>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: > >> Hello, >> >> can somebody give me an advice? I have decided to use SRF-PLL systemfor>> frequency tracking/estimation in 3 phase power grid recently but there >> is some problems: >> 1. long settling time, but I beliave, I will solve this soon 2. if I am >> trying to change frequency constantly(= frequency ramp), the estimation >> frequency curve is above reference curve and the distanc of thesecurves>> gets bigger with time. So I can say, resulting frequency does notfollow>> grid frequency by frequency ramp. >> >> In other situation it works quite well. I have been testing a lot ofPLL>> systems in Matlab for long time, but problem with frequency ramp >> continues. >> >> Thank you for your ideas. >> >> PS: I am sorry, my English is not good. > >First, I question whether a PLL is really the best approach for this sort>of thing. Given that this is a DSP group, I'm assuming that you're doing>this digitally. Assuming that you have the processing power available, >there are better ways to estimate frequency than by implementing a >traditional PLL. > >Ultimately, a phase locked loop is an excellent solution to the problem >when your signal processing capabilities are largely limited to analog >circuits. When you can do DSP, there are better ways. > >I would consider an approach that samples your signal over some fixed >interval, then does a best-fit of a sine wave to that signal. The >frequency of the sine wave that fits best is then your frequencyestimate.> >Second, if you still feel that you absolutely, positively, must stick >with a PLL, please share some details. If you are implementing the PLL >correctly and in the canonical way, then your problem with ramping is in >your loop filter. But over the years I've seen PLL circuits and >algorithms messed up in some pretty astounding ways, and even seen a few >very non-canonical arrangements that worked quite well indeed. So I >can't just issue general directives without seeing what you're doing. > >PLEASE DON'T BOTHER WITH POSTING JUST CODE!! > >Post a block diagram, or at least a three- or four-line algorithmic >description. If you must, post the code with it, but post a block >diagram. If all you have is code, and you can't draw up a block diagram >or extract the essentials of the algorithm from it, then chances are that>you don't really know what it is that you are doing. In that event, as >you build your block diagram you may find your problem without having to >ask us further. > >-- >My liberal friends think I'm a conservative kook. >My conservative friends think I'm a liberal kook. >Why am I not happy that they have found common ground? > >Tim Wescott, Communications, Control, Circuits & Software >http://www.wescottdesign.com >Hello Tim, the PLL I am testing now, is DDSRF-PLL (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a suitable structure for purpose, I will use it to. As you correctly mentioned, PLL is implemented in DSP (FreeScale 56800E family) using simple algorithm: in first stage there is provided Clark transform, then twice DQ transform and at the end some IIR filters and PI controller with anti-wind-up. Sample frequency of input signals (= 3 phase voltage) I chosed, is 5 kHz. I have tested as pure signal (50 Hz sinus) and signals with harmonic pollution. The rate of frequency change is different. I have tested 0.02 Hz/0.2 s, 0.5 Hz/0.2 s ......and the result is the same - output curve of estimated frequency cannot follow input frequency. I tried adjust Ki and Kp constant in PI controller for million times to improve it, but without good result. I think, the solution of this problem will be in transition response. PLL doesn´t enough time to stabilize itself.
SRF-PLL problem
Started by ●March 27, 2013
Reply by ●March 27, 20132013-03-27
Reply by ●March 28, 20132013-03-28
On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote:>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >> >>> Hello, >>> >>> can somebody give me an advice? I have decided to use SRF-PLL system > for >>> frequency tracking/estimation in 3 phase power grid recently but there >>> is some problems: >>> 1. long settling time, but I beliave, I will solve this soon 2. if I >>> am trying to change frequency constantly(= frequency ramp), the >>> estimation frequency curve is above reference curve and the distanc of >>> these > curves >>> gets bigger with time. So I can say, resulting frequency does not > follow >>> grid frequency by frequency ramp. >>> >>> In other situation it works quite well. I have been testing a lot of > PLL >>> systems in Matlab for long time, but problem with frequency ramp >>> continues. >>> >>> Thank you for your ideas. >>> >>> PS: I am sorry, my English is not good. >> >>First, I question whether a PLL is really the best approach for this >>sort > >>of thing. Given that this is a DSP group, I'm assuming that you're >>doing > >>this digitally. Assuming that you have the processing power available, >>there are better ways to estimate frequency than by implementing a >>traditional PLL. >> >>Ultimately, a phase locked loop is an excellent solution to the problem >>when your signal processing capabilities are largely limited to analog >>circuits. When you can do DSP, there are better ways. >> >>I would consider an approach that samples your signal over some fixed >>interval, then does a best-fit of a sine wave to that signal. The >>frequency of the sine wave that fits best is then your frequency > estimate. >> >>Second, if you still feel that you absolutely, positively, must stick >>with a PLL, please share some details. If you are implementing the PLL >>correctly and in the canonical way, then your problem with ramping is in >>your loop filter. But over the years I've seen PLL circuits and >>algorithms messed up in some pretty astounding ways, and even seen a few >>very non-canonical arrangements that worked quite well indeed. So I >>can't just issue general directives without seeing what you're doing. >> >>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >> >>Post a block diagram, or at least a three- or four-line algorithmic >>description. If you must, post the code with it, but post a block >>diagram. If all you have is code, and you can't draw up a block diagram >>or extract the essentials of the algorithm from it, then chances are >>that > >>you don't really know what it is that you are doing. In that event, as >>you build your block diagram you may find your problem without having to >>ask us further. >> >>-- >>My liberal friends think I'm a conservative kook. >>My conservative friends think I'm a liberal kook. >>Why am I not happy that they have found common ground? >> >>Tim Wescott, Communications, Control, Circuits & Software >>http://www.wescottdesign.com >> >> > Hello Tim, > > the PLL I am testing now, is DDSRF-PLL > (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a > suitable structure for purpose, I will use it to. > As you correctly mentioned, PLL is implemented in DSP (FreeScale 56800E > family) using simple algorithm: in first stage there is provided Clark > transform, then twice DQ transform and at the end some IIR filters and > PI controller with anti-wind-up. > Sample frequency of input signals (= 3 phase voltage) I chosed, is 5 > kHz. I have tested as pure signal (50 Hz sinus) and