Frnak McKenney wrote:> So the "range" of the CWT(), the "surface" the CWT describes > above the scale-time plane, is the same as the "range" of the > signal(s), that is, amplitude.That's correct.> But the important thing (to me) is that I'm "pushing things > around" and seeing results that match what my "model" predicts.Right on!> Hope y'all can enjoy it from afar.It's indeed exciting (though something of an acquired taste), thanks for the explanation. See that everyone gets through the weather OK! Martin -- A trick that is used more than once is called a method. --Ron Getoor paraphrasing George Polya and Gabor Szego
Trying to follow the math behind wavelets
Started by ●August 22, 2008
Reply by ●September 7, 20082008-09-07
Martin Eisenberg wrote: ...> [I] See that everyone gets through the weather OK!I hope so! No problem here that I know of. To guard against my canoe blowing around in the storm, I set it right side up and filled it with about half a ton of water. (I needn't have bothered.) The rain added five or six inches of additional water. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> > Me, I'm still trying to understand the rules governing the selection > of an appropriately-sized... �er, -scaled wavelet-screwdriver for > pounding in a given set of signal-nails. �<grin!> > > Frank > --Hello Frank, Have you tried Ingrid Daubechies' book "Ten Lectures on Wavelets." She covers the rules behind wavelets, i.e., their being a complete basis for example. Their construction ect. Clay
Reply by ●September 8, 20082008-09-08
Jerry Avins wrote:> Martin Eisenberg wrote:>> [I] See that everyone gets through the weather OK!What I meant was not "I perceive" but "You take care". Should I have written it differently to convey that? Martin -- Seek simplicity and mistrust it. --Alfred Whitehead
Martin Eisenberg wrote:> Jerry Avins wrote: >> Martin Eisenberg wrote: > >>> [I] See that everyone gets through the weather OK! > > What I meant was not "I perceive" but "You take care". Should I have > written it differently to convey that?No. I jumped to a wrong conclusion. Good writers shape their sentences not merely to convey their intended meaning, but to make it impossible that any other meaning be attached. That's too high a standard for casual -- if heartfelt -- conversation. We need good readers, too. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 8, 20082008-10-08
On Sun, 7 Sep 2008 09:27:02 -0700 (PDT), clay@claysturner.com <clay@claysturner.com> wrote:> Have you tried Ingrid Daubechies' book "Ten Lectures on Wavelets." > > She covers the rules behind wavelets, i.e., their being a complete > basis for example. Their construction ect.Clay, Sorry I didn't reply sooner. I did see a copy of her book at the University of Richmond Library, but I had trouble following more than the basics of what she was doing. Hubbard's "World of Wavelets" is a bit more my speed, I'm afraid. But thanks for the suggestion. Frank -- Little is inevitable in history, and even less in warfare. God may be thought to be on the side with the largest battalions, and quite often it works out in that manner, but wars often turn on an untold number of factors, including strategic and tactical decisions, good or bad leadership, the experience of the soldiery, the availability of resources, success in getting supplies where and when they are needed, the conduct of foreign policy, ideological zeal, willpower, and a measure of good luck. -- John Ferling / Almost a Miracle -- Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney ayut mined spring dawt cahm (y'all)
