Negative Group Delay ... again!
Started by Andor March 7, 2008
On Mar 7, 5:18&#4294967295;pm, Andor <andor.bari...@gmail.com> wrote:
> From a recent discussion here: > > > >if i could generate some coefficents that had a 'negative' group delay for > > >a period of time, would you think that 'phase cloning' was new and > > >intersting?? > > > A time machine would be pretty revolutionary, yes. > > > Negative group delay means that the output appears before the input > > arrives. > > Fascinating concept, isn't it? I was curious enough to dig into the > topic for a while and write up what I found out. You can read about it > here: > > http://www.dsprelated.com/showarticle/54.php > > Regards, > Andor
thank you Fig 6 was facinating... Could you reproduce Fig 6 except start at T=0? It would be interesting to see what happens at the very (unpredictable) start of the input signal. I'm going to build one of these and go to Wall Street :-). Too bad stock numbers are not bandlimted :-( Mark
On Mar 8, 2:55 pm, Rune Allnor <all...@tele.ntnu.no> wrote:
> On Mar 8, 3:43 pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote: > > > On Mar 8, 2:01 pm, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > On Mar 8, 2:38 pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote: > > > > > I'm not sure it matters what the technique is? > > > > It does to me. A result derived with a known, well-udnerstood > > > technique has a far greater impact than a unfamiliar, possibly > > > novel technique applied to a tricky question. > > > Perhaps. > > Certainly. If a conclusion depends on using a novel method > to do a standard computation, the first awkward questions > will inevitably concern the soundness of this new method. > It will only strengthen the conclusion if it can be demonstrated > that the conclusion is independent of numerical methods used. > > > > > > > Surely all that > > > > matters is that a discrete-time filter is derived that has the key > > > > properties of its CT counterpart (approximately flat -ve group delay > > > > over a region with approximately flat magnitude response). The fact > > > > that the overall response is roughly the same is merely an aesthetic > > > > bonus. > > > > Wrong. If the claim applies to the CT cirquit, it is the CT > > > cirquit which must be analyzed. > > > Not necessarily. See further down... > > > > > How would you suggest performing the experiment in CT, short of > > > > actually building the circuit? Even circuit analysis tools have to > > > > operate in discrete time. > > > > Derive and analyze the Laplace transform for the cirquit? > > > All analytical, should be easy. > > > Yes, we could analyse via the Laplace domain by putting in a signal > > with a known equation, and examining the output signal's equation. > > No. The LT describes the linear system regardless of > input and output signals. If the LP is invalid, then > the system is nonlinear and thus the concept of group > delay is undefined.
Not sure I understand. It's a given that the continuous-time system is LTI, therefore we can apply the LT. In what way would it be invalid? -- Oli