signals with > harmonic pollution. > The rate of frequency change is different. I have tested 0.02 Hz/0.2 s, > 0.5 Hz/0.2 s ......and the result is the same - output curve of > estimated frequency cannot follow input frequency. > I tried adjust Ki and Kp constant in PI controller for million times to > improve it, but without good result. > > I think, the solution of this problem will be in transition response. > PLL doesn´t enough time to stabilize itself.You have two potential problems. I'm not sure which one applies to your situation. The first is just the PLL bandwidth. As the frequency starts and stops ramping, the loop will take time to react. The second is the fact that you've got a type 2 loop (meaning the open- loop path has two pure integrators). A type 2 loop simply cannot track a ramp with zero error -- you can increase the loop gain (and hence the bandwidth), but you do so at the expense of increasing the bandwidth (and hence the noise sensitivity) and possibly decreasing the loop stability. You can use a proportional-double integrator loop (i.e., use a loop whose transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track a steady ramp with zero error, but keeping all else equal it will have worse transient behavior to frequency steps and at the onset and endings of frequency ramps. I still question the whole PLL approach. There _are_ times when PLLs in software make sense -- but there are times when implementing one instead of using some more modern phase/frequency detection scheme is like sitting on the floor of a modern shop and using stone tools to do some task. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
>On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote: > >>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >>> >>>> Hello, >>>> >>>> can somebody give me an advice? I have decided to use SRF-PLL system >> for >>>> frequency tracking/estimation in 3 phase power grid recently butthere>>>> is some problems: >>>> 1. long settling time, but I beliave, I will solve this soon 2. if I >>>> am trying to change frequency constantly(= frequency ramp), the >>>> estimation frequency curve is above reference curve and the distancof>>>> these >> curves >>>> gets bigger with time. So I can say, resulting frequency does not >> follow >>>> grid frequency by frequency ramp. >>>> >>>> In other situation it works quite well. I have been testing a lot of >> PLL >>>> systems in Matlab for long time, but problem with frequency ramp >>>> continues. >>>> >>>> Thank you for your ideas. >>>> >>>> PS: I am sorry, my English is not good. >>> >>>First, I question whether a PLL is really the best approach for this >>>sort >> >>>of thing. Given that this is a DSP group, I'm assuming that you're >>>doing >> >>>this digitally. Assuming that you have the processing power available, >>>there are better ways to estimate frequency than by implementing a >>>traditional PLL. >>> >>>Ultimately, a phase locked loop is an excellent solution to the problem >>>when your signal processing capabilities are largely limited to analog >>>circuits. When you can do DSP, there are better ways. >>> >>>I would consider an approach that samples your signal over some fixed >>>interval, then does a best-fit of a sine wave to that signal. The >>>frequency of the sine wave that fits best is then your frequency >> estimate. >>> >>>Second, if you still feel that you absolutely, positively, must stick >>>with a PLL, please share some details. If you are implementing the PLL >>>correctly and in the canonical way, then your problem with ramping isin>>>your loop filter. But over the years I've seen PLL circuits and >>>algorithms messed up in some pretty astounding ways, and even seen afew>>>very non-canonical arrangements that worked quite well indeed. So I >>>can't just issue general directives without seeing what you're doing. >>> >>>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >>> >>>Post a block diagram, or at least a three- or four-line algorithmic >>>description. If you must, post the code with it, but post a block >>>diagram. If all you have is code, and you can't draw up a blockdiagram>>>or extract the essentials of the algorithm from it, then chances are >>>that >> >>>you don't really know what it is that you are doing. In that event, as >>>you build your block diagram you may find your problem without havingto>>>ask us further. >>> >>>-- >>>My liberal friends think I'm a conservative kook. >>>My conservative friends think I'm a liberal kook. >>>Why am I not happy that they have found common ground? >>> >>>Tim Wescott, Communications, Control, Circuits & Software >>>http://www.wescottdesign.com >>> >>> >> Hello Tim, >> >> the PLL I am testing now, is DDSRF-PLL >> (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a >> suitable structure for purpose, I will use it to. >> As you correctly mentioned, PLL is implemented in DSP (FreeScale 56800E >> family) using simple algorithm: in first stage there is provided Clark >> transform, then twice DQ transform and at the end some IIR filters and >> PI controller with anti-wind-up. >> Sample frequency of input signals (= 3 phase voltage) I chosed, is 5 >> kHz. I have tested as pure signal (50 Hz sinus) and signals with >> harmonic pollution. >> The rate of frequency change is different. I have tested 0.02 Hz/0.2 s, >> 0.5 Hz/0.2 s ......and the result is the same - output curve of >> estimated frequency cannot follow input frequency. >> I tried adjust Ki and Kp constant in PI controller for million times to >> improve it, but without good result. >> >> I think, the solution of this problem will be in transition response. >> PLL doesn´t enough time to stabilize itself. > >You have two potential problems. I'm not sure which one applies to your >situation. > >The first is just the PLL bandwidth. As the frequency starts and stops >ramping, the loop will take time to react. > >The second is the fact that you've got a type 2 loop (meaning the open- >loop path has two pure integrators). A type 2 loop simply cannot track a>ramp with zero error -- you can increase the loop gain (and hence the >bandwidth), but you do so at the expense of increasing the bandwidth (and>hence the noise sensitivity) and possibly decreasing the loop stability. > >You can use a proportional-double integrator loop (i.e., use a loop whose>transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track a >steady ramp with zero error, but keeping all else equal it will have >worse transient behavior to frequency steps and at the onset and endings >of frequency ramps. > >I still question the whole PLL approach. There _are_ times when PLLs in >software make sense -- but there are times when implementing one instead >of using some more modern phase/frequency detection scheme is like >sitting on the floor of a modern shop and using stone tools to do some >task. > >-- >Tim Wescott >Control system and signal processing consulting >www.wescottdesign.com >Before several minutes I tried to change PI loop to proportional-double integrator loop as you mentioned above. But I am not sure my difference equation of transfer function is correct: kp + ki/(z-1) I wrote as: y(n) = (kp + ki)*e(n) + y(n-1); and ki2/(z-1)^2 I wrote as: y(n) = ki2*e(n) + (2*y(n-1) - y(n-2)); where e ... input error y ... output from loop Can you control it, please?
