On Sun, 01 Jun 2008 19:06:00 -0500, "digintu" <digintu@gmail.com> wrote:>Hello, > >When combining two smaller FFTs to make a larger one, what are th >techniques. Example..I want to combine two 64 pt FFTs into a 128 pt FFT. >have fed the first 64 data samples into the first FFT and the second 6 >into the 2nd FFT. The results are output from the two FFTs into a 12 >array. The problem is that the 128 pt FFT result has the same peaks as th >64 pt FFT. What is the problem here? How do I correct this in order to ge >the same results as the standard 128 pt FFT? > >Thank you >DJHi DJ, Ya' might take a look at: http://www.dsprelated.com/showarticle/63.php Good Luck, [-Rick-]
combining small FFTs to make a larger FFT
Started by ●June 1, 2008
Reply by ●August 16, 20092009-08-16
Reply by ●January 14, 20102010-01-14
>On Jun 1, 8:06 pm, "digintu" <digi...@gmail.com> wrote: >you're missing a step or two. if you're gonna stuff two halves of >your length 128 data into two length 64 FFTs and post-process the >results, you have to put the even-indexed samples in one and the odd- >index samples in another. do two 64-pt FFTs, and post process the >results with 64 butterflies that have coefficients of > > W(k) = exp(j*2*pi*k/N) for 0 <= k < N/2 > >where N is 128. this is called the Decimation-In-Time algorithm. > >if you want to do this in normal order and toss the "first half" in >one FFT and the "last half" in the other FFT, that's the Decimation-In- >Frequency algorithm and instead of post-processing the results, you >*pre*-process what goes in with similar looking butterflies. either >the DIT or DIF can be done in-place where the input is in normal or >bit-reversed order and the output would then naturally end up bit- >reversed or normal, respectively. in fact, the DIT with normal input, >bir-reversed output, can be compared directly to the DIF with bit- >reversed input and normal order output. a butterfly in the final >stage (or "pass") of the DIT simply has its function inverted with the >corresponding butterfly in the first pass of the DIF. (assume the >first DIT alg is a "forward DFT" and the second DIF alg is set for >"inverse DFT". "j" in the first becomes "-j" in the second.) > >r b-jHi Robert bristow-johnson, Can you pleas give me more information about preprocessing by DIT or DIF, I want to implement it in DSP. The code for MATLAB could be great. I need to know what are the steps for preprocessing, and then after FFT how to combine them. Thanks in advance. Afi
Reply by ●March 10, 20142014-03-10
For some reason, no matter how often or where the question is asked, no one ever posts the full solution to this problem, so here it is: ///////////////////////////////////////////////////////////////////////////////////////////////////// function Y = fftx(X) % Y = fftx(X) %Extended fft by combining smaller fft's recursively. %URL: http://www.mathworks.com/company/newsletters/articles/faster-finite-fourier-transforms-matlab.html %Modified to end recursion at max fft size by Don Gateley %Maximum allowed fft size (use whatever is appropriate for you.) max = 512; X = X(:); n = length(X); if(n <= max) %Down to chunks and end of recursion. Use native fft() for chunks or less. Y = fft(X); else % Recursive divide and conquer. w = exp(2 * 1i * pi * (0: n / 2 - 1) / n)'; u = fftx(X(1: 2: n-1)); v = fftx(X(2: 2: n)) .* w; Y = [u + v; u - v]; end end ///////////////////////////////////////////////////////////////////////////////////////////////////// And the inverse: ///////////////////////////////////////////////////////////////////////////////////////////////////// function T = ifftx(X) %ifftx() using fftx() n = size(X, 1); T = fftx(imag(X) + 1i * real(X)); T= imag(T) + 1i * real(T); T = T / n; end /////////////////////////////////////////////////////////////////////////////////////////////////////
For some reason, no matter how often or where the question is asked, no one ever posts the full solution to this problem, so here it is: ///////////////////////////////////////////////////////////////////////////////////////////////////// function Y = fftx(X) % Y = fftx(X) %Extended fft by combining smaller fft's recursively. %URL: http://www.mathworks.com/company/newsletters/articles/faster-finite-fourier-transforms-matlab.html %Modified to end recursion at max fft size by Don Gateley %Maximum allowed fft size (use whatever is appropriate for you.) max = 512; X = X(:); n = length(X); if(n <= max) %Down to chunks and end of recursion. Use native fft() for chunks or less. Y = fft(X); else % Recursive divide and conquer. w = exp(2 * 1i * pi * (0: n / 2 - 1) / n)'; u = fftx(X(1: 2: n-1)); v = fftx(X(2: 2: n)) .* w; Y = [u + v; u - v]; end end ///////////////////////////////////////////////////////////////////////////////////////////////////// And the inverse: ///////////////////////////////////////////////////////////////////////////////////////////////////// function T = ifftx(X) %ifftx() using fftx() n = size(X, 1); T = fftx(imag(X) + 1i * real(X)); T= imag(T) + 1i * real(T); T = T / n; end ///////////////////////////////////////////////////////////////////////////////////////////////////// _____________________________ Posted through www.DSPRelated.com
