On Mar 27, 12:32�pm, Rob Gaddi <rga...@technologyhighland.com> wrote:> On Fri, 27 Mar 2009 08:04:43 -0700 (PDT) > > > > rickman <gnu...@gmail.com> wrote: > > I'm sure I'm not the first person to control an oscillator by the > > amount of data in a FIFO, but I haven't found a reference to this > > design which is similar to a PLL. > > > In place of a typical phase detector, I am using the count of samples > > in the FIFO to control the DCO which drives the output clock. �Data is > > clocked into the FIFO using the reference (input) clock. �I have an > > integrator between the data count and the DCO phase step input. �The > > data count is also offset so that it is zero when at the set point. > > > I am having trouble understanding how to model this design. �Is there > > a unique name for this sort of circuit? �At first I was thinking it > > was a frequency locked loop (FLL), but then I realized that the data > > count works the same as a phase detector by integrating the difference > > in frequency of the two signals, it just has a granularity of 1 cycle > > and does not wrap around like typical phase detectors do. �So should I > > be using the same model for this as I would use for a conventional PLL > > using a standard phase detector? > > > I am having trouble getting the circuit to lock in quickly without > > overshoot and hold lock as the frequency shifts. �I believe I need to > > add a proportional element to the feedback loop. �I am also > > considering using different coefficients when the loop is locked and > > when not locked. > > > Am I making this hard and it just needs to be treated like any other > > PLL? > > > Rick > > Sure sounds like it's just a phase detector. �That said, unless every > clock of the input clock is putting a sample into the FIFO you start > giving away gain pretty rapidly. �In a digital feedback loop, > gain=bits=ability to treat things as mathematically perfect rather than > mucking around in non-linear quantization effects.I'm not sure I understand this. Every clock of the input *does* put a value into the FIFO. Every clock of the output removes a sample from the FIFO. One thing that is confusing me is that I want to update the error integrator only on the input clock enable, but the output clock phase accumulator operates on every cycle of the main clock. So a single count in the error value produces multiple counts of offset in the phase of the output. This seems to make the output rate never stabilize completely. I suspect that I need to provide proper low pass filtering which I don't currently use. Rick
FIFO controlled loop, PLL, FLL or something else?
Started by ●March 27, 2009
Reply by ●March 27, 20092009-03-27
On Mar 27, 7:10�pm, rickman <gnu...@gmail.com> wrote:> On Mar 27, 12:32�pm, Rob Gaddi <rga...@technologyhighland.com> wrote: > > > > > On Fri, 27 Mar 2009 08:04:43 -0700 (PDT) > > > rickman <gnu...@gmail.com> wrote: > > > I'm sure I'm not the first person to control an oscillator by the > > > amount of data in a FIFO, but I haven't found a reference to this > > > design which is similar to a PLL. > > > > In place of a typical phase detector, I am using the count of samples > > > in the FIFO to control the DCO which drives the output clock. �Data is > > > clocked into the FIFO using the reference (input) clock. �I have an > > > integrator between the data count and the DCO phase step input. �The > > > data count is also offset so that it is zero when at the set point. > > > > I am having trouble understanding how to model this design. �Is there > > > a unique name for this sort of circuit? �At first I was thinking it > > > was a frequency locked loop (FLL), but then I realized that the data > > > count works the same as a phase detector by integrating the difference > > > in frequency of the two signals, it just has a granularity of 1 cycle > > > and does not wrap around like typical phase detectors do. �So should I > > > be using the same model for this as I would use for a conventional PLL > > > using a standard phase detector? > > > > I am having trouble getting the circuit to lock in quickly without > > > overshoot and hold lock as the frequency shifts. �I believe I need to > > > add a proportional element to the feedback loop. �I am also > > > considering using different coefficients when the loop is locked and > > > when not locked. > > > > Am I making this hard and it just needs to be treated like any other > > > PLL? > > > > Rick > > > Sure sounds like it's just a phase detector. �That said, unless every > > clock of the input clock is putting a sample into the FIFO you start > > giving away gain pretty rapidly. �In a