On Thu, 28 Mar 2013 06:32:52 -0500, Mimar wrote:>>On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote: >> >>>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >>>> >>>>> Hello, >>>>> >>>>> can somebody give me an advice? I have decided to use SRF-PLL system >>> for >>>>> frequency tracking/estimation in 3 phase power grid recently but > there >>>>> is some problems: >>>>> 1. long settling time, but I beliave, I will solve this soon 2. if I >>>>> am trying to change frequency constantly(= frequency ramp), the >>>>> estimation frequency curve is above reference curve and the distanc > of >>>>> these >>> curves >>>>> gets bigger with time. So I can say, resulting frequency does not >>> follow >>>>> grid frequency by frequency ramp. >>>>> >>>>> In other situation it works quite well. I have been testing a lot of >>> PLL >>>>> systems in Matlab for long time, but problem with frequency ramp >>>>> continues. >>>>> >>>>> Thank you for your ideas. >>>>> >>>>> PS: I am sorry, my English is not good. >>>> >>>>First, I question whether a PLL is really the best approach for this >>>>sort >>> >>>>of thing. Given that this is a DSP group, I'm assuming that you're >>>>doing >>> >>>>this digitally. Assuming that you have the processing power >>>>available, >>>>there are better ways to estimate frequency than by implementing a >>>>traditional PLL. >>>> >>>>Ultimately, a phase locked loop is an excellent solution to the >>>>problem when your signal processing capabilities are largely limited >>>>to analog circuits. When you can do DSP, there are better ways. >>>> >>>>I would consider an approach that samples your signal over some fixed >>>>interval, then does a best-fit of a sine wave to that signal. The >>>>frequency of the sine wave that fits best is then your frequency >>> estimate. >>>> >>>>Second, if you still feel that you absolutely, positively, must stick >>>>with a PLL, please share some details. If you are implementing the >>>>PLL correctly and in the canonical way, then your problem with ramping >>>>is > in >>>>your loop filter. But over the years I've seen PLL circuits and >>>>algorithms messed up in some pretty astounding ways, and even seen a > few >>>>very non-canonical arrangements that worked quite well indeed. So I >>>>can't just issue general directives without seeing what you're doing. >>>> >>>>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >>>> >>>>Post a block diagram, or at least a three- or four-line algorithmic >>>>description. If you must, post the code with it, but post a block >>>>diagram. If all you have is code, and you can't draw up a block > diagram >>>>or extract the essentials of the algorithm from it, then chances are >>>>that >>> >>>>you don't really know what it is that you are doing. In that event, >>>>as you build your block diagram you may find your problem without >>>>having > to >>>>ask us further. >>>> >>>>-- >>>>My liberal friends think I'm a conservative kook. >>>>My conservative friends think I'm a liberal kook. >>>>Why am I not happy that they have found common ground? >>>> >>>>Tim Wescott, Communications, Control, Circuits & Software >>>>http://www.wescottdesign.com >>>> >>>> >>> Hello Tim, >>> >>> the PLL I am testing now, is DDSRF-PLL >>> (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a >>> suitable structure for purpose, I will use it to. >>> As you correctly mentioned, PLL is implemented in DSP (FreeScale >>> 56800E family) using simple algorithm: in first stage there is >>> provided Clark transform, then twice DQ transform and at the end some >>> IIR filters and PI controller with anti-wind-up. >>> Sample frequency of input signals (= 3 phase voltage) I chosed, is 5 >>> kHz. I have tested as pure signal (50 Hz sinus) and signals with >>> harmonic pollution. >>> The rate of frequency change is different. I have tested 0.02 Hz/0.2 >>> s, >>> 0.5 Hz/0.2 s ......and the result is the same - output curve of >>> estimated frequency cannot follow input frequency. >>> I tried adjust Ki and Kp constant in PI controller for million times >>> to improve it, but without good result. >>> >>> I think, the solution of this problem will be in transition response. >>> PLL doesn´t enough time to stabilize itself. >> >>You have two potential problems. I'm not sure which one applies to your >>situation. >> >>The first is just the PLL bandwidth. As the frequency starts and stops >>ramping, the loop will take time to react. >> >>The second is the fact that you've got a type 2 loop (meaning the open- >>loop path has two pure integrators). A type 2 loop simply cannot track >>a > >>ramp with zero error -- you can increase the loop gain (and hence the >>bandwidth), but you do so at the expense of increasing the bandwidth >>(and > >>hence the noise sensitivity) and possibly decreasing the loop stability. >> >>You can use a proportional-double integrator loop (i.e., use a loop >>whose > >>transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track a >>steady ramp with zero error, but keeping all else equal it will have >>worse transient behavior to frequency steps and at the onset and endings >>of frequency ramps. >> >>I still question the whole PLL approach. There _are_ times when PLLs in >>software make sense -- but there are times when implementing one instead >>of using some more modern phase/frequency detection scheme is like >>sitting on the floor of a modern shop and using stone tools to do some >>task. >> >>-- >>Tim Wescott Control system and signal processing consulting >>www.wescottdesign.com >> >> > Before several minutes I tried to change PI loop to proportional-double > integrator loop as you mentioned above. > But I am not sure my difference equation of transfer function is > correct: > kp + ki/(z-1) I wrote as: y(n) = (kp + ki)*e(n) + y(n-1); and > ki2/(z-1)^2 I wrote as: y(n) = ki2*e(n) + (2*y(n-1) - y(n-2)); > > where e ... input error > y ... output from loop > > Can you control it, please?I do this sort of thing by breaking out the integrator states separately. This minimizes your chances of having problems with numerical precision, makes the coding more transparent, and makes it easier to apply anti-windup to the integrators. x1(n) = x1(n-1) + ki1 * e(n) (limit x1(n) as necessary) x2(n) = x2(n-1) + ki2/ki1 * x1(n) (limit x2(n) as necessary) y(n) = kp * e(n) + x1 + x2 Of the forms that really make the integrators explicit, the practice of putting the integrator gain at the input of the integrators means two things: one, you won't get jumps in the output if you tune on-line, and two, the "meaning" of your integrator limits more or less stay the same. I'm assuming that you're tuning this in the frequency domain using Bode plots or Nyquist plots -- yes? If you're not ready to step up to that, I probably should not have recommended a double-integrator controller. Note, too, that PLLs that use a double-integrating loop filter are often designed such that the second integrator (x2, ki2) remains off with x2 = 0 until the PLL has achieved lock -- if you don't do that, then your PLL frequency can go off into the weeds and you'll never actually lock. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Reply by ●April 2, 20132013-04-02
