I'm going to use that module for detecting range, velocity and angle, for that radar.https://www.innosent.de/fileadmin/media/dokumente/datasheets/180222_Datenblatt_IVQ-3005.pdf
So I have read a lot of radar techniques and I'm going to use the mode FMCW, and the modulated signal will be a sawtooth (chirps).
I have 4 signals I1, Q1, I2, Q2.
I need to confirm my understanding of the signal processing algorithms
I wrote a basic algorithm, hope that's correct
/* FFT length must be a power of 2 */
#define FFT_LENGTH 16
#define M 4 /* must be log2(FFT_LENGTH) */
#define ECHO_SIZE 12
void main()
int i,j,k;
float tempflt,rin,iin,p1,p2;
static float mag[FFT_LENGTH];
static COMPLEX echos[ECHO_SIZE][FFT_LENGTH];
static COMPLEX last_echo[ECHO_SIZE];
/* read in the first echo */
for(i = 0 ; i < ECHO_SIZE ; i++) {
last_echo[i].real = getinput();
last_echo[i].imag = getinput();
// Read in the Second channgel
// Add first channel I/Q to second channel.
for(;;) {
for (j=0; j< FFT_LENGTH; j++){
/* remove stationary targets by subtracting pairs (highpass filter) */
for (k=0; k< ECHO_SIZE; k++){
rin = getinput();
iin = getinput();
echos[k][j].real = rin - last_echo[k].real;
echos[k][j].imag = iin - last_echo[k].imag;
last_echo[k].real = rin;
last_echo[k].imag = iin;
/* do FFTs on each range sample */
for (k=0; k< ECHO_SIZE; k++) {
fft(echos[k],M);
for(j = 0 ; j < FFT_LENGTH ; j++) {
tempflt = echos[k][j].real * echos[k][j].real;
tempflt += echos[k][j].imag * echos[k][j].imag;
mag[j] = tempflt;
/* find the biggest magnitude spectral bin and output */
tempflt = mag[0];
i=0;
for(j = 1 ; j < FFT_LENGTH ; j++) {
if(mag[j] > tempflt) {
tempflt = mag[j];
i=j;
/* interpolate the peak loacation */
p1 = mag[i] - mag[i-1];
p2 = mag[i] - mag[i+1];
sendout((float)i + (p1-p2)/(2*(p1+p2+1e-30)));
