Factoring a filter (s^2) * h into (s*h1) . (s*h2)
Started by Antoine Bruguier ●January 18, 2008
Hello,
This is probably a classic problem, but after much Googling, I can't
come up with the right keywords.
In the following, * is a convolution (conv in Matlab) ^2 means squared
( .^2 in Matlab) and a dot . means multiply (.* in Matlab).
I would like to be able to "factor" a filter h into two filters h1 and
h2 in such a way that for any signal s:
(s^2) * h = (s*h1) . (s*h2)
Any good pointers?
Thanks in advance
I forgot to add that from the math I've done, it seems that if the
length of h is 4 or greater, the solutions does not always exist. I'm
also looking for conditions on h when it's possible, etc...
Antoine Bruguier wrote:
> Hello, > > This is probably a classic problem, but after much Googling, I can't > come up with the right keywords. > > In the following, * is a convolution (conv in Matlab) ^2 means squared > ( .^2 in Matlab) and a dot . means multiply (.* in Matlab). > > I would like to be able to "factor" a filter h into two filters h1 and > h2 in such a way that for any signal s: > > (s^2) * h = (s*h1) . (s*h2) > > Any good pointers? > Thanks in advance
Hi, I think that the right keyword is spectral factorization or in the case of FIR filters you simply find the zeros of the transfer function and construct the subfilters by choosing some of the zeros of the overall filter to the H_1(z) and the remaining to the H_2(z). -- Juha >> h = [1 2 2 2 1]; >> allRoots = roots(h) allRoots = 0 + 1.0000i 0 - 1.0000i -1.0000 -1.0000 >> h1 = poly([allRoots(1); allRoots(2)]) h1 = 1.0000 0 1.0000 >> h2 = poly([allRoots(3); allRoots(4)]) h2 = 1.0000 2.0000 1.0000 >> conv(h1, h2) ans = 1.0000 2.0000 2.0000 2.0000 1.0000
Hi Juha,
Thanks for your reply. However, I am not sure this is what I am
looking for.
The spectral factorization finds h1 and h2 such that for every s:
s*h = s*h1*h2
I was looking for conditions on h such that we can find h1 and h2 such
that for every s:
Let me know if I was confused and did not really understand spectral
factorization.
The problem is underspecified. You can take h1=1 and h2 = h, for example.
On 19 Jan., 08:26, Andor <andor.bari...@gmail.com> wrote:
> On 18 Jan., 19:08, Antoine &#4294967295;Bruguier <tony.brugu...@gmail.com> wrote: > > > Hello, > > > This is probably a classic problem, but after much Googling, I can't > > come up with the right keywords. > > > In the following, * is a convolution (conv in Matlab) ^2 means squared > > ( .^2 in Matlab) and a dot . means multiply (.* in Matlab). > > > I would like to be able to "factor" a filter h into two filters h1 and > > h2 in such a way that for any signal s: > > > (s^2) * h = (s*h1) . (s*h2) > > > Any good pointers? > > Thanks in advance > > The problem is underspecified. You can take h1=1 and h2 = h, for > example.
Scratch that ...
> Hi Juha, > > Thanks for your reply. However, I am not sure this is what I am > looking for. > > The spectral factorization finds h1 and h2 such that for every s: > s*h = s*h1*h2 > > I was looking for conditions on h such that we can find h1 and h2 such > that for every s: > (s^2) * h = (s*h1) . (s*h2) > > Let me know if I was confused and did not really understand spectral > factorization.
Sorry, I misunderstood you question. -- Juha
If the condition is required to hold for *every* input s, then it must hold when the input is the unit pulse function given by p[n] = 1 for n = 0 and p[n] = 0 otherwise. Since p^2 = p, and p is the identity for convolution, it must be that (p^2) * h = p * h = h, and p*h1 = h1, p*h2 = h2. Hence, h = h1.h2, that is, h[n] = h1[n]h2[n] for all n. Since multiplication in the time domain corresponds to convolution inn the frequency domain, perhaps you need to look at spectral convolution H = (H1) * (H2) rather than spectral factorization H = (H1)(H2).
sarwate@YouEyeYouSee.edu wrote:
> On Jan 18, 2:41 pm, Antoine Bruguier <tony.brugu...@gmail.com> wrote: > >> I was looking for conditions on h such that we can find h1 and h2 such >> that for every s: >> (s^2) * h = (s*h1) . (s*h2) > > If the condition is required to hold for *every* input s, then > it must hold when the input is the unit pulse function given > by p[n] = 1 for n = 0 and p[n] = 0 otherwise. Since p^2 = p, > and p is the identity for convolution, it must be that > (p^2) * h = p * h = h, and p*h1 = h1, p*h2 = h2. Hence, > h = h1.h2, that is, > > h[n] = h1[n]h2[n] for all n. > > Since multiplication in the time domain corresponds to convolution > inn the frequency domain, perhaps you need to look at spectral > convolution H = (H1) * (H2) rather than spectral factorization > H = (H1)(H2).
Wrong. Squaring is a non-linear operation and thus your condition does NOT hold. Take this little example: h1 = [1 2 3 4]; h2 = [-1 -2 -3 -4]; s = [0 -0.1 0.2 -0.3 0.4]; h = h1.*h2; conv(s.^2,h) conv(s,h1) .* conv(s,h2) and compare the outputs. Regards, Laurent
On Jan 22, 1:16 am, Laurent Schmalen <lo...@gmx.de> wrote:
> sarw...@YouEyeYouSee.edu wrote: > > On Jan 18, 2:41 pm, Antoine Bruguier <tony.brugu...@gmail.com> wrote: > > >> I was looking for conditions on h such that we can find h1 and h2 such > >> that for every s: > >> (s^2) * h = (s*h1) . (s*h2) > > > If the condition is required to hold for *every* input s, then > > it must hold when the input is the unit pulse function given > > by p[n] = 1 for n = 0 and p[n] = 0 otherwise. Since p^2 = p, > > and p is the identity for convolution, it must be that > > (p^2) * h = p * h = h, and p*h1 = h1, p*h2 = h2. Hence, > > h = h1.h2, that is, > > > h[n] = h1[n]h2[n] for all n. > > > Since multiplication in the time domain corresponds to convolution > > inn the frequency domain, perhaps you need to look at spectral > > convolution H = (H1) * (H2) rather than spectral factorization > > H = (H1)(H2). >
> Wrong. > Squaring is a non-linear operation and thus your condition does NOT > hold. Take this little example: > > h1 = [1 2 3 4]; > h2 = [-1 -2 -3 -4]; > s = [0 -0.1 0.2 -0.3 0.4]; > h = h1.*h2; > conv(s.^2,h) > conv(s,h1) .* conv(s,h2) > > and compare the outputs. > > Regards, > Laurent
The condition h[n] = h1[n]h2[n] for all n is NECESSARY if it is desired that (s^2) * h = (s*h1) . (s*h2) hold for ALL signals s; it is by no means SUFFICIENT. I very much doubt that the decomposition sought by the OP is possible for all h; indeed the OP was looking for conditions on h that would allow for the decomposition that he wanted