>On Thu, 28 Mar 2013 06:32:52 -0500, Mimar wrote: > >>>On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote: >>> >>>>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >>>>> >>>>>> Hello, >>>>>> >>>>>> can somebody give me an advice? I have decided to use SRF-PLLsystem>>>> for >>>>>> frequency tracking/estimation in 3 phase power grid recently but >> there >>>>>> is some problems: >>>>>> 1. long settling time, but I beliave, I will solve this soon 2. ifI>>>>>> am trying to change frequency constantly(= frequency ramp), the >>>>>> estimation frequency curve is above reference curve and the distanc >> of >>>>>> these >>>> curves >>>>>> gets bigger with time. So I can say, resulting frequency does not >>>> follow >>>>>> grid frequency by frequency ramp. >>>>>> >>>>>> In other situation it works quite well. I have been testing a lotof>>>> PLL >>>>>> systems in Matlab for long time, but problem with frequency ramp >>>>>> continues. >>>>>> >>>>>> Thank you for your ideas. >>>>>> >>>>>> PS: I am sorry, my English is not good. >>>>> >>>>>First, I question whether a PLL is really the best approach for this >>>>>sort >>>> >>>>>of thing. Given that this is a DSP group, I'm assuming that you're >>>>>doing >>>> >>>>>this digitally. Assuming that you have the processing power >>>>>available, >>>>>there are better ways to estimate frequency than by implementing a >>>>>traditional PLL. >>>>> >>>>>Ultimately, a phase locked loop is an excellent solution to the >>>>>problem when your signal processing capabilities are largely limited >>>>>to analog circuits. When you can do DSP, there are better ways. >>>>> >>>>>I would consider an approach that samples your signal over some fixed >>>>>interval, then does a best-fit of a sine wave to that signal. The >>>>>frequency of the sine wave that fits best is then your frequency >>>> estimate. >>>>> >>>>>Second, if you still feel that you absolutely, positively, must stick >>>>>with a PLL, please share some details. If you are implementing the >>>>>PLL correctly and in the canonical way, then your problem withramping>>>>>is >> in >>>>>your loop filter. But over the years I've seen PLL circuits and >>>>>algorithms messed up in some pretty astounding ways, and even seen a >> few >>>>>very non-canonical arrangements that worked quite well indeed. So I >>>>>can't just issue general directives without seeing what you're doing. >>>>> >>>>>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >>>>> >>>>>Post a block diagram, or at least a three- or four-line algorithmic >>>>>description. If you must, post the code with it, but post a block >>>>>diagram. If all you have is code, and you can't draw up a block >> diagram >>>>>or extract the essentials of the algorithm from it, then chances are >>>>>that >>>> >>>>>you don't really know what it is that you are doing. In that event, >>>>>as you build your block diagram you may find your problem without >>>>>having >> to >>>>>ask us further. >>>>> >>>>>-- >>>>>My liberal friends think I'm a conservative kook. >>>>>My conservative friends think I'm a liberal kook. >>>>>Why am I not happy that they have found common ground? >>>>> >>>>>Tim Wescott, Communications, Control, Circuits & Software >>>>>http://www.wescottdesign.com >>>>> >>>>> >>>> Hello Tim, >>>> >>>> the PLL I am testing now, is DDSRF-PLL >>>> (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a >>>> suitable structure for purpose, I will use it to. >>>> As you correctly mentioned, PLL is implemented in DSP (FreeScale >>>> 56800E family) using simple algorithm: in first stage there is >>>> provided Clark transform, then twice DQ transform and at the end some >>>> IIR filters and PI controller with anti-wind-up. >>>> Sample frequency of input signals (= 3 phase voltage) I chosed, is 5 >>>> kHz. I have tested as pure signal (50 Hz sinus) and signals with >>>> harmonic pollution. >>>> The rate of frequency change is different. I have tested 0.02 Hz/0.2 >>>> s, >>>> 0.5 Hz/0.2 s ......and the result is the same - output curve of >>>> estimated frequency cannot follow input frequency. >>>> I tried adjust Ki and Kp constant in PI controller for million times >>>> to improve it, but without good result. >>>> >>>> I think, the solution of this problem will be in transition response. >>>> PLL doesn´t enough time to stabilize itself. >>> >>>You have two potential problems. I'm not sure which one applies toyour>>>situation. >>> >>>The first is just the PLL bandwidth. As the frequency starts and stops >>>ramping, the loop will take time to react. >>> >>>The second is the fact that you've got a type 2 loop (meaning the open- >>>loop path has two pure integrators). A type 2 loop simply cannot track >>>a >> >>>ramp with zero error -- you can increase the loop gain (and hence the >>>bandwidth), but you do so at the expense of increasing the bandwidth >>>(and >> >>>hence the noise sensitivity) and possibly decreasing the loopstability.>>> >>>You can use a proportional-double integrator loop (i.e., use a loop >>>whose >> >>>transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track a >>>steady ramp with zero error, but keeping all else equal it will have >>>worse transient behavior to frequency steps and at the onset andendings>>>of frequency ramps. >>> >>>I still question the whole PLL approach. There _are_ times when PLLsin>>>software make sense -- but there are times when implementing oneinstead>>>of using some more modern phase/frequency detection scheme is like >>>sitting on the floor of a modern shop and using stone tools to do some >>>task. >>> >>>-- >>>Tim Wescott Control system and signal processing consulting >>>www.wescottdesign.com >>> >>> >> Before several minutes I tried to change PI loop to proportional-double >> integrator loop as you mentioned above. >> But I am not sure my difference equation of transfer function is >> correct: >> kp + ki/(z-1) I wrote as: y(n) = (kp + ki)*e(n) + y(n-1); and >> ki2/(z-1)^2 I wrote as: y(n) = ki2*e(n) + (2*y(n-1) - y(n-2)); >> >> where e ... input error >> y ... output from loop >> >> Can you control it, please? > >I do this sort of thing by breaking out the integrator states >separately. This minimizes your chances of having problems with >numerical precision, makes the coding more transparent, and makes it >easier to apply anti-windup to the integrators. > >x1(n) = x1(n-1) + ki1 * e(n) >(limit x1(n) as necessary) > >x2(n) = x2(n-1) + ki2/ki1 * x1(n) >(limit x2(n) as necessary) > >y(n) = kp * e(n) + x1 + x2 > >Of the forms that really make the integrators explicit, the practice of >putting the integrator gain at the input of the integrators means two >things: one, you won't get jumps in the output if you tune on-line, and >two, the "meaning" of your integrator limits more or less stay the same. > >I'm assuming that you're tuning this in the frequency domain using Bode >plots or Nyquist plots -- yes? If you're not ready to step up to that, I>probably should not have recommended a double-integrator controller. > >Note, too, that PLLs that use a double-integrating loop filter are often >designed such that the second integrator (x2, ki2) remains off with x2 = >0 until the PLL has achieved lock -- if you don't do that, then your PLL >frequency can go off into the weeds and you'll never actually lock. > >-- >Tim Wescott >Control system and signal processing consulting >www.wescottdesign.com >I have tested the double-integrating loop filter mentioned above this weekend, but the result is the same. Problem still continues. If you can see curves of input and output frequency, you can visit this link: http://uloz.to/xpTLixf/pllfrekvence-jpg. Red is reference frequency and blue is the output of system. At the moment I am studying some documents about PID etc., so I believe I will have a brainwave soon :-).