On the off chance that someone muight be curious, I thought I'd post a sample of a WWV waveform being "decoded" using wavelets. It's a simple pair of BCD digits modulating a 100Hz sine wave (assuming my code is doing what I think it's doing <grin!>) This is, of course, a nice, clean, theoretical signal; add a lot of noise and it looks a lot messier. That part is left as an E.F.S. <grin!> You'll need Scilab 4.1.2 and the Scilab Wavelet Toolbox (SWT) to run the code. Frank ------------------snip here------------------------- // // Scilab WWV and Wavelets Demo // // Requires Scilab Wavelet Toolbox // Tested with WinXX Scilab v4.1.2, SWT v0.1.0-rc6. // // Written by: Frank McKenney, McKenney Associates // Last updated: 08Oct2008 // stacksize(floor(12*1000000));// increase memory size // // Plotting Performance // On my Dell 2.2GHz laptop, plotting more than about 20K points // makes plotting slow (see also: non-interactive) and scaling and // rotating the result equally sluggish. // PlotMaxPoints = 30000; // More than this makes plotting slow // // WindowSize = number of seconds of samples to fetch // WindowOffset is offset into file in seconds WindowSize = 10; // Samples to fetch (seconds) WindowOffset = 38; // offset into file (seconds) WindowPhaseShift = 0.30; // Offset to put ticks on sec. boundary // // Add signals // Fs = 2500; // "Sample" at 2500Hz F0 = [100, 1.0]; // Hz, amp. Set to 0 to eliminate F1 = [200, 1.0]; // Hz, amp. Set to 0 to eliminate // // Per NIST Time and Frequency Services 1394.pdf // // Time Signals: BCD code on 100 Hz subcarrier, 1 pulse/s // // "Bits are transmitted on the 100 Hz subcarrier using amplitude // modulation. A 200 ms pulse (20 cycles of 100 Hz) is used to // represent a 0 bit, and a 500 ms pulse (50 cycles of 100 Hz) is // used to represent a 1 bit. However, tone suppression deletes // the first 30 ms of each pulse. Therefore, 170 ms pulses are // recognized as 0 bits, and 470 ms pulses are recognized as 1 bits. // The leading edge of each pulse can serve as an on time marker, // but due to the tone suppression it actually occurs 30 ms after // the start of the second." // // Implications: // // 1) Fs needs to resolve 100Hz. // 2) Fs needs to let us distinguish between 200/170ms trains of // 100Hz and 500/470ms trains of 100Hz. // // Available Wavelet types, as of v0.1.0-rc6 (The Help file listing // contains some name errors.) // // haar mexh morl cmor cauchy poisson // gaus1-8 cgau1-8 legd1-legd9 // db1-db20 coif1-coif5 sym2-sym20 // dmey vaidyanathan bior1.1-bior6.8 // sinus DOG shan fbsp // beylkin bath4.0-bath4.15 bath6.0-bath6.15 // // Scale choices will change with wavelet type WaveletType = "beylkin"; // [db7 1:60], Scales = 1:60; // 1:12; // 1:30; // // WWV sends BCD digits LSB first BCDBits = [1 1 0 0 1 0 0 1]; // 93 in BCD, 8 bits = 8 seconds //BCDBits = [1 0 1]; // 5 in BCD, 3 bits = 3 seconds //BCDBits = [1]; // Single bit for testing //BCDBits = []; // No BCD signal // HalfSecond100Hz = sin( (F0(1)*2*%pi) * ([0:fix(Fs/2)-1]/Fs) ); HalfSecond100Hz(1:fix( 0.030 * Fs ) ) = 0; // First 30msec silenced Bits = HalfSecond100Hz; HalfSecond100Hz( [1+fix( 0.200 * Fs ):fix(Fs/2)] ) = 0; Bits = [HalfSecond100Hz' , Bits' ]'; // Ugly, but laminates new row Bits = [Bits, zeros(Bits)]; // BCDSignal = Bits((1+BCDBits),:)' ; // Select rows per index and ravel BCDSignal = BCDSignal(:)' ; // result (with transposes). // // Remove every other-than-nth value of s // function z=Decimate(s,n) z = s(1:n:$); endfunction // // DEMO. We're not really reading from a file here //wf = "WWV-Richmond-2007-10-23-c2016-excellent-to-good-113sec-clip.wav"; //[WFcs, WFFs, WFbits] = wavread(wf,'size'); // Get WAV file information //chs = WFcs(1); // Channel count //ns = WFcs(2); // Sample count WFFs = Fs; // Load samples WSzSa = WindowSize * WFFs; // Size (in samples) // Offset in samples WOSa = 0; //WFy = wavread(wf,WSzSa+WOSa); //WFy = WFy(WOSa+1:length(WFy)); // DF = 1; // Reduce data size by Downsampling Factor //y = Decimate(WFy,DF); Fs = WFFs/DF; // Decimate, adjust Fs //WFy = []; //Free up storage y = zeros(1,WindowSize * Fs); // Demo - no signal yet. ny = length(y); x = [1:ny]; // // Add simulated WWV audio, matched to window // BCDsize = size(BCDSignal); // No recursive indexing if (BCDsize(1)) > 0 then; if (BCDsize(2) > length(y)) then; BCDSignal = BCDSignal(1:length(y)); // Too long - truncate elseif (BCDsize(2) < length(y)) then; BCDSignal = [BCDSignal, zeros(1,length(y)-length(BCDSignal))]; end; y = y + BCDSignal; end; // // Possibly amplify signal // //y = y * 3; // // Possibly add reference