The 'phasing method' of single sideband demodulation
Started by Rick Lyons August 8, 2012
On Thursday, August 9, 2012 9:55:36 PM UTC-4, Robert Adams wrote:
> If from birth we all listened exclusively to frequency-shifted voices, do you think we would adapt to the non-harmonic harmonics and think that non-shifted voices sounded bizarre? > > > > Bob
I'm sure we could adapt, but I believe we would like harmonious sounds better. Music theory covers a lot of this. This is like wine tasting - do some wines inherently taste good or is it an acquired taste? I find that so called quality wines taste like crap to me. So I'm glad I didn't make that adaptation as it saves me a lot of money ;-) Listeners of music today accept and seem to desire a lot more dissonance than in music from several centuries ago, which from an evolutionary viewpoint suggests this is all adaptation. But as Glen stated many naturally occuring sounds are harmonious in nature. Clay
On Thursday, August 9, 2012 11:10:20 AM UTC-4, Vladimir Vassilevsky wrote:
> 2. When comparing SSB or DSB performance to FM or AM, it is often overlooked > > that the transmit power amplifier for SSB/DSB has to be linear, whereas > > FM/AM amplifiers operate in efficient class C or D or E mode. So, if > > performance is compared for the same power consumption of the transmitter > > (and this is what matters), the advantages of SSB/DSB are not so obvious if > > any at all. >
Generally linear modulations require linear amplifiers while phase modulations do not. Any power efficiency comparison between linear and constant envelope modulations should, as you rightly pointed out, include not only the efficiency of the signaling method but also the efficiency of the PA. FM and PM have an edge here because Class B and C amplifiers are practical. Class D and E are less common in many RF applications because the filter is more expensive. That being said, comparing power efficiency of SSB to AM without consideration of the PA is practical in many cases. For example lower power/lower cost equipment (amateur radio, CB) generally use Class AB linear amplifiers, so PA efficiency is fixed whether operating in SSB or AM mode. For this class of equipment it's fair to say that SSB operates at more than twice the power efficiency of AM.
<lito844@gmail.com> wrote in message
news:86197064-e87f-436e-8987-67871388e64b@googlegroups.com...
>> 2. When comparing SSB or DSB performance to FM or AM, it is often >> overlooked >> that the transmit power amplifier for SSB/DSB has to be linear, whereas >> FM/AM amplifiers operate in efficient class C or D or E mode. So, if >> performance is compared for the same power consumption of the transmitter >> (and this is what matters), the advantages of SSB/DSB are not so obvious >> if >> any at all.
>Generally linear modulations require linear amplifiers while phase >modulations do not.
This statement is both wrong and irrelevant :-)
> Any power efficiency comparison between linear and constant envelope > modulations should, as you rightly pointed out, include not > only the > efficiency of the signaling method but also the efficiency of the PA. FM > and PM have an edge here because Class B and C > amplifiers are practical. > Class D and E are less common in many RF applications because the filter > is more expensive.
Huh? Refer to any book on transmitter design.
> That being said, comparing power efficiency of SSB to AM without > consideration of the PA is practical in many cases. > For example lower power/lower cost equipment (amateur radio, CB) generally > use Class AB linear amplifiers, so PA efficiency is >fixed whether > operating in SSB or AM mode. For this class of equipment it's fair to say > that SSB operates at more than twice the >power efficiency of AM.
Amplification of a modulated signal is the least efficient way of power amplification. Classic AM is performed by modulating power supply of the transmitter output stage; this could be up to 100% efficient. It would be good to generate complex signals like SSB as a combination of AM and PM, i.e. in polar coordinate system. The only problem with that is insufficient accuracy of practical modulators. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
On Saturday, August 11, 2012 3:46:37 PM UTC-4, Vladimir Vassilevsky wrote:
> Mark wrote in message > > >Generally linear modulations require linear amplifiers while phase > >modulations do not. > > This statement is both wrong and irrelevant :-)
That it is distinct from PA class of operation does not diminish its relevance. The statement is relevant in that a PA can be, and often is operated in compression and therefore at a higher efficiency when transmitting a constant envelope signal. This is not true for linear modulation. The statement, therefore, could only be wrong if this were not the case. Further, its relevance is supported by the torrent of patents issued in the 90s for inventions aimed at improving the efficiency-linearity tradeoff for linear modulation. Some key examples follow. US5880633 claims a feedback linearization circuit for eliminating distortion due to operating a PA close to saturation for the purpose of increasing power efficiency. Read the background section for a succinct statement of issues and tradeoffs relating efficiency, modulation type and their relevance to the global personal communications market. US7164893 claims a supply modulation technique specifically designed to improve efficiency of linear amplifiers for use with linear modulation. US6236837 claims a predistortion method for compensating nonlinearities in an RF PA in order to reduce spectral growth of linear modulation. US5638403 claims a peak to average power ratio reduction method for improving efficiency of a linear RF PA by allowing it to operate near but not in compression for linear modulation.