Very OT I attended a lecture some years ago that explained how all power grids have random frequency variations. Our government records these variations from many countries over a period of years. Why? Lets say a terrorist or a kidnapper makes an audio recording and releases it to the press. Most audio recordings contain a small amount of hum, and you can analyze that hum by cross-correlating the frequency trajectory with your database of mains-frequency trajectories. So in theory you can isolate the time and country where the recording was made. This assumes that countries are frequency-locked over the entire grid, which I think is mostly true. Of course this does not help in the case of a guy in a cave with a generator ...
On 4/2/2013 7:52 AM, radams2000@gmail.com wrote:> Very OT > > I attended a lecture some years ago that explained how all power > grids have random frequency variations. Our government records these > variations from many countries over a period of years. > > Why?Electronic espionage (source identification and leaked data extraction).> Lets say a terrorist or a kidnapper makes an audio recording and > releases it to the press. Most audio recordings contain a small > amount of hum, and you can analyze that hum by cross-correlating the > frequency trajectory with your database of mains-frequency > trajectories. So in theory you can isolate the time and country where > the recording was made. This assumes that countries are > frequency-locked over the entire grid, which I think is mostly true.Did they have any example if this ever worked ? VLV
I'm sure it's been used in a few cases, but I'm guessing that's top secret, they didn't mention any specifics
On Tue, 02 Apr 2013 01:04:28 -0500, Mimar wrote:>>On Thu, 28 Mar 2013 06:32:52 -0500, Mimar wrote: >> >>>>On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote: >>>> >>>>>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >>>>>> >>>>>>> Hello, >>>>>>> >>>>>>> can somebody give me an advice? I have decided to use SRF-PLL > system >>>>> for >>>>>>> frequency tracking/estimation in 3 phase power grid recently but >>> there >>>>>>> is some problems: >>>>>>> 1. long settling time, but I beliave, I will solve this soon 2. if > I >>>>>>> am trying to change frequency constantly(= frequency ramp), the >>>>>>> estimation frequency curve is above reference curve and the >>>>>>> distanc >>> of >>>>>>> these >>>>> curves >>>>>>> gets bigger with time. So I can say, resulting frequency does not >>>>> follow >>>>>>> grid frequency by frequency ramp. >>>>>>> >>>>>>> In other situation it works quite well. I have been testing a lot > of >>>>> PLL >>>>>>> systems in Matlab for long time, but problem with frequency ramp >>>>>>> continues. >>>>>>> >>>>>>> Thank you for your ideas. >>>>>>> >>>>>>> PS: I am sorry, my English is not good. >>>>>> >>>>>>First, I question whether a PLL is really the best approach for this >>>>>>sort >>>>> >>>>>>of thing. Given that this is a DSP group, I'm assuming that you're >>>>>>doing >>>>> >>>>>>this digitally. Assuming that you have the processing power >>>>>>available, >>>>>>there are better ways to estimate frequency than by implementing a >>>>>>traditional PLL. >>>>>> >>>>>>Ultimately, a phase locked loop is an excellent solution to the >>>>>>problem when your signal processing capabilities are largely limited >>>>>>to analog circuits. When you can do DSP, there are better ways. >>>>>> >>>>>>I would consider an approach that samples your signal over some >>>>>>fixed interval, then does a best-fit of a sine wave to that signal. >>>>>>The frequency of the sine wave that fits best is then your frequency >>>>> estimate. >>>>>> >>>>>>Second, if you still feel that you absolutely, positively, must >>>>>>stick with a PLL, please share some details. If you are >>>>>>implementing the PLL correctly and in the canonical way, then your >>>>>>problem with > ramping >>>>>>is >>> in >>>>>>your loop filter. But over the years I've seen PLL circuits and >>>>>>algorithms messed up in some pretty astounding ways, and even seen a >>> few >>>>>>very non-canonical arrangements that worked quite well indeed. So I >>>>>>can't just issue general directives without seeing what you're >>>>>>doing. >>>>>> >>>>>>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >>>>>> >>>>>>Post a block diagram, or at least a three- or four-line algorithmic >>>>>>description. If you must, post the code with it, but post a block >>>>>>diagram. If all you have is code, and you can't draw up a block >>> diagram >>>>>>or extract the essentials of the algorithm from it, then chances are >>>>>>that >>>>> >>>>>>you don't really know what it is that you are doing. In that event, >>>>>>as you build your block diagram you may find your problem without >>>>>>having >>> to >>>>>>ask us further. >>>>>> >>>>>>-- >>>>>>My liberal friends think I'm a conservative kook. My conservative >>>>>>friends think I'm a liberal kook. Why am I not happy that they have >>>>>>found common ground? >>>>>> >>>>>>Tim Wescott, Communications, Control, Circuits & Software >>>>>>http://www.wescottdesign.com >>>>>> >>>>>> >>>>> Hello Tim, >>>>> >>>>> the PLL I am testing now, is DDSRF-PLL >>>>> (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a >>>>> suitable structure for purpose, I will use it to. As you correctly >>>>> mentioned, PLL is implemented in DSP (FreeScale 56800E family) using >>>>> simple algorithm: in first stage there is provided Clark transform, >>>>> then twice DQ transform and at the end some IIR filters and PI >>>>> controller with anti-wind-up. Sample frequency of input signals (= 3 >>>>> phase voltage) I chosed, is 5 kHz. I have tested as pure signal (50 >>>>> Hz sinus) and signals with harmonic pollution. >>>>> The rate of frequency change is different. I have tested 0.02 Hz/0.2 >>>>> s, >>>>> 0.5 Hz/0.2 s ......and the result is the same - output curve of >>>>> estimated frequency cannot follow input frequency. I tried adjust Ki >>>>> and Kp constant in PI controller for million times to improve it, >>>>> but without good result. >>>>> >>>>> I think, the solution of this problem will be in transition >>>>> response. PLL doesn´t