digital feedback loop, > > gain=bits=ability to treat things as mathematically perfect rather than > > mucking around in non-linear quantization effects. > > I'm not sure I understand this. �Every clock of the input *does* put a > value into the FIFO. �Every clock of the output removes a sample from > the FIFO. > > One thing that is confusing me is that I want to update the error > integrator only on the input clock enable, but the output clock phase > accumulator operates on every cycle of the main clock. �So a single > count in the error value produces multiple counts of offset in the > phase of the output. �This seems to make the output rate never > stabilize completely. �I suspect that I need to provide proper low > pass filtering which I don't currently use. > > RickHere's a simulation in Matlab that shows output rate adaptation to keep buffer half full. John nco_fill=1; nco_empty=1; % write rate is 1/3 phinc_fill=1/3; % read rate offset from write rate by 'ppm' ppm=100; phinc_empty=phinc_fill*(1+ppm/1e6); pherr=0; Ki=1/1000; Kp=1/10; acc=0; N=1e5; backlog=0; bv = zeros(N,1);sv=bv;nf=bv;ne=bv;ev=bv; % buffer size is B B=1000; state=0; for k = 1:N if(nco_fill-phinc_fill<=0) % write a sample into buffer when fill nco wraps backlog = backlog + 1; nco_fill = 1-abs(nco_fill-phinc_fill); else nco_fill=nco_fill-phinc_fill; end if(state == 0) % state 0: waiting for half full condition if(backlog > B/2) state = 1; end elseif(state == 1) % state 1: emptying nco_empty=nco_empty-phinc_empty-pherr; if(nco_empty<=0) % read a sample from buffer when empty nco wraps backlog = backlog-1; nco_empty=1-abs(nco_empty-phinc_empty-pherr); end % compute error and apply to PI filter e = (backlog-B/2)/(B/2); acc = Kp*e + acc; lag = Ki*acc; lead = Kp*e; pherr = lag + lead; end bv(k) = backlog; end plot(bv);grid;shg;title('Backlog');
On Fri, 27 Mar 2009 16:03:09 -0700 (PDT), rickman <gnuarm@gmail.com> wrote:>On Mar 27, 1:25�pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> On Fri, 27 Mar 2009 08:19:43 -0700 (PDT), John <sampson...@gmail.com> >> wrote: >> >> >> >> >On Mar 27, 11:04�am, rickman <gnu...@gmail.com> wrote: >> >> I'm sure I'm not the first person to control an oscillator by the >> >> amount of data in a FIFO, but I haven't found a reference to this >> >> design which is similar to a PLL. >> >> >> In place of a typical phase detector, I am using the count of samples >> >> in the FIFO to control the DCO which drives the output clock. �Data is >> >> clocked into the FIFO using the reference (input) clock. �I have an >> >> integrator between the data count and the DCO phase step input. �The >> >> data count is also offset so that it is zero when at the set point. >> >> >> I am having trouble understanding how to model this design. �Is there >> >> a unique name for this sort of circuit? �At first I was thinking it >> >> was a frequency locked loop (FLL), but then I realized that the data >> >> count works the same as a phase detector by integrating the difference >> >> in frequency of the two signals, it just has a granularity of 1 cycle >> >> and does not wrap around like typical phase detectors do. �So should I >> >> be using the same model for this as I would use for a conventional PLL >> >> using a standard phase detector? >> >> >> I am having trouble getting the circuit to lock in quickly without >> >> overshoot and hold lock as the frequency shifts. �I believe I need to >> >> add a proportional element to the feedback loop. �I am also >> >> considering using different coefficients when the loop is locked and >> >> when not locked. >> >> >> Am I making this hard and it just needs to be treated like any other >> >> PLL? >> >> >> Rick >> >> >I call it a "rate-locked loop", but I'm not sure there is an official >> >name. Other keywords include "elastic store" or "elastic buffer". >> >> >You can write loop equations and get response curves. If the buffer >> >length is B, the error is (x - B/2)/(B/2) where x is how much is in >> >the buffer. The feedback is through a standard lead-lag filter, the >> >output of which controls the buffer's empty rate. >> >> >John >> >> Also sometimes called a "delay-locked loop". > >I am pretty sure that this is not a delay locked loop. A DLL uses a >delay in the feedback path to generate an output that has a different >phase than the original. This is often used to compensate for a delay >elsewhere in the clock path. > >In one incarnation of the design of this circuit the error integrator >was enabled by the input clock enable. If there was a phase shift in >the input and output clock enables, it would produce a single count of >difference during part