rhn@mauve.rahul.net (Ronald H. Nicholson Jr.) writes:> In article <xxpu0z1mgfo.fsf@usrts005.corpusers.net>, > Randy Yates <randy.yates@sonyericsson.com> wrote: > >The DFT, BY DEFINITION, produces a *FINITE* set of values as output. > >These are, BY DEFINITION, frequency-domain output samples. > > Only if you make certain assumptions about the input. You've gone > in a complete circle.Yeah, and THAT'S only true if you make assumptions about the meaning of the word "Only" and the word "if" and the word "you" and the word "make" and the word "certain" and the word ... This is black and white, or at least as black and white as anything can be. We could all be the dream of some mythical sentient being for all we *really* know. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
CAUTION! was "What is the advantage on high-sampling rate ?"
Started by ●April 23, 2004
Reply by ●April 30, 20042004-04-30
Randy Yates wrote:> > You're wrong. I don't mean to be disrespectul, and Lord knows > I not tactful, but you are flat-out wrong. Here's why. >'Fraid I have the same opinion of your position. There is nothing whatsoever in the DFT definition that speaks to infinity or anything outside the interval including the sinusoidal intervals that are used as the basis. The only time considered in the definition is that within the interval being transformed and no more need be to qualify those sinusoidal sections as a complete and orthogonal basis for band limited functions defined within that interval. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Ronald H. Nicholson Jr. wrote:> > Only if you make certain assumptions about the input. You've gone > in a complete circle.Exactly.> > A DFT is only an operator which munges one finite set of bits into > another.Period. End of story. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●May 1, 20042004-05-01
Bob Cain <arcane@arcanemethods.com> writes:> Randy Yates wrote: > >> You're wrong. I don't mean to be disrespectul, and Lord knows >> I not tactful, but you are flat-out wrong. Here's why. >> > > 'Fraid I have the same opinion of your position. There is nothing > whatsoever in the DFT definition that speaks to infinityAs long as you agree that we have a set of discrete values in frequency spaced evenly apart (i.e., of the form \sum_{k=-\infty}^{+\infty} a[k]delta[f-kF]" it doesn't have to have anything to do with the DFT definition. If you have a set of impulses in frequency, then the corresponding time-domain function is necessarily periodic. Those impulses can come from a DFT, a Fourier series analysis, or your mother's kitchen. periodic time <==> discrete frequency Live it, love it. -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
Ronald H. Nicholson Jr. wrote:> Randy Yates <randy.yates@sonyericsson.com> wrote: > >The DFT, BY DEFINITION, produces a *FINITE* set of values as output. > >These are, BY DEFINITION, frequency-domain output samples. > > Only if you make certain assumptions about the input. You've gone > in a complete circle.Haha, pun intended? > A DFT is only an operator which munges one finite set of bits into> another.That's what I would say also. The DFT is a unitary linear map on a hilbert space: DFT: CC^n -> CC^n (CC: complex nubmers, n dimension of hilbert space) As such it transforms a set of o.n vectors into another set of o.n vectors while keeping the inner product invariant. It has some nice properties: one of them is that is diagonalizes the shift operator - linear algebra version of the FT shifting theorms. There are absolutely no assumptions made on what basis you are acting on, or what physical meaning is attached to that basis. Regards, Andor
Randy Yates wrote:> Bob Cain <arcane@arcanemethods.com> writes: > > >>Randy Yates wrote: >> >> >>>You're wrong. I don't mean to be disrespectul, and Lord knows >>>I not tactful, but you are flat-out wrong. Here's why. >>> >> >>'Fraid I have the same opinion of your position. There is nothing >>whatsoever in the DFT definition that speaks to infinity > > > As long as you agree that we have a set of discrete values in frequency > spaced evenly apart (i.e., of the form \sum_{k=-\infty}^{+\infty} > a[k]delta[f-kF]" it doesn't have to have anything to do with the DFT > definition.And if I don't agree with that? All I see after a DFT is the weights to be applied to set of harmonic functions (sinusoids and cosinusoids) that are defined only in the same interval as that of the set of time domain points. That set is comprised of all those harmonics which have an integral number of cycles within the interval with frequencies up to the Nyquist limit. Nothing in the DFT definition is assumed about their value outside that interval. Infinity only appears if you define those sinusoids and cosinusoids to extend to +/- infinity in which case you will obviously will the periodicity you can't shake but there is nothing in the DFT definition which makes that extension to the infinities explicit. That falls out of your assumption about the basis set. In the use that I almost exclusively have for the DFT, the assumption that the basis functions are zero outside that interval matches intuition and the physical systems I work with much better than extension of them as harmonic functions. The problems you attack with it may be different so your assumptions may yield a better match. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