enough time to stabilize itself. >>>> >>>>You have two potential problems. I'm not sure which one applies to > your >>>>situation. >>>> >>>>The first is just the PLL bandwidth. As the frequency starts and >>>>stops ramping, the loop will take time to react. >>>> >>>>The second is the fact that you've got a type 2 loop (meaning the >>>>open- loop path has two pure integrators). A type 2 loop simply >>>>cannot track a >>> >>>>ramp with zero error -- you can increase the loop gain (and hence the >>>>bandwidth), but you do so at the expense of increasing the bandwidth >>>>(and >>> >>>>hence the noise sensitivity) and possibly decreasing the loop > stability. >>>> >>>>You can use a proportional-double integrator loop (i.e., use a loop >>>>whose >>> >>>>transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track >>>>a steady ramp with zero error, but keeping all else equal it will have >>>>worse transient behavior to frequency steps and at the onset and > endings >>>>of frequency ramps. >>>> >>>>I still question the whole PLL approach. There _are_ times when PLLs > in >>>>software make sense -- but there are times when implementing one > instead >>>>of using some more modern phase/frequency detection scheme is like >>>>sitting on the floor of a modern shop and using stone tools to do some >>>>task. >>>> >>>>-- >>>>Tim Wescott Control system and signal processing consulting >>>>www.wescottdesign.com >>>> >>>> >>> Before several minutes I tried to change PI loop to >>> proportional-double integrator loop as you mentioned above. But I am >>> not sure my difference equation of transfer function is correct: >>> kp + ki/(z-1) I wrote as: y(n) = (kp + ki)*e(n) + y(n-1); and >>> ki2/(z-1)^2 I wrote as: y(n) = ki2*e(n) + (2*y(n-1) - y(n-2)); >>> >>> where e ... input error >>> y ... output from loop >>> >>> Can you control it, please? >> >>I do this sort of thing by breaking out the integrator states >>separately. This minimizes your chances of having problems with >>numerical precision, makes the coding more transparent, and makes it >>easier to apply anti-windup to the integrators. >> >>x1(n) = x1(n-1) + ki1 * e(n) >>(limit x1(n) as necessary) >> >>x2(n) = x2(n-1) + ki2/ki1 * x1(n) >>(limit x2(n) as necessary) >> >>y(n) = kp * e(n) + x1 + x2 >> >>Of the forms that really make the integrators explicit, the practice of >>putting the integrator gain at the input of the integrators means two >>things: one, you won't get jumps in the output if you tune on-line, and >>two, the "meaning" of your integrator limits more or less stay the same. >> >>I'm assuming that you're tuning this in the frequency domain using Bode >>plots or Nyquist plots -- yes? If you're not ready to step up to that, >>I > >>probably should not have recommended a double-integrator controller. >> >>Note, too, that PLLs that use a double-integrating loop filter are often >>designed such that the second integrator (x2, ki2) remains off with x2 = >>0 until the PLL has achieved lock -- if you don't do that, then your PLL >>frequency can go off into the weeds and you'll never actually lock. >> >>-- >>Tim Wescott >>Control system and signal processing consulting www.wescottdesign.com >> >> > I have tested the double-integrating loop filter mentioned above this > weekend, but the result is the same. Problem still continues. If you can > see curves of input and output frequency, you can visit this link: > http://uloz.to/xpTLixf/pllfrekvence-jpg. Red is reference frequency and > blue is the output of system. > At the moment I am studying some documents about PID etc., so I believe > I will have a brainwave soon :-).I don't get a picture on that site. If there's a button I need to press, alas, I don't read the language. I'll reiterate what I think is causing you trouble: if you're trying to track a steady ramp, then the two-integrator loop will work splendidly. If you're trying to track a ramp that starts and stops, then the two- integrator loop will take some time to settle out to the correct answer, and may actually be worse than a one-integrator solution. If you use a more "modern DSP-ish" batch approach that starts by assuming that you're estimating the frequency of a sine wave that has both an offset and a ramp, then for any segment that you analyze that has a steady ramp, you'll be as close to correct as noise will allow. I'd suggest that you take your sample, split it into cycles at the nominal frequency (50Hz?), extract a phase estimate for each defined cycle, "unwind" the phase estimate (i.e., make sure that -pi and pi connect instead of making a sawtooth), then find the offset and slope of the whole thing. For moderate to low noise, and small frequency variations from nominal, this should be very close to optimum. And you won't have to mess around with phase-locked loops. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
>On Tue, 02 Apr 2013 01:04:28 -0500, Mimar wrote: > >>>On Thu, 28 Mar 2013 06:32:52 -0500, Mimar wrote: >>> >>>>>On Wed, 27 Mar 2013 17:40:08 -0500, Mimar wrote: >>>>> >>>>>>>On Wed, 27 Mar 2013 09:53:41 -0500, Mimar wrote: >>>>>>> >>>>>>>> Hello, >>>>>>>> >>>>>>>> can somebody give me an advice? I have decided to use SRF-PLL >> system >>>>>> for >>>>>>>> frequency tracking/estimation in 3 phase power grid recently but >>>> there >>>>>>>> is some problems: >>>>>>>> 1. long settling time, but I beliave, I will solve this soon 2.if>> I >>>>>>>> am trying to change frequency constantly(= frequency ramp), the >>>>>>>> estimation frequency curve is above reference curve and the >>>>>>>> distanc >>>> of >>>>>>>> these >>>>>> curves >>>>>>>> gets bigger with time. So I can say, resulting frequency does not >>>>>> follow >>>>>>>> grid frequency by frequency ramp. >>>>>>>> >>>>>>>> In other situation it works quite well. I have been testing a lot >> of >>>>>> PLL >>>>>>>> systems in Matlab for long time, but problem with frequency ramp >>>>>>>> continues. >>>>>>>> >>>>>>>> Thank you for your ideas. >>>>>>>> >>>>>>>> PS: I am sorry, my English is not good. >>>>>>> >>>>>>>First, I question whether a PLL is really the best approach forthis>>>>>>>sort >>>>>> >>>>>>>of thing. Given that this is a DSP group, I'm assuming that you're >>>>>>>doing >>>>>> >>>>>>>this digitally. Assuming that you have the processing power >>>>>>>available, >>>>>>>there are better ways to estimate frequency than by implementing a >>>>>>>traditional PLL. >>>>>>> >>>>>>>Ultimately, a phase locked loop is an excellent solution to the >>>>>>>problem when your signal processing capabilities are largelylimited>>>>>>>to analog circuits. When you can do DSP, there are better ways. >>>>>>> >>>>>>>I would consider an approach that samples your signal over some >>>>>>>fixed interval, then does a best-fit of a sine wave to that signal.