of the cycle, but would be zero again by the >next input clock enable. However, with the phase accumulator (DCO) >operating on each cycle of the main clock, this single count would be >added in producing what amounted to a fractional phase step compared >to the value in the error integrator. The result is that the smallest >adjustments in output frequency would be made by the phasing of the >input and output signals. However, the phase would never be corrected >in the error integrator. > >This is a bit hard to describe in words. I hope it is clear. > >RickThat's also a DLL, and perhaps the more commonly-used meaning of the term in my experience. This FIFO thing is also pretty common but doesn't seem to have a universal name. As John mentioned, they've been referred to as RLLs, "Elastic buffer", and I've heard DLL when the purpose was to match the delay to some other output to which the stream needs to be synchronized. In the satellite world there's also "plesiochronous buffer" (one of my fave names for this). I guess since the jobs that it does can different a universal name is impractical. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Fri, 27 Mar 2009 08:04:43 -0700, rickman wrote:> I'm sure I'm not the first person to control an oscillator by the amount > of data in a FIFO, but I haven't found a reference to this design which > is similar to a PLL. > > In place of a typical phase detector, I am using the count of samples in > the FIFO to control the DCO which drives the output clock. Data is > clocked into the FIFO using the reference (input) clock. I have an > integrator between the data count and the DCO phase step input. The > data count is also offset so that it is zero when at the set point. > > I am having trouble understanding how to model this design. Is there a > unique name for this sort of circuit?I don't believe so, but I'm not good with names.> At first I was thinking it was a > frequency locked loop (FLL), but then I realized that the data count > works the same as a phase detector by integrating the difference in > frequency of the two signals, it just has a granularity of 1 cycle and > does not wrap around like typical phase detectors do. So should I be > using the same model for this as I would use for a conventional PLL > using a standard phase detector?Yes and no. It doesn't wrap, but it does quantize. So you still need to model the offset accumulation process as an integration, but you don't need to model the phase accumulator rollover, and you do need to model quantization one way or another.> I am having trouble getting the circuit to lock in quickly without > overshoot and hold lock as the frequency shifts. I believe I need to > add a proportional element to the feedback loop.You sure do! How well does a double integrator loop with no damping settle, after all?> I am also considering > using different coefficients when the loop is locked and when not > locked.That may be wise.> Am I making this hard and it just needs to be treated like any other > PLL? > > RickI think you're overanalyzing some simple things, and overlooking some complexities. You should be able to _leverage_ your knowledge of PLL theory, but you have to modify it wisely to make it work in this case. -- http://www.wescottdesign.com
On Fri, 27 Mar 2009 16:10:07 -0700, rickman wrote:> > > I'm sure I'm not the first person to control an oscillator by the > > > amount of data in a FIFO, but I haven't found a reference to this > > > design which is similar to a PLL. > > > > In place of a typical phase detector, I am using the count ofsamples> > > in the FIFO to control the DCO which drives the output clock. Datais> > > clocked into the FIFO using the reference (input) clock. I have an > > > integrator between the data count and the DCO phase step input. The > > > data count is also offset so that it is zero when at the set point. > > > > I am having trouble understanding how to model this design. Isthere> > > a unique name for this sort of circuit? At first I was thinking it > > > was a frequency locked loop (FLL), but then I realized that the data > > > count works the same as a phase detector by integrating thedifference> > > in frequency of the two signals, it just has a granularity of 1cycle> > > and does not wrap around like typical phase detectors do. Soshould I> > > be using the same model for this as I would use for a conventionalPLL> > > using a standard phase detector? > > > > I am having trouble getting the circuit to lock in quickly without > > > overshoot and hold lock as the frequency shifts. I believe I needto> > > add a proportional element to the feedback loop. I am