an2or@mailcircuit.com (Andor) writes:> Ronald H. Nicholson Jr. wrote: >> Randy Yates <randy.yates@sonyericsson.com> wrote: >> >The DFT, BY DEFINITION, produces a *FINITE* set of values as output. >> >These are, BY DEFINITION, frequency-domain output samples. >> >> Only if you make certain assumptions about the input. You've gone >> in a complete circle. > > Haha, pun intended? > > > A DFT is only an operator which munges one finite set of bits into >> another. > > That's what I would say also. The DFT is a unitary linear map on a > hilbert space: > DFT: CC^n -> CC^n > > (CC: complex nubmers, n dimension of hilbert space) > > As such it transforms a set of o.n vectors into another set of o.n > vectors while keeping the inner product invariant. It has some nice > properties: one of them is that is diagonalizes the shift operator - > linear algebra version of the FT shifting theorms. There are > absolutely no assumptions made on what basis you are acting on, or > what physical meaning is attached to that basis.Tell you what - you go ahead and constrain yourselves to thinking of the FFT output as nothing more than the result of a unitary linear operator operating on a set of vectors in a Hilbert space. I much prefer to use it as a tool to operate on real-world data and real-world problems to accomplish real-world goals, and thus to have real-world significance. I just as capable of abstracting the math into meaninglessness as the rest of you - I choose instead to use it as a tool. -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
Bob Cain <arcane@arcanemethods.com> writes:> Randy Yates wrote: > >> Bob Cain <arcane@arcanemethods.com> writes: >> >>>Randy Yates wrote: >>> >>> >>>>You're wrong. I don't mean to be disrespectul, and Lord knows >>>>I not tactful, but you are flat-out wrong. Here's why. >>>> >>> >>>'Fraid I have the same opinion of your position. There is nothing >>> whatsoever in the DFT definition that speaks to infinity >> As long as you agree that we have a set of discrete values in >> frequency >> spaced evenly apart (i.e., of the form \sum_{k=-\infty}^{+\infty} >> a[k]delta[f-kF]" it doesn't have to have anything to do with the DFT >> definition. > > And if I don't agree with that? All I see after a DFT is the weights > to be applied to set of harmonic functions (sinusoids and cosinusoids) > that are defined only in the same interval as that of the set of time > domain points. That set is comprised of all those harmonics which have > an integral number of cycles within the interval with frequencies up > to the Nyquist limit.I see this viewpoint, and agree with its validity.> Nothing in the DFT definition is assumed about their value outside > that interval. Infinity only appears if you define those sinusoids > and cosinusoids to extend to +/- infinity in which case you will > obviously will the periodicity you can't shake but there is nothing in > the DFT definition which makes that extension to the infinities > explicit. That falls out of your assumption about the basis set. > > In the use that I almost exclusively have for the DFT, the assumption > that the basis functions are zero outside that interval matches > intuition and the physical systems I work with much better than > extension of them as harmonic functions. The problems you attack with > it may be different so your assumptions may yield a better match.I guess it depends on the assumptions you make about the meaning of the DFT output, which is equivalent to making assumptions about the basis set. As I stated, IF you consider the output to be a spectrum in the normal Fourier sense, then you get the result I put forth. If you interpret the output differntly, you can certainly get a different result. -- % Randy Yates % "So now it's getting late, %% Fuquay-Varina, NC % and those who hesitate %%% 919-577-9882 % got no one..." %%%% <yates@ieee.org> % 'Waterfall', *Face The Music*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> > I guess it depends on the assumptions you make about the meaning of > the DFT output, which is equivalent to making assumptions about the > basis set.I would only modify that to say that it depends on the assumptions you make about the meaning of the DFT _input_, specifically the basis set. In the problems I work on, FIR functions and their application by convolution to audio recordings, viewing the basis set as harmonics extended to infinity will make repetitive something that actually 'happens' once. Thus I fail to see the usefulness of the infinite, ...periodicperiodic... assumption when working with filters. There is a real difference in the result of convolving a single IR with a signal and convolving an infinite train of them.> As I stated, IF you consider the output to be a spectrum > in the normal Fourier sense, then you get the result I put forth. If > you interpret the output differntly, you can certainly get a different > result.In the end we don't disagree at all, really, and are both correct provisionally. I love arguments that end that way. I doubt that Robert is done with me, however. :-) Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
In article <4qr0fe5c.fsf@ieee.org>, Randy Yates <yates@ieee.org> wrote:>Tell you what - you go ahead and constrain yourselves to thinking of >the FFT output as nothing more than the result of a unitary linear >operator operating on a set of vectors in a Hilbert space. > >I much prefer to use it as a tool to operate on real-world data and >real-world problems to accomplish real-world goals, and thus to have >real-world significance.I do to. But all the real-world data I deal with doesn't have infinite extent (e.g. is much more recent phenomena than stuff periodic since the Big-Bang), and doesn't have an infinite spectra (I doubt my audio system produces any X-ray radiation above background, maybe I need bigger quantum-plated speaker cables? :^). I'm not sure what real-world goals would be accomplished by assuming such. IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
