McBSP broken?
Started by mavrusha May 9, 2008
Hi everyone!
I'm new in CCStudio and I have simple question. How I can know what my
McBSP is not broken?
I use DM642EVM. I wrote transmitter, no device connected. I use
oscilloscope to look at pins signal (ALL OF THEM), there is constant 0
(ground). Program continuously transmit data (by poling). There is no
loopback. Fsynk is ON. Transmitter ON.
I will be happy if I will see some moving on oscillogram!
Thanks!
mavrusha wrote:
> Hi everyone! > I'm new in CCStudio and I have simple question. How I can know what my > McBSP is not broken? > I use DM642EVM. I wrote transmitter, no device connected. I use > oscilloscope to look at pins signal (ALL OF THEM), there is constant 0 > (ground). Program continuously transmit data (by poling). There is no > loopback. Fsynk is ON. Transmitter ON. > I will be happy if I will see some moving on oscillogram! > Thanks! > >
I assume you're probably looking at a header. If that's the case you better double check the schematics and/or Technical Reference Manual to see what needs to be done to get signals routed to the header. As I recall there's a pin on the header that needs to be pulled high to bring signals out to the header. Alternatively, there's probably an audio codec on-board so you could probe the pins on the codec. The McBSP isn't broken -- look harder. Brad
