Factoring a filter (s^2) * h into (s*h1) . (s*h2)
Started by Antoine Bruguier January 18, 2008
Hello all,
Thanks for your replies. Indeed, there are some stringent conditions.
The number of equations scales as ~n^2 but the number of unknowns
(size of h1 and h2) scales as ~n.
h1[n]h2[n] = h[n]
h1[n]h2[p] + h1[p]h2[n] = 0 (for n != p)
I was wondering if this problem has been studied before, otherwise,
I'll try to create a solution from scratch.
Going into Fourier does not seem to help.
On Jan 22, 5:02 am, "sarw...@YouEyeYouSee.edu" <dvsarw...@gmail.com>
wrote:
> On Jan 22, 1:16 am, Laurent Schmalen <lo...@gmx.de> wrote: > > > > > sarw...@YouEyeYouSee.edu wrote: > > > On Jan 18, 2:41 pm, Antoine Bruguier <tony.brugu...@gmail.com> wrote: > > > >> I was looking for conditions on h such that we can find h1 and h2 such > > >> that for every s: > > >> (s^2) * h = (s*h1) . (s*h2) > > > > If the condition is required to hold for *every* input s, then > > > it must hold when the input is the unit pulse function given > > > by p[n] = 1 for n = 0 and p[n] = 0 otherwise. Since p^2 = p, > > > and p is the identity for convolution, it must be that > > > (p^2) * h = p * h = h, and p*h1 = h1, p*h2 = h2. Hence, > > > h = h1.h2, that is, > > > > h[n] = h1[n]h2[n] for all n. > > > > Since multiplication in the time domain corresponds to convolution > > > inn the frequency domain, perhaps you need to look at spectral > > > convolution H = (H1) * (H2) rather than spectral factorization > > > H = (H1)(H2). > > > Wrong. > > Squaring is a non-linear operation and thus your condition does NOT > > hold. Take this little example: > > > h1 = [1 2 3 4]; > > h2 = [-1 -2 -3 -4]; > > s = [0 -0.1 0.2 -0.3 0.4]; > > h = h1.*h2; > > conv(s.^2,h) > > conv(s,h1) .* conv(s,h2) > > > and compare the outputs. > > > Regards, > > Laurent > > The condition h[n] = h1[n]h2[n] for all n is NECESSARY > if it is desired that (s^2) * h = (s*h1) . (s*h2) hold for ALL > signals s; it is by no means SUFFICIENT. I very much > doubt that the decomposition sought by the OP is possible > for all h; indeed the OP was looking for conditions on h > that would allow for the decomposition that he wanted
