equation df = (1/dt)/Nfft; EX = sum((abs(X).^2)*df) % this doesn't work, EX = sum((abs(X).^2)*dt) does
Simulating CTFT in MATLAB and calculating energy with Parseval's Theorem
Started by ●December 22, 2007