>>>>>>>The frequency of the sine wave that fits best is then yourfrequency>>>>>> estimate. >>>>>>> >>>>>>>Second, if you still feel that you absolutely, positively, must >>>>>>>stick with a PLL, please share some details. If you are >>>>>>>implementing the PLL correctly and in the canonical way, then your >>>>>>>problem with >> ramping >>>>>>>is >>>> in >>>>>>>your loop filter. But over the years I've seen PLL circuits and >>>>>>>algorithms messed up in some pretty astounding ways, and even seena>>>> few >>>>>>>very non-canonical arrangements that worked quite well indeed. SoI>>>>>>>can't just issue general directives without seeing what you're >>>>>>>doing. >>>>>>> >>>>>>>PLEASE DON'T BOTHER WITH POSTING JUST CODE!! >>>>>>> >>>>>>>Post a block diagram, or at least a three- or four-line algorithmic >>>>>>>description. If you must, post the code with it, but post a block >>>>>>>diagram. If all you have is code, and you can't draw up a block >>>> diagram >>>>>>>or extract the essentials of the algorithm from it, then chancesare>>>>>>>that >>>>>> >>>>>>>you don't really know what it is that you are doing. In thatevent,>>>>>>>as you build your block diagram you may find your problem without >>>>>>>having >>>> to >>>>>>>ask us further. >>>>>>> >>>>>>>-- >>>>>>>My liberal friends think I'm a conservative kook. My conservative >>>>>>>friends think I'm a liberal kook. Why am I not happy that they have >>>>>>>found common ground? >>>>>>> >>>>>>>Tim Wescott, Communications, Control, Circuits & Software >>>>>>>http://www.wescottdesign.com >>>>>>> >>>>>>> >>>>>> Hello Tim, >>>>>> >>>>>> the PLL I am testing now, is DDSRF-PLL >>>>>> (http://www.icrepq.com/icrepq%2712/826-luna.pdf). I think, it is a >>>>>> suitable structure for purpose, I will use it to. As you correctly >>>>>> mentioned, PLL is implemented in DSP (FreeScale 56800E family)using>>>>>> simple algorithm: in first stage there is provided Clark transform, >>>>>> then twice DQ transform and at the end some IIR filters and PI >>>>>> controller with anti-wind-up. Sample frequency of input signals (=3>>>>>> phase voltage) I chosed, is 5 kHz. I have tested as pure signal (50 >>>>>> Hz sinus) and signals with harmonic pollution. >>>>>> The rate of frequency change is different. I have tested 0.02Hz/0.2>>>>>> s, >>>>>> 0.5 Hz/0.2 s ......and the result is the same - output curve of >>>>>> estimated frequency cannot follow input frequency. I tried adjustKi>>>>>> and Kp constant in PI controller for million times to improve it, >>>>>> but without good result. >>>>>> >>>>>> I think, the solution of this problem will be in transition >>>>>> response. PLL doesn´t enough time to stabilize itself. >>>>> >>>>>You have two potential problems. I'm not sure which one applies to >> your >>>>>situation. >>>>> >>>>>The first is just the PLL bandwidth. As the frequency starts and >>>>>stops ramping, the loop will take time to react. >>>>> >>>>>The second is the fact that you've got a type 2 loop (meaning the >>>>>open- loop path has two pure integrators). A type 2 loop simply >>>>>cannot track a >>>> >>>>>ramp with zero error -- you can increase the loop gain (and hence the >>>>>bandwidth), but you do so at the expense of increasing the bandwidth >>>>>(and >>>> >>>>>hence the noise sensitivity) and possibly decreasing the loop >> stability. >>>>> >>>>>You can use a proportional-double integrator loop (i.e., use a loop >>>>>whose >>>> >>>>>transfer function is kp + ki1 /(z-1) + ki2/(z-1)^2). That will track >>>>>a steady ramp with zero error, but keeping all else equal it willhave>>>>>worse transient behavior to frequency steps and at the onset and >> endings >>>>>of frequency ramps. >>>>> >>>>>I still question the whole PLL approach. There _are_ times when PLLs >> in >>>>>software make sense -- but there are times when implementing one >> instead >>>>>of using some more modern phase/frequency detection scheme is like >>>>>sitting on the floor of a modern shop and using stone tools to dosome>>>>>task. >>>>> >>>>>-- >>>>>Tim Wescott Control system and signal processing consulting >>>>>www.wescottdesign.com >>>>> >>>>> >>>> Before several minutes I tried to change PI loop to >>>> proportional-double integrator loop as you mentioned above. But I am >>>> not sure my difference equation of transfer function is correct: >>>> kp + ki/(z-1) I wrote as: y(n) = (kp + ki)*e(n) + y(n-1); and >>>> ki2/(z-1)^2 I wrote as: y(n) = ki2*e(n) + (2*y(n-1) - y(n-2)); >>>> >>>> where e ... input error >>>> y ... output from loop >>>> >>>> Can you control it, please? >>> >>>I do this sort of thing by breaking out the integrator states >>>separately. This minimizes your chances of having problems with >>>numerical precision, makes the coding more transparent, and makes it >>>easier to apply anti-windup to the integrators. >>> >>>x1(n) = x1(n-1) + ki1 * e(n) >>>(limit x1(n) as necessary) >>> >>>x2(n) = x2(n-1) + ki2/ki1 * x1(n) >>>(limit x2(n) as necessary) >>> >>>y(n) = kp * e(n) + x1 + x2 >>> >>>Of the forms that really make the integrators explicit, the practice of >>>putting the integrator gain at the input of the integrators means two >>>things: one, you won't get jumps in the output if you tune on-line, and >>>two, the "meaning" of your integrator limits more or less stay thesame.