also > > > considering using different coefficients when the loop is locked and > > > when not locked. > > > > Am I making this hard and it just needs to be treated like any other > > > PLL? > > > > Rick > > > Sure sounds like it's just a phase detector. That said, unless every > > clock of the input clock is putting a sample into the FIFO you start > > giving away gain pretty rapidly. In a digital feedback loop, > > gain=bits=ability to treat things as mathematically perfect ratherthan> > mucking around in non-linear quantization effects. > > I'm not sure I understand this. Every clock of the input *does* put a > value into the FIFO. Every clock of the output removes a sample from > the FIFO. > > One thing that is confusing me is that I want to update the error > integrator only on the input clock enable, but the output clock phase > accumulator operates on every cycle of the main clock. So a single > count in the error value produces multiple counts of offset in the > phase of the output. This seems to make the output rate never > stabilize completely. I suspect that I need to provide proper low > pass filtering which I don't currently use. > > RickPerhaps you need to crank your integrator gain down? -- http://www.wescottdesign.com
Reply by ●March 28, 20092009-03-28
On Fri, 27 Mar 2009 08:04:43 -0700, rickman wrote:> I'm sure I'm not the first person to control an oscillator by the amount > of data in a FIFO, but I haven't found a reference to this design which > is similar to a PLL. > > In place of a typical phase detector, I am using the count of samples in > the FIFO to control the DCO which drives the output clock. Data is > clocked into the FIFO using the reference (input) clock. I have an > integrator between the data count and the DCO phase step input. The > data count is also offset so that it is zero when at the set point. > > I am having trouble understanding how to model this design. Is there a > unique name for this sort of circuit? At first I was thinking it was a > frequency locked loop (FLL), but then I realized that the data count > works the same as a phase detector by integrating the difference in > frequency of the two signals, it just has a granularity of 1 cycle and > does not wrap around like typical phase detectors do. So should I be > using the same model for this as I would use for a conventional PLL > using a standard phase detector? > > I am having trouble getting the circuit to lock in quickly without > overshoot and hold lock as the frequency shifts. I believe I need to > add a proportional element to the feedback loop. I am also considering > using different coefficients when the loop is locked and when not > locked. > > Am I making this hard and it just needs to be treated like any other > PLL?Hi Rick, I've done this sort of thing in a few real-world designs. The FIFO is a phase / frequency detector when used this way, and the regular PLL theory applies. I break the PFD implementations into a number of types: 1. The "half full" output of the FIFO is used as the phase error signal. This gives bang-bang control, which can result in a chaotic system. These are hard to analyse, but can still be made to give good results. Things like jitter gain will vary with input jitter amplitude. (This doesn't apply to your design, and I won't consider it further.) 2a. The depth output of the FIFO is used to give a (more or less) linear phase error signal. The FIFO will have stops at either end (writes disabled if full and reads disabled if empty) which means that the FIFO also acts as a frequency detector (e.g. if there is a constant difference in the input and output frequencies, the phase error signal will have an average value that is non-zero). Note that the frequency detector doesn't work in a linear way: it is either +max, -max, or off (and the FIFO is operating as a phase detector with a linear output). 2b. Like 2a, but without the stops. This disables the frequency detector action of the FIFO. You will need some other sort of frequency detector to enable the loop to lock. This can be handy if you want to avoid windup.> So should I be > using the same model for this as I would use for a conventional PLL > using a standard phase detector?Yes. For both 2a and 2b, you can calculate the equivalent phase detector gain in terms of output units per radian of phase error. Analog phase detectors have a gain usually measured in volt / radian or amp / radian (for charge pump types). If you wish, you can convert units to volts to enable you to plug your design into old-fashioned PLL design equations.