> > Class D and E are less common in many RF applications because the filter > > is more expensive. > > Huh? Refer to any book on transmitter design.
Hard to see why this statement would be challenged. Seemingly such a challenge could only be valid if Class D and E amplifiers were as common in all RF applications as Class AB or if their filter requirements were looser. But, on both accounts, they are not.
> Amplification of a modulated signal is the least efficient way of power > amplification. Classic AM is performed by modulating power supply of the > transmitter output stage; this could be up to 100% efficient.
This is only one type of amplifier design, albeit a more efficient one. Supply modulation is hardly the rule especially in lower power and lower cost designs. See for example the RF PA designs in the ARRL Handbook for Radio Communications. While the PA operates at a higher efficiency, supply modulating systems often utilize lower efficiency Class AB stages to amplify the modulation to a level sufficient to drive the final stage. So although in theory the final stage can operate at close to 100% efficiency, in practice the overall system does not.
> It would be good to generate complex signals like SSB as a combination of AM > and PM, i.e. in polar coordinate system.
Yes, such a method is a beautiful dream.
On Thu, 9 Aug 2012 10:10:20 -0500, "Vladimir Vassilevsky"
<nospam@nowhere.com> wrote:
> >"Rick Lyons" <R.Lyons@_BOGUS_ieee.org> wrote in message >news:hbo528d30hi5hi3ffs90c3htqbv4fr6dce@4ax.com... >> >> Hi guys, >> Some weeks ago I posted a message asking for help >> in understanding the 'phasing method' of single >> sideband (SSB) demodulation. >> >> You guys helped me out, and I learned so much that >> I wrote a blog on that SSB demodulation method. >> In case anyone's interested, the blog is at: >> >> http://www.dsprelated.com/showarticle/176.php > >1. When communication engineers sketch out an audio spectrum, they represent >it as trapezium with the fall from low to high frequencies. This is more >like the audio spectrum looks in reality, and this convention makes real >easy to see if a sideband signal is inverted in frequency or not. The author >draws spectrums vise versa. > >2. When comparing SSB or DSB performance to FM or AM, it is often overlooked >that the transmit power amplifier for SSB/DSB has to be linear, whereas >FM/AM amplifiers operate in efficient class C or D or E mode. So, if >performance is compared for the same power consumption of the transmitter >(and this is what matters), the advantages of SSB/DSB are not so obvious if >any at all. >
This elderly, slow witted student is slowly beginning to understand the subject and then you say "FM/AM amplifiers operate in efficient class C or D or E mode". Tell me that was a simple miss speak and I can get back to the struggle! I am learning and enjoying the process but I doubt will ever be more than a student here. Thanks to all. John, de W8CCW
>3. DSB demodulator requires perfect carrier recovery in frequency and phase. >A practical DSB demodulator must include PLL for carrier recovery. Costas >loop structure is suitable for that purpose. > >Vladimir Vassilevsky >DSP and Mixed Signal Consultant >www.abvolt.com > > >
John Ferrell W8CCW
On 12.8.12 11:00 , John Ferrell wrote:
> >> 2. When comparing SSB or DSB performance to FM or AM, it is often overlooked >> that the transmit power amplifier for SSB/DSB has to be linear, whereas >> FM/AM amplifiers operate in efficient class C or D or E mode. So, if >> performance is compared for the same power consumption of the transmitter >> (and this is what matters), the advantages of SSB/DSB are not so obvious if >> any at all. >> > This elderly, slow witted student is slowly beginning to understand > the subject and then you say "FM/AM amplifiers operate in efficient > class C or D or E mode". Tell me that was a simple miss speak and I > can get back to the struggle! > > I am learning and enjoying the process but I doubt will ever be more > than a student here. Thanks to all. > > John, de W8CCW
It is possible to use a Class C (or higher) amplifier for conventional AM, but the power of the amplifier has to be adjusted along with the modulating waveform. There are two possibilites here: 1. Adjust the excitation or operating point of the amplifier so that the output follows the desired envelope, 2. Adjust the supply feed so that the output follows the desired envelope. The case 1 was known in the tube era as grid modulation. Both control grid and screen grid modulation were used. Here the modulation comes at the price that the efficiency of the amplifier is about the same as the efficiency of a linear amplifier with the same PEP. The case 2 was known in the tube era as anode (or anode-screen) modulation. Here the carrier efficiency at PEP is the classic Class C level, but the price to be paid is the audio power needed from the modulator, half of the RF stage input power. To have a fair comparison, the modulator power must be calculated into the total efficiency of the transmitter. Remember that the modulator must run in Class B or AB, with the modest efficiency. Transistor power amplifiers often need an adjustment of excitation in combination with the supply voltage modualtion, so pretty often two of the last stages of the transmitter get modulated. --- FM and PM (which are essentially the same thing) are different beasts, as the output envelope is constant. These modulation methods are not spectrally efficient, so their use is not a good idea on crowded frequency bands. -- Tauno Voipio, OH2UG
"Tauno Voipio" <tauno.voipio@notused.fi.invalid> wrote in message
news:k0932n$6ic$1@dont-email.me...
