robert bristow-johnson wrote:>> >>You really didn't understand that? Granted it's concise but >>I'm not sure how else to not state it. > > > okay, so you make me parse it: > > >>>>... you will absolutely not lure me back into saying > > > the follow you will not say:Ah, the intended humor is coming through a little then?> > >>>>that the DFT merely compiles the correlations of an interval of a signal > > > an "interval of a signal" is going to be a finite length segment of a > signal, i presume by this time it has been sampled so that finite length is > a finite number of samples, no? we'll call that number, N.Agreed.> > >>>>with all the sinusoids and cosinusoids that have an integral number of >>>>cycles in the same length interval (up to the Nyquist one) > > > okay, i got that one (i presume that you're using the Nyquist one since that > appears in bin N/2 of the DFT if N is even). but you're not going over the > Nyquist bin.Yep.> > >>>>and that it says nothing whatsoever about anything outside that interval. > > > so you're refuse to say "that it says nothing whatsoever..." or that, if you > would say it, "that it says nothing whatsoever about anything outside that > interval." *that's* a little ambiguous. from the past, i think you believe > that it *does* say something about something outside that interval. no?No. It's totally ambiguous as to what might lie outside that interval.> > if that *is* the case, we have a disagreement whereas i would say that > neither the DFT nor those N samples tell you what is going on outside that > interval. you are welcome to say that it's, say, zero outside that interval > (and then the consequence of that *assumption* is that the DFT is the > sampling of N samples of the DTFT around the unit circle).An assumption I make and work with more than any other, but it is just one of the possible assumptions.> i insist that > it's an assumption that may be reasonable in some contexts, but neither > those N samples nor the DFT of them give you that information. > > >>>> I absolutely refuse to restate my position. :-) > > > let's see where this gets us, Bob. i promise to be nice (i.e. respectful), > but, as you might guess, i take no prisoners regarding the content of the > discussion.I accept your terms. This argument that isn't happening can proceed. Or not. :-) Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
CAUTION! was "What is the advantage on high-sampling rate ?"
Started by ●April 23, 2004
Reply by ●April 29, 20042004-04-29
glen herrmannsfeldt wrote:> > For DFT a cyclic rotation of the input points is a phase change in > the result, but otherwise doesn't affect the result. >It certainly does if that set of points contains a finite impulse response and you convolve that rotation with something else. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●April 30, 20042004-04-30
In article <H6Ujc.7709$lz5.854606@attbi_s53>, glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>The use of the DFT instead of the continuous Fourier transform >implies the assumption that the function is periodic, and so is >its transform.The DFT is merely a transform. Nothing about periodicity needs to be assumed about the input function to do a transform. You can DFT a pile of random numbers if you want. However, if you wish to interpret the DFT results as if the input was periodic, then one should assume the input was periodic for the purposes of that interpretation of the result. That's normally what happens when you assume the result says something about non-windowed frequency content.>If the function is not periodic, then you should not use a DFT.Nonsense. I use DFT's for data compression of non-periodic images for instance. Lot's of other uses... IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
In article c6t6go$ljf$1@blue.rahul.net, Ronald H. Nicholson Jr. at rhn@mauve.rahul.net wrote on 04/30/2004 05:33:> In article <H6Ujc.7709$lz5.854606@attbi_s53>, > glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote: >> The use of the DFT instead of the continuous Fourier transform >> implies the assumption that the function is periodic, and so is >> its transform. > > The DFT is merely a transform. Nothing about periodicity needs to be > assumed about the input function to do a transform.nothing needs be assumed by the *user*. in fact, the user might have additional knowledge that these N samples were yanked out of some other non-periodic sequence. however (anthropomorphizing), the DFT "assumes" that those N numbers are one period of an infinite periodic sequence. the basis functions that you are fitting to the input are all periodic.> You can DFT a pile of random numbers if you want.and that pile of (i.e. a finite set of) random numbers would be periodically extended to infinity in both directions by the DFT. r b-j
In article c6sdf10rdb@enews4.newsguy.com, Bob Cain at arcane@arcanemethods.com wrote on 04/29/2004 22:25:> robert bristow-johnson wrote: >>> >>>>> I absolutely refuse to restate my position. :-) >> >> >> let's see where this gets us, Bob. i promise to be nice (i.e. respectful), >> but, as you might guess, i take no prisoners regarding the content of the >> discussion. > > I accept your terms. This argument that isn't happening can > proceed. Or not. :-)well, i'm preparing for a weekend at a camp in upstate NY (downstate for me). let's not get back to this argument that isn't happening when i get back unless you want to not toss the first volley. (that might be nice, you can put forth a list of reasons that the DFT is not inherently periodic, but if you don't wanna, i'll make my list Sunday night. i plan to google the thread where were 2 years ago (or whenever) to see where there were loose ends.) L8r, r b-j
