Green Xenon [Radium] wrote:> Eric Jacobsen wrote: > > >> Duh, I mean 2^1B amplitudes, (2^1B)/2, etc....reversed the >> relationship there... > > > In the '2^1B', does the 'B' stand for the bit-resolution?Sorry, I should've realized the that B stands for billion. My bad.
Modulation scheme with multiple phases and a two amplitudes?
Started by ●May 16, 2008
Reply by ●May 18, 20082008-05-18
Green Xenon [Radium] wrote:> Eric Jacobsen wrote: > > >> You can do it with *one* if you have log2(1B) amplitudes. > > 'One' of what? > >> *Two* if you >> have log2(1B)/2, *four* with log2(1B)/4, amplitudes, etc., etc. > > "Two" and "four" of what?Once again, I apologize for responding without reading properly. The 'one', 'two', and 'four' are the amounts of phases. Sorry for the annoyance cause by the above response.
Eric Jacobsen wrote:> On Sat, 17 May 2008 15:55:02 -0700, "Green Xenon [Radium]" > <glucegen1@excite.com> wrote:>> Let's say I am using QAM and want a baud-rate of only >> 1-symbol-per-second but I want there to be 1-billion-bits-per-symbol. >> How many phases do I need?> > You can do it with one if you have log2(1B) amplitudes. Two if you > have log2(1B)/2, four with log2(1B)/4, amplitudes, etc., etc. With > QAM you can encode information in both the phase and the amplitude.If I have log2(1B) phases, I need only one amplitude. Right?