> On 12.8.12 11:00 , John Ferrell wrote: >> > It is possible to use a Class C (or higher) amplifier for conventional > AM, but the power of the amplifier has to be adjusted along with the > modulating waveform. There are two possibilites here: > > 1. Adjust the excitation or operating point of the amplifier so that > the output follows the desired envelope, > > 2. Adjust the supply feed so that the output follows the desired > envelope. > > The case 1 was known in the tube era as grid modulation. Both control > grid and screen grid modulation were used. Here the modulation comes > at the price that the efficiency of the amplifier is about the same > as the efficiency of a linear amplifier with the same PEP. > > The case 2 was known in the tube era as anode (or anode-screen) > modulation. Here the carrier efficiency at PEP is the classic Class > C level, but the price to be paid is the audio power needed from > the modulator, half of the RF stage input power.
There are double- and tripple- anode modulations, where they regulate grid bias altogether with supply voltage on the output and driver stages. This improves linearity and efficiency, and this is substantial at power levels typical for broadcasting.
> To have a fair > comparison, the modulator power must be calculated into the total > efficiency of the transmitter. Remember that the modulator must > run in Class B or AB, with the modest efficiency.
For that matter, modulator could operate in Class D. The elegant solution is auto anode modulation: anode surcuit of the output stage is loaded on low frequency choke, grid bias is modulated by audio signal.
> Transistor power amplifiers often need an adjustment of excitation > in combination with the supply voltage modualtion, so pretty often > two of the last stages of the transmitter get modulated.
That is done of necessity. Transistors have high reaction of the output circuit to the input circuit altogether with nonlinearity; other methods will result in distortions, low efficiency and underutilization of devices. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
On Sun, 12 Aug 2012 23:18:30 +0300, Tauno Voipio
<tauno.voipio@notused.fi.invalid> wrote:
>On 12.8.12 11:00 , John Ferrell wrote: >> >>> 2. When comparing SSB or DSB performance to FM or AM, it is often overlooked >>> that the transmit power amplifier for SSB/DSB has to be linear, whereas >>> FM/AM amplifiers operate in efficient class C or D or E mode. So, if >>> performance is compared for the same power consumption of the transmitter >>> (and this is what matters), the advantages of SSB/DSB are not so obvious if >>> any at all. >>> >> This elderly, slow witted student is slowly beginning to understand >> the subject and then you say "FM/AM amplifiers operate in efficient >> class C or D or E mode". Tell me that was a simple miss speak and I >> can get back to the struggle! >> >> I am learning and enjoying the process but I doubt will ever be more >> than a student here. Thanks to all. >> >> John, de W8CCW > >It is possible to use a Class C (or higher) amplifier for conventional >AM, but the power of the amplifier has to be adjusted along with the >modulating waveform. There are two possibilites here: > >1. Adjust the excitation or operating point of the amplifier so that > the output follows the desired envelope, > >2. Adjust the supply feed so that the output follows the desired > envelope. > >The case 1 was known in the tube era as grid modulation. Both control >grid and screen grid modulation were used. Here the modulation comes >at the price that the efficiency of the amplifier is about the same >as the efficiency of a linear amplifier with the same PEP. > >The case 2 was known in the tube era as anode (or anode-screen) >modulation. Here the carrier efficiency at PEP is the classic Class >C level, but the price to be paid is the audio power needed from >the modulator, half of the RF stage input power. To have a fair >comparison, the modulator power must be calculated into the total >efficiency of the transmitter. Remember that the modulator must >run in Class B or AB, with the modest efficiency. > >Transistor power amplifiers often need an adjustment of excitation >in combination with the supply voltage modualtion, so pretty often >two of the last stages of the transmitter get modulated. > >--- > >FM and PM (which are essentially the same thing) are different beasts, >as the output envelope is constant. These modulation methods are not >spectrally efficient, so their use is not a good idea on crowded >frequency bands.