>>> >>>I'm assuming that you're tuning this in the frequency domain using Bode >>>plots or Nyquist plots -- yes? If you're not ready to step up to that, >>>I >> >>>probably should not have recommended a double-integrator controller. >>> >>>Note, too, that PLLs that use a double-integrating loop filter areoften>>>designed such that the second integrator (x2, ki2) remains off with x2=>>>0 until the PLL has achieved lock -- if you don't do that, then yourPLL>>>frequency can go off into the weeds and you'll never actually lock. >>> >>>-- >>>Tim Wescott >>>Control system and signal processing consulting www.wescottdesign.com >>> >>> >> I have tested the double-integrating loop filter mentioned above this >> weekend, but the result is the same. Problem still continues. If youcan>> see curves of input and output frequency, you can visit this link: >> http://uloz.to/xpTLixf/pllfrekvence-jpg. Red is reference frequency and >> blue is the output of system. >> At the moment I am studying some documents about PID etc., so I believe >> I will have a brainwave soon :-). > >I don't get a picture on that site. If there's a button I need to press,>alas, I don't read the language. > >I'll reiterate what I think is causing you trouble: if you're trying to >track a steady ramp, then the two-integrator loop will work splendidly. >If you're trying to track a ramp that starts and stops, then the two- >integrator loop will take some time to settle out to the correct answer, >and may actually be worse than a one-integrator solution. > >If you use a more "modern DSP-ish" batch approach that starts by assuming>that you're estimating the frequency of a sine wave that has both an >offset and a ramp, then for any segment that you analyze that has a >steady ramp, you'll be as close to correct as noise will allow. > >I'd suggest that you take your sample, split it into cycles at the >nominal frequency (50Hz?), extract a phase estimate for each defined >cycle, "unwind" the phase estimate (i.e., make sure that -pi and pi >connect instead of making a sawtooth), then find the offset and slope of >the whole thing. For moderate to low noise, and small frequency >variations from nominal, this should be very close to optimum. And you >won't have to mess around with phase-locked loops. > >-- >My liberal friends think I'm a conservative kook. >My conservative friends think I'm a liberal kook. >Why am I not happy that they have found common ground? > >Tim Wescott, Communications, Control, Circuits & Software >http://www.wescottdesign.com >I think it will be better, I'll give here my code of proposed PLL written in Matlab: %.......................................................................... % % Test of SFR-PLL % %.......................................................................... clc; clear all; close all; %.......................................................................... f = 40; fvz = 5000; Ts = 1/fvz; %.......................................................................... faze = 0; reg_P = 0; delka_sig = 3000; %% test signal generation SNR = 60; % noise to signal ratio AMP1 = 10; NSAMP = AMP1/(10^(SNR/20)) % amplitude for SNR for n = 0 : 1 : delka_sig-1 % delka_sig is length of signal in English %% variable frequencies if n < 370 f = 50; elseif n >= 370 & n < 1200 if mod(n, 200) f = f + 0.01; else f = f; end elseif n >= 1200 & n < 1500 f = 57; else if mod(n, 100) f = f - 0.01; else f = f; end end reference_f(n+1) = f; % vector of freq. % harmonics uA(n+1) = AMP1 * sin(2*pi*f*Ts*n); % 1. uB(n+1) = AMP1 * sin(2*pi*f*Ts*n + (2*pi)/3); uC(n+1) = AMP1 * sin(2*pi*f*Ts*n - (2*pi)/3); uA3(n+1) = 1 * sin(3*2*pi*f*Ts*n); % 3. uB3(n+1) = 1 * sin(3*2*pi*f*Ts*n + (2*pi)/3); uC3(n+1) = 1 * sin(3*2*pi*f*Ts*n - (2*pi)/3); uA5(n+1) = 0.8 * sin(5*2*pi*f*Ts*n); % 5. uB5(n+1) = 0.8 * sin(5*2*pi*f*Ts*n + (2*pi)/3); uC5(n+1) = 0.8 * sin(5*2*pi*f*Ts*n - (2*pi)/3); uA7(n+1) = 0.4 * sin(7*2*pi*f*Ts*n); % 7. uB7(n+1) = 0.4 * sin(7*2*pi*f*Ts*n + (2*pi)/3); uC7(n+1) = 0.4 * sin(7*2*pi*f*Ts*n - (2*pi)/3); end noise = NSAMP * randn(size(delka_sig)); % noise inserting %% now only pure signal uA = uA; % + uA3 + uA5 + uA7 + noise; uB = uB; % + uB3 + uB5 + uB7 + noise; uC = uC; %+ uC3 + uC5 + uC7 + noise; %........data preparing.................................................... uD = zeros(1, delka_sig); uQ = zeros(1, delka_sig); f_out = zeros(1, delka_sig); % output (estimated) frequency reg_I = zeros(1, delka_sig); % integer part of controller reg_ID = zeros(1, delka_sig); % second integer part of controller w_out = zeros(1, delka_sig); % output angular frequency phase = zeros(1, delka_sig); % output phase contr = zeros(1, delka_sig); % other PI controller error = zeros(1, delka_sig); % input error for controller %.......................................................................... %........parameters........................................................ %% constant for controller Kp = 250; % Ki = 50; Ki_1 = 0.001; Ki_2 = -0.5; a1 = ((Kp*Ts)/(2*Ki)) - Kp; a2 = ((Kp*Ts)/(2*Ki)) + Kp; b1 = 0.5; %% MAIN LOOP for n = 3 : 1 : delka_sig %% Clark transformation Ualpha = (2*uA(n) - uB(n) - uC(n))/3; % slozka ALFA Ubeta = (uB(n) - uC(n))/1.73205; % slozka BETA %% Park transformation uD(n) = Ualpha*cos(phase(n-1)) + Ubeta*sin(phase(n-1)); uQ(n) = Ubeta *cos(phase(n-1)) - Ualpha*sin(phase(n-1)); % error error(n) = uQ(n); %% PI controllers %{ % P reg_P = Kp * error(n); % I % first integrator reg_I(n) = reg_I(n-1) + Kp * 1/Ki_1 * Ts * (error(n) + error(n-1))/2; % second integrator reg_ID(n) = reg_ID(n-1) + Ki_2/Ki_1 *reg_I(n)*Ts; %} % alternative for PI regul(n) = a1*error(n) + a2*error(n-1) + b1*regul(n-1); % it is better than above % angular frequency w_out(n) = 314.159 + regul(n); % + reg_I(n); %+ reg_ID(n); % phase phase(n) = phase(n-1) + w_out(n) * Ts; if phase(n) > 2*pi phase(n) = 0; elseif phase(n) < 0 phase(n) = 2*pi; else phase(n) = phase(n); end % output, estimated frequency f_out(n-1) = w_out(n)/(2*pi); end %........graphic output................................................... osax = [0 : 1 : delka_sig-1]*Ts; % x axis figure(1) subplot(2,1,1) hold on plot(uA(1:500), 'r'); plot(uB(1:500), 'c'); plot(uC(1:500), 'g'); hold off subplot(2,1,2) hold on plot(osax, reference_f, 'r', 'LineWidth', 2); plot(osax, f_out, 'c', 'LineWidth', 1.5); legend('In', 'Out'); grid on figure(2) subplot(2,1,1) hold on plot(uA(1:500), 'r'); plot(uQ(1:500), 'c'); grid on subplot(2,1,2) plot(phase(1:500), 'c'); grid on