robert bristow-johnson wrote:>> You can DFT a pile of random numbers if you want. > > > and that pile of (i.e. a finite set of) random numbers would be periodically > extended to infinity in both directions by the DFT. >And this is the crux of our disagreement. You get the original result if you assume that all the sinusoids and cosinusoids involved in the inner products of the DFT (the basis functions) are tone bursts that only last for the duration of the interval. Under that assumption you can perform the DFT integral from negative to positive infinity and the inverse will give back the original signal interval with it extended by zeros in both directions outside the interval. This is how I think about impulse response transforms. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
robert bristow-johnson wrote:> well, i'm preparing for a weekend at a camp in upstate NY (downstate for > me). let's not get back to this argument that isn't happening when i get > back unless you want to not toss the first volley. (that might be nice, you > can put forth a list of reasons that the DFT is not inherently periodic, but > if you don't wanna, i'll make my list Sunday night. i plan to google the > thread where were 2 years ago (or whenever) to see where there were loose > ends.) >I think I've just done part of that in my response to another post of yours in this thread. You once challenged me with the periodicity (or wrap) of convolution by frequency domain multiplication and that stumped me. I now wonder if that isn't a property of the convolution theorem rather than a property of the DFT but haven't a proof of that theorem in front of me to check out its assumptions. In any event, I see that property more as a kind of aliasing problem wherein the length of the container is insufficient to contain the length of the result so it mathematically wraps. If one merely extends the original sequences with zeros and then does the FFT, multiply, IFFT then one has satisfied the constraint that the container be long enough to contain the result and no periodicity is evident. This is the underlying basis of the overlap add/save algorithms for convolving and if you treat them as black boxes mathematically then no periodicity is evident anywhere. I believe that this periodicity assumption is the root cause of considerable confusion among those getting on board all this stuff and should be purged. I look forward to your return. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Bob Cain <arcane@arcanemethods.com> writes:> robert bristow-johnson wrote: > > > >> You can DFT a pile of random numbers if you want. > > and that pile of (i.e. a finite set of) random numbers would be > > periodically > > > extended to infinity in both directions by the DFT. > > > > > And this is the crux of our disagreement. You get the original result > if you assume that all the sinusoids and cosinusoids involved in the > inner products of the DFT (the basis functions) are tone bursts that > only last for the duration of the interval. Under that assumption you > can perform the DFT integral from negative to positive infinity and > the inverse will give back the original signal interval with it > extended by zeros in both directions outside the interval. > > > This is how I think about impulse response transforms.Bob, You're wrong. I don't mean to be disrespectul, and Lord knows I not tactful, but you are flat-out wrong. Here's why. The DFT, BY DEFINITION, produces a *FINITE* set of values as output. These are, BY DEFINITION, frequency-domain output samples. It is an absolute IRREFUTABLE property that discrete-time samples in the frequency REQUIRE a periodic time-domain function. Period. End of argument. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
In article <BCB80384.AD77%rbj@surfglobal.net>, robert bristow-johnson <rbj@surfglobal.net> wrote:>> You can DFT a pile of random numbers if you want. > >and that pile of (i.e. a finite set of) random numbers would be >periodically extended to infinity in both directions by the DFT.DFT's cannot alter your input data, periodic, infinite or not. Only your possibly false assumptions about the meaning of particular DFT results can do that. One can assume the DFT results to be many other things other than orthonormal functions of infinite extent (statistical pattern data for example; a neural-net classifier "knows" nothing about sin/cos functions). IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
In article <xxpu0z1mgfo.fsf@usrts005.corpusers.net>, Randy Yates <randy.yates@sonyericsson.com> wrote:>The DFT, BY DEFINITION, produces a *FINITE* set of values as output. >These are, BY DEFINITION, frequency-domain output samples.Only if you make certain assumptions about the input. You've gone in a complete circle. A DFT is only an operator which munges one finite set of bits into another. IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