Perhaps it is a matter of perspective. From my point of view you can modulate a Class C amplifier to produce an Amplitude Modulation Output in several ways. Further amplification of the AM output requires a linear amplifier. I apologize if I am coming across as an Anal Troll, but you folks are normally very concise with your Math. If I am in error, please explain. I make many mistakes every day. I will not take offense from those who offer to teach me... John, W8CCW. John Ferrell W8CCW
On Mon, 13 Aug 2012 13:07:03 -0400, John Ferrell wrote:
> On Sun, 12 Aug 2012 23:18:30 +0300, Tauno Voipio > <tauno.voipio@notused.fi.invalid> wrote: > >>On 12.8.12 11:00 , John Ferrell wrote: >>> >>>> 2. When comparing SSB or DSB performance to FM or AM, it is often >>>> overlooked that the transmit power amplifier for SSB/DSB has to be >>>> linear, whereas FM/AM amplifiers operate in efficient class C or D or >>>> E mode. So, if performance is compared for the same power consumption >>>> of the transmitter (and this is what matters), the advantages of >>>> SSB/DSB are not so obvious if any at all. >>>> >>> This elderly, slow witted student is slowly beginning to understand >>> the subject and then you say "FM/AM amplifiers operate in efficient >>> class C or D or E mode". Tell me that was a simple miss speak and I >>> can get back to the struggle! >>> >>> I am learning and enjoying the process but I doubt will ever be more >>> than a student here. Thanks to all. >>> >>> John, de W8CCW >> >>It is possible to use a Class C (or higher) amplifier for conventional >>AM, but the power of the amplifier has to be adjusted along with the >>modulating waveform. There are two possibilites here: >> >>1. Adjust the excitation or operating point of the amplifier so that >> the output follows the desired envelope, >> >>2. Adjust the supply feed so that the output follows the desired >> envelope. >> >>The case 1 was known in the tube era as grid modulation. Both control >>grid and screen grid modulation were used. Here the modulation comes at >>the price that the efficiency of the amplifier is about the same as the >>efficiency of a linear amplifier with the same PEP. >> >>The case 2 was known in the tube era as anode (or anode-screen) >>modulation. Here the carrier efficiency at PEP is the classic Class C >>level, but the price to be paid is the audio power needed from the >>modulator, half of the RF stage input power. To have a fair comparison, >>the modulator power must be calculated into the total efficiency of the >>transmitter. Remember that the modulator must run in Class B or AB, with >>the modest efficiency. >> >>Transistor power amplifiers often need an adjustment of excitation in >>combination with the supply voltage modualtion, so pretty often two of >>the last stages of the transmitter get modulated. >> >>--- >> >>FM and PM (which are essentially the same thing) are different beasts, >>as the output envelope is constant. These modulation methods are not >>spectrally efficient, so their use is not a good idea on crowded >>frequency bands. > > Perhaps it is a matter of perspective. From my point of view you can > modulate a Class C amplifier to produce an Amplitude Modulation Output > in several ways. Further amplification of the AM output requires a > linear amplifier. > > I apologize if I am coming across as an Anal Troll, but you folks are > normally very concise with your Math. If I am in error, please explain. > I make many mistakes every day. I will not take offense from those who > offer to teach me... > John, W8CCW. > John Ferrell W8CCW
I'm still not sure where your misunderstanding arises, but I'll try. If you're going to make a purpose-built transmitter to operate on just one modulation mode at a specific power level (or narrow range thereof), and if it's a mode that'll support it, then you'll get better efficiency in the RF final amplifier with class C (or E). Adding a follow-on linear amplifier isn't a consideration, because you're purpose-building the thing (for instance, for an AM or FM radio station). You're probably used to current amateur practice where you want one radio that does everything, so you get a Kenwood or Yaesu or whatever that puts out 100W PEP, then if you want more punch you follow it with a linear amplifier. That makes sense in the amateur domain because (a) the cost of the power that you use to operate costs a fraction of the total station cost, and (b) the transciever + linear amp combination can be used on any mode that the transciever is capable of, whereas a station with a class-C final stage is much less flexible (you can't use it on SSB, for instance). But if you only ever operate on CW, or AM, FM, or PSK, then you pay for that linear amplifier in your monthly power bill, because it's not operating with nearly the efficiency that a class C amplifier would. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On Mon, 20 Aug 2012 12:19:53 -0500, Tim Wescott <tim@seemywebsite.com>