signal(s) as markers // if (F0(1) > 0) then; yRef = F0(2) * sin( (F0(1) *2*%pi) * ([0:length(y)-1]/Fs) ); y = y + yRef; end; if (F1(1) > 0) then; yRef = F1(2) * sin( (F1(1) *2*%pi) * ([0:length(y)-1]/Fs) ); y = y + yRef; end; // coef=cwt(y, Scales, WaveletType); // // "Downsample" the coefficients to a usable size array // [pts_y,pts_x] = size(coef); // Note order here. PlotDS = floor( (pts_x*pts_y) / PlotMaxPoints ); keepcols = 1:PlotDS:pts_x; DScoef = coef(:,keepcols); // Reduce array size via columns (x) // // Plot CWT coefficients // set("figure_style","new"); clf(); f = gcf(); f.visible = "off"; // Eliminate frustrating redraws f.figure_name = "Wavelet Analysis of WWV Signal"; set(f, "color_map", graycolormap(128)); //15 good // [xxx,c_cols] = size(DScoef); x_time = WindowOffset + PlotDS * (0:c_cols-1)/Fs; // Time in seconds // DSc1 = DScoef / max(DScoef); // Normalize DSc2 = DSc1 .* DSc1; DSc2 = DSc2 / max(DSc2); mesh(x_time, Scales, (DSc1 .* DSc1) ); //surf(x_time, Scales, (DScoef .* DScoef)); //plot3d1(x_time, Scales, (DScoef' .* DScoef')); // Warning: grayplot() looks nice, but takes a long time //grayplot(x_time, Scales, (DScoef .* DScoef)'); // // a=gca(); title = "Wavelet Analysis of WWV Signal"; title = title + sprintf(" Wavelet Type: %s",WaveletType); title = title + sprintf(" Fs: %d Ns: %d", Fs, WindowSize*Fs); a.title.text = title; a.x_label.text="Time (sec)"; a.y_label.text="Scale"; a.z_label.text="CWT()"; // //a.rotation_angles = [6, -104]; // Viewpoint angles: alpha, theta a.rotation_angles = [16, -108]; // Viewpoint angles: alpha, theta // // Draw contents of plot window // f.visible = "on"; // //============================================= -- ...[T]he innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new. -- Niccolo Machiavelli / The Prince -- Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney ayut mined spring dawt cahm (y'all)
Reply by ●October 11, 20082008-10-11
Frnak McKenney wrote:> On the off chance that someone muight be curious, I thought I'd > post a sample of a WWV waveform being "decoded" using wavelets.So you haven't drowned after all. With hindsight, do you see any benefits of wavelets over other approaches to this task? Martin -- Quidquid latine scriptum est, altum videtur.
Reply by ●October 14, 20082008-10-14
Martin, Thanks for the interest. I haven't given up on my research, but other things keep interrupting. On 11 Oct 2008 19:03:50 GMT, Martin Eisenberg <martin.eisenberg@udo.edu> wrote:> Frnak McKenney wrote: > >> On the off chance that someone muight be curious, I thought I'd >> post a sample of a WWV waveform being "decoded" using wavelets. > > So you haven't drowned after all.No, but we haven't had much rain lately, so there's still hope. <grin!>> ... With hindsight, do you see any > benefits of wavelets over other approaches to this task?The "demo" I posted shows me that I _can_ use wavelets to clearly pick WWV's digital time-code information out of an ideal (e.g. Scilab-generated) signal. On the other hand, using the same techniques on parts of a WAV file recorded off a Heathkit MAC-II with an indoor antenna shows me that this data is a lot harder to pick out from a RealWorld(tm) signal. The audible portions of the recording are moderately clear most of the time, so I'm assuming I didn't lose too much of the 100Hz during recording, and I _think_ I can spot the data bits here and there, but they come and go as I work my way through the WAV file. Next step: use wavelets to try reducing the noise. Several of the papers in my collection describe what seems like a reasonable technique: dropping the signal gain at points where there is "wideband" activity, that is, the wavelet "filtering" shows presence simultaneously across a wide range of scales. Hm. And, just for grins (since it only now occurred to me), I think I'll check the 100Hz performance of the recording system's audio support; all the K8N-E book says is "Realtek ALC850", so I may have to dig out my signal generator. Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney ayut mined spring dawt cahm (y'all)
