Dear Sir.. I'm trying to implement a fft program with TI 320f2812. I'm using Ti FFT library. I can't get the correct amplitude of result. 1. If the input value is small than 100000, the output is "0", Is this right? 2. In my opinion, Question 1 has relation to this question. some sample code use bit shift command(<<16) to input data, Should is I use this command too? and that case, What should I do with the amplitude of fft result. 3. The amplitude of fft result seems to be 1/1000 of expected amplitude. any answer will be appreciated. Thanks.
Scaling problem of TI FFT library
Started by ●May 29, 2008