wrote:
>On Mon, 13 Aug 2012 13:07:03 -0400, John Ferrell wrote: > >> On Sun, 12 Aug 2012 23:18:30 +0300, Tauno Voipio >> <tauno.voipio@notused.fi.invalid> wrote: >> >>>On 12.8.12 11:00 , John Ferrell wrote: >>>> >>>>> 2. When comparing SSB or DSB performance to FM or AM, it is often >>>>> overlooked that the transmit power amplifier for SSB/DSB has to be >>>>> linear, whereas FM/AM amplifiers operate in efficient class C or D or >>>>> E mode. So, if performance is compared for the same power consumption >>>>> of the transmitter (and this is what matters), the advantages of >>>>> SSB/DSB are not so obvious if any at all. >>>>> >>>> This elderly, slow witted student is slowly beginning to understand >>>> the subject and then you say "FM/AM amplifiers operate in efficient >>>> class C or D or E mode". Tell me that was a simple miss speak and I >>>> can get back to the struggle! >>>> >>>> I am learning and enjoying the process but I doubt will ever be more >>>> than a student here. Thanks to all. >>>> >>>> John, de W8CCW >>> >>>It is possible to use a Class C (or higher) amplifier for conventional >>>AM, but the power of the amplifier has to be adjusted along with the >>>modulating waveform. There are two possibilites here: >>> >>>1. Adjust the excitation or operating point of the amplifier so that >>> the output follows the desired envelope, >>> >>>2. Adjust the supply feed so that the output follows the desired >>> envelope. >>> >>>The case 1 was known in the tube era as grid modulation. Both control >>>grid and screen grid modulation were used. Here the modulation comes at >>>the price that the efficiency of the amplifier is about the same as the >>>efficiency of a linear amplifier with the same PEP. >>> >>>The case 2 was known in the tube era as anode (or anode-screen) >>>modulation. Here the carrier efficiency at PEP is the classic Class C >>>level, but the price to be paid is the audio power needed from the >>>modulator, half of the RF stage input power. To have a fair comparison, >>>the modulator power must be calculated into the total efficiency of the >>>transmitter. Remember that the modulator must run in Class B or AB, with >>>the modest efficiency. >>> >>>Transistor power amplifiers often need an adjustment of excitation in >>>combination with the supply voltage modualtion, so pretty often two of >>>the last stages of the transmitter get modulated. >>> >>>--- >>> >>>FM and PM (which are essentially the same thing) are different beasts, >>>as the output envelope is constant. These modulation methods are not >>>spectrally efficient, so their use is not a good idea on crowded >>>frequency bands. >> >> Perhaps it is a matter of perspective. From my point of view you can >> modulate a Class C amplifier to produce an Amplitude Modulation Output >> in several ways. Further amplification of the AM output requires a >> linear amplifier. >> >> I apologize if I am coming across as an Anal Troll, but you folks are >> normally very concise with your Math. If I am in error, please explain. >> I make many mistakes every day. I will not take offense from those who >> offer to teach me... >> John, W8CCW. >> John Ferrell W8CCW > >I'm still not sure where your misunderstanding arises, but I'll try. > >If you're going to make a purpose-built transmitter to operate on just >one modulation mode at a specific power level (or narrow range thereof), >and if it's a mode that'll support it, then you'll get better efficiency >in the RF final amplifier with class C (or E). Adding a follow-on linear >amplifier isn't a consideration, because you're purpose-building the >thing (for instance, for an AM or FM radio station). > >You're probably used to current amateur practice where you want one radio >that does everything, so you get a Kenwood or Yaesu or whatever that puts >out 100W PEP, then if you want more punch you follow it with a linear >amplifier. That makes sense in the amateur domain because (a) the cost >of the power that you use to operate costs a fraction of the total >station cost, and (b) the transciever + linear amp combination can be >used on any mode that the transciever is capable of, whereas a station >with a class-C final stage is much less flexible (you can't use it on SSB, >for instance). > >But if you only ever operate on CW, or AM, FM, or PSK, then you pay for >that linear amplifier in your monthly power bill, because it's not >operating with nearly the efficiency that a class C amplifier would.
Thank you, You spent quite a bit of time on me. I hope my dumb questions do not interfere with the discussions. I hope to better understand signal processing, especially in regard to software defined radio. So, anything offered is appreciated but please just treat me like noise and filter me out when I become a nescience! John, W8CCW John Ferrell W8CCW