> I am having trouble getting the circuit to lock in quickly without > overshoot and hold lock as the frequency shifts. I believe I need to > add a proportional element to the feedback loop.Yes, in a Type II system you *need* a zero (from the proportional element) to position the closed loop poles in a good location. (BTW, the Type II system has two (open loop) integrators: one is the integrator in your loop filter, the other is the DCO.)> I am also considering > using different coefficients when the loop is locked and when not > locked.When used as a frequency detector, the FIFO depth output will be stuck at +max or -max as long as the frequency difference is present. You can vary the relative frequency detector / phase detector gain by varying the depth of your FIFO. A deeper FIFO means that +max and -max will be larger, and they will slew your integrator faster (meaning lock time will be lower). It is also possible to go the other way and reduce the effective frequency detector "gain" by clipping the PFD output to smaller limits. When locked, the PFD output only needs to be linear over a limited range, given by the amount of jitter you need to absorb outside the loop bandwidth. This is typically small (perhaps a few cycles?). Clipping the PFD output so that it can't go outside this range can help to reduce windup effects and improve the overshoot during initial frequency acquisition, at the cost of increased lock time. Regards, Allan
On Mar 27, 10:34 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> On Fri, 27 Mar 2009 16:03:09 -0700 (PDT), rickman <gnu...@gmail.com> > wrote: > > >On Mar 27, 1:25 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > > >> Also sometimes called a "delay-locked loop". > > >I am pretty sure that this is not a delay locked loop. A DLL uses a > >delay in the feedback path to generate an output that has a different > >phase than the original. This is often used to compensate for a delay > >elsewhere in the clock path. > > >In one incarnation of the design of this circuit the error integrator > >was enabled by the input clock enable. If there was a phase shift in > >the input and output clock enables, it would produce a single count of > >difference during part of the cycle, but would be zero again by the > >next input clock enable. However, with the phase accumulator (DCO) > >operating on each cycle of the main clock, this single count would be > >added in producing what amounted to a fractional phase step compared > >to the value in the error integrator. The result is that the smallest > >adjustments in output frequency would be made by the phasing of the > >input and output signals. However, the phase would never be corrected > >in the error integrator. > > >This is a bit hard to describe in words. I hope it is clear. > > >Rick > > That's also a DLL, and perhaps the more commonly-used meaning of the > term in my experience.Yeah, I guess people use whatever term they want often and that makes it hard to communicate about these things. I am pretty sure that the "correct" definition of a Delay Locked Loop is as I described above. But if there is no "official" group to decide these things, there really is no correct definition.> This FIFO thing is also pretty common but doesn't seem to have a > universal name. As John mentioned, they've been referred to as RLLs, > "Elastic buffer", and I've heard DLL when the purpose was to match the > delay to some other output to which the stream needs to be > synchronized. In the satellite world there's also "plesiochronous > buffer" (one of my fave names for this).In my case the use is two fold. I am receiving a bit stream and I need to interleave other data with it at a odd ratio (31:1, 15:1, etc). The interleave ratio also determines a delay in the other bit stream which must be compensated for in the first bit stream with a fixed quantity delay. Then as the first bit stream speeds or slows, the second bit stream clock rate is adjusted to match. The second bit rate is just a simple ratio to the first, so that would not require a PLL. But the output stream is now 32/31 times the bit rate of the first input. This is what the PLL is for. At the other end a similar circuit de-interleaves the two bit streams and a PLL generates the output clock. A similar FIFO adds a delay at this end and the FIFO data count is again used as the phase detector.> I guess since the jobs that it does can different a universal name is > impractical.I would like to think that the name would be based on how the circuit works, not so much on what it is used for. A FIFO is always called a FIFO (or a queue) regardless of how it is being used. Oh, well. The main thing is to get it to work. Rick
