Hi fellows, I am working on coverage optimization of a running CDMA2000a Celluler system commisioned with Lucent BTS Equiptments. I am getting problems regarding ECHO in the Handsets. My CDMA Antennas are co-located with GSM900 antennas. I am using KATHEREIN(65 degree) and DECIBAL PRODUCTS (90 degree) make antennas. Is there any quick solution for solving this problem? Any websites or links would be greatly appreciated. Can I get some info or tip regarding minimum distance to be maintained between CDMA Antennas with GSM Antennas. Regards, Tarun Tiwari.
GSM900 and CDMA2000a Co-located Antennas.
Started by ●September 25, 2003
Reply by ●September 27, 20032003-09-27
Tarun, Why do you suspect the problem is due to the GSM antennas? Echo is usually a problem in the baseband signal processing or connection to POTS, not the RF. "Tarun Tiwari" <tarunmani@yahoo.com> wrote in message news:fb73eea0.0309242317.786b6f50@posting.google.com...> Hi fellows, > > I am working on coverage optimization of a running CDMA2000a Celluler > system commisioned with Lucent BTS Equiptments. I am getting problems > regarding ECHO in the Handsets. My CDMA Antennas are co-located with > GSM900 antennas. > > I am using KATHEREIN(65 degree) and DECIBAL PRODUCTS (90 degree) make > antennas. > Is there any quick solution for solving this problem? > Any websites or links would be greatly appreciated. > > Can I get some info or tip regarding minimum distance to be maintained > between CDMA Antennas with GSM Antennas. > > Regards, > Tarun Tiwari.
