Hello All, I believe a lot of the people on this ng are users of Matlab and heavily into mathematics, so here is my question. I am trying to integrate a cosine function. If I compare the analitical formula result with the numerical integration result using cumsum(), there is a small difference. Is there anything I can do to minimize that difference, ideally make it zero? Unfortunately, using another integration method is not an option in my case. I can come back with more details if required. Thank you, Cirip
cumsum() in Matlab
Started by ●April 8, 2004
Reply by ●April 8, 20042004-04-08
Cirip, Numerical integration (cumsum) cannot guarantee absolute accuracy. There are more accurate schemes (cumtrapz), to enhance the accuracy Increase the sampling rate. Here are two examples dt=1/1000; wt=linspace(0,10,10/dt)'; y=cos(wt); yi1=cumsum(y)*dt ; yi2=cumtrapz(y)*dt; plot([sin(wt)-yi1 sin(wt)-yi2]); legend('cumsum-error','trapez-error') % use interpolation dt2=1/10000; % fine grid wt2=linspace(0,10,10/dt2)'; % prepare grid yI=spline(wt,y,wt2); % interpolate yi3=cumtrapz(yI)*dt2; % integrate on finner grid plot(wt,[sin(wt)-yi1 sin(wt)-yi2],wt2,sin(wt2)-yi3 ); % compare HTH -- izhak "cirip" <cirip@NOT_VALID.com> wrote in message news:wc4dc.15651$JTG1.14466@news04.bloor.is.net.cable.rogers.com...> Hello All, > > I believe a lot of the people on this ng are users of Matlab and heavily > into mathematics, so here is my question. > > I am trying to integrate a cosine function. If I compare the analitical > formula result with the numerical integration result using cumsum(), there > is a small difference. Is there anything I can do to minimize that > difference, ideally make it zero? > > Unfortunately, using another integration method is not an option in mycase.> > I can come back with more details if required. > > Thank you, > Cirip > >
Reply by ●April 9, 20042004-04-09
Thank you Izhak, Cirip "Izhak" <bucher@technion.ac.il> wrote in message news:c52mpq$fc$1@news.iucc.ac.il...> Cirip, > > Numerical integration (cumsum) cannot guarantee absolute accuracy. > There are more accurate schemes (cumtrapz), > to enhance the accuracy Increase the sampling rate. > > Here are two examples > > > dt=1/1000; wt=linspace(0,10,10/dt)'; y=cos(wt); yi1=cumsum(y)*dt ; > yi2=cumtrapz(y)*dt; plot([sin(wt)-yi1 sin(wt)-yi2]); > legend('cumsum-error','trapez-error') > > > % use interpolation > > dt2=1/10000; % fine grid > wt2=linspace(0,10,10/dt2)'; % prepare grid > yI=spline(wt,y,wt2); % interpolate > yi3=cumtrapz(yI)*dt2; % integrate on finner grid > plot(wt,[sin(wt)-yi1 sin(wt)-yi2],wt2,sin(wt2)-yi3 ); % compare > > > HTH > -- > izhak > > "cirip" <cirip@NOT_VALID.com> wrote in message > news:wc4dc.15651$JTG1.14466@news04.bloor.is.net.cable.rogers.com... > > Hello All, > > > > I believe a lot of the people on this ng are users of Matlab and heavily > > into mathematics, so here is my question. > > > > I am trying to integrate a cosine function. If I compare the analitical > > formula result with the numerical integration result using cumsum(),there> > is a small difference. Is there anything I can do to minimize that > > difference, ideally make it zero? > > > > Unfortunately, using another integration method is not an option in my > case. > > > > I can come back with more details if required. > > > > Thank you, > > Cirip > > > > > >
