On Apr 23, 2:48�pm, "cpptutor2...@yahoo.com" <cpptutor2...@yahoo.com> wrote:> With reference to all the postings I am sorry I have caused confusion..One way to 'cut through the c..onfusion' is to post an SSCCE. More info here http://sscce.org/ Have one peice of code to generate the tone, and a second to do the transform. -- Andrew T.
Java Audio question - PLEASE HELP
Started by ●April 13, 2008
Reply by ●April 24, 20082008-04-24
Lew wrote:> cpptutor2000@yahoo.com wrote: >> On Apr 22, 11:04 pm, Lew <l...@lewscanon.com> wrote: >> >>>> fs = sample rate in Hz >>>> dT = 1/fs = interval between samples >>>> N = number of samples taken >>>> T = N x dT = total time period >>>> f1 = 1/T = frequency of the first harmonic in Hz >>> So if you accumulated twice as many samples, over twice as long, your >>> fundamental frequency would be halved? That is not sensible. >>> >>> -- >>> Lew >> That is precisely the case. Please check the definitions above. Please >> note that f1 is the first harmonic if I were to calculate an FFT with >> the collected samples. The fundamental frequency is 500.0 Hz, and >> stays that way. > > No, that doesn't make sense. If I recorded a pure 1000 Hz sine wave, that is > the frequency whether I take 44000 samples for one second or 88000 samples > over two seconds. The frequency isn't affected by how long I record it. >The frequency *resolution* is, though. That's what the OP was referring to [rather obliquely]. The OP mistakenly calls this the fundamental frequency. The sampling rate determines the bandwidth, and the maximum freq. which you can capture (Nyquist-Shannon). The overall length (in time, not samples) determines the frequency resolution (Fourier). -- Nigel Wade
Jerry Avins wrote: (snip)> It would help if you used the same terms that the rest of us do. In > particular, it is important to avoid using standard words in > non-standard ways without the sort of glossary you provided here.> *Fundamental* applies not to an FFT, but to the longest-period component > of a periodic waveform. What *you* have called the fundamental is often > referred to as bin width or resolution.It does make some sense in the context of the FFT, though. Since FFT has periodic boundary conditions, the lowest non-zero frequency could be considered the fundamental. Those who apply the FFT to non-periodic signals get what they deserve.> If your signal repeats every 2 ms, then its fundamental is 500 Hz. It > may have harmonics at 1000, 1500, 2000Hz, etc.-- glen
On Apr 24, 1:16 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Jerry Avins wrote: > > (snip)> > snip> It does make some sense in the context of the FFT, though. > Since FFT has periodic boundary conditions, the lowest non-zero > frequency could be considered the fundamental.In the OP's description, 500 Hz is the lowest non-zero frequency :,). And it is the 'fundamental of the signal', as opposed belonging to the set of 'fundamental frequencies of the transform', of which zero is included as a member. Does anyone have a suggestion for a description of this area of vocabulary that is: 1) accessible (free, etc.) 2) complete enough for this level of discussion 3) unambiguous 4) at a suitable level for the OP?> Those who > apply the FFT to non-periodic signals get what they deserve. >Those who have known how to apply the FFT to non-periodic signals have made much good use of it.> -- glenDale B. Dalrymple
Reply by ●April 28, 20082008-04-28
On Apr 24, 4:33�pm, Lew <l...@lewscanon.com> wrote:> Andrew Thompson wrote: > >http://sscce.org/ > > Swee-eet.I thought you (amongst others) might like that URL. It is Dave Minter's mirror of the SSCCE. Thanks Dave! -- Andrew T.
