Hi all, I've recently begun trying to understand the fundamentals of lossy image compression via transforms such as DCT and Wavelets (CDF9/7). In a paper I was reading it suggested that prior to applying a forward transform that a "reflection image" of the original image be created. This involves flipping the image vertically and horizontally and copy those flipped variants above, below and to the left and right hand-side, ending up with a larger image that is 3xwidth and 3xheight of the original. then applying the forward transform and then the inverse transform leads to a much higher PSNR than when the image itself is forward then inverse transformed. My questions are: 1. What is this method called? as I can't find anything else in the literature I have that comments about this 2. Why does it provide a better result? is this some kind of Gibbs effect on the border areas? I find that a great deal of the nose when only using the original image comes from around the borders. Any help would be greatly appreciated, Rgds, Jerzie
Wavelets and Reflection image question
Started by ●March 25, 2008
