"Bryan Olson" <fakeaddress@nowhere.org> wrote in message news:biYsd.29447$zx1.4950@newssvr13.news.prodigy.com...> Karl Malbrain wrote: > > Over a wide area network the variance is likely 10^12. > > Standing by itself and with no unit, that's not meaningful. Tim > had it right (sorry about my previous confusion):The unit is cpu cycles squared, estimated.> The key parameters in this case are the deterministic difference in > turn-around time due to message content and the variance in turn- > around time from the network. > > We can compress this to a single parameter: the signal to noise ratio. > The signal is the expected time difference caused by the key/message > values, and the noise is the standard deviation in the network turn- > around time. Both are in seconds, so the ratio is a unit-less constant.Professor Bernstein's attack on the Athlon accumulates a 1 cpu-cycle timing difference between trial encryptions -- estimated at a 1 cpu-cycle squared variance.> In this case, working with noise/signal is a little more convenient > than signal/noise. We expect the signal to become larger than the noise > when the number of messages exceeds the square of the single-message > noise/signal.> > With a message > > length of 1K bits and a DS3 transfer rate of 45 mbs, that's 45K > > encryptions/second which makes for 50+ years. > > Do you know the optical circuit data rate? karl m > > Those numbers don't really tell us anything. If the standard deviation > in the time is 1000 times as large than the key-dependent effect, then > we expect to need on the order of a million messages.Right. My point was that over a DS3 line with a timing variance of 10^12 there's not much worry of a remote wide-area-network timing attack. karl m
AES timing attacks
Started by ●December 4, 2004
Reply by ●December 6, 20042004-12-06
"Clay Turner" <physics@bellsouth.net> wrote in message news:KCKsd.104218$IQ.17698@bignews6.bellsouth.net...> Hello Randy, > > The RSA algo has a similar vunerability and the standard work around wasto> make the encryption/decryption process a constant time one.Do you have any details on this? A web url, for example? Thanks, karl m
"karl malbrain" <karl_m@acm.org> wrote in message news:31jqstF396i8vU1@individual.net...> > "Clay Turner" <physics@bellsouth.net> wrote in message > news:KCKsd.104218$IQ.17698@bignews6.bellsouth.net... > > > Hello Randy, > > > > The RSA algo has a similar vunerability and the standard work around was > to > > make the encryption/decryption process a constant time one. > > Do you have any details on this? A web url, for example? > > Thanks, karl mHello Karl, I think you will find the following paper more than useful. http://crypto.stanford.edu/~dabo/papers/ssl-timing.pdf Clay S. Turner
"Clay Turner" <physics@bellsouth.net> wrote in message news:vH3td.36626$Dm2.1889@bignews1.bellsouth.net...> > "karl malbrain" <karl_m@acm.org> wrote in message > news:31jqstF396i8vU1@individual.net... > > > > "Clay Turner" <physics@bellsouth.net> wrote in message > > news:KCKsd.104218$IQ.17698@bignews6.bellsouth.net... > > > > > Hello Randy, > > > > > > The RSA algo has a similar vunerability and the standard work aroundwas> > to > > > make the encryption/decryption process a constant time one. > > > > Do you have any details on this? A web url, for example? > > > > Thanks, karl m > > Hello Karl, > > I think you will find the following paper more than useful. > > http://crypto.stanford.edu/~dabo/papers/ssl-timing.pdfYes, thanks. I'd been stuck in section 5 and hadn't read section 6 yet. karl m
Reply by ●December 7, 20042004-12-07
"karl malbrain" <karl_m@acm.org> wrote in message news:31jqstF396i8vU1@individual.net...> > "Clay Turner" <physics@bellsouth.net> wrote in message > news:KCKsd.104218$IQ.17698@bignews6.bellsouth.net... > > > Hello Randy, > > > > The RSA algo has a similar vunerability and the standard work around was > to > > make the encryption/decryption process a constant time one. > > Do you have any details on this? A web url, for example? > > Thanks, karl m >Google for "Quisquater" and "RSA". This professor from Belgium has published a lot about timing attacks. Wim
"Karl Malbrain" <karl_m@acm.org> wrote in message news:1102269765.683817.172220@f14g2000cwb.googlegroups.com...> > Bryan Olson wrote: > > Bryan Olson wrote: > > > > > > > > Tim Wescott wrote: > > > > [...] This means that if the > > > > variance in your network turn-around time is v, and if the > difference > > > > between message times is t_d, you need to collect somewhere on > the > > order > > > > of N = v / t_d^2 of each type of message if you want to discern > a > > > > difference. > > > > > > I think you mean N = (v / t_d)^2. > > > > Oops, my mistake. The variance is already in seconds^2. > > On a wide area network I estimate the variance is going to run 10^12. > With a DS3 connection of 45mbs that's about 50 years to gather enough > trial encryptions. > > karl m >Karl, Bryan et. al., The guys at Stanford, were able to break the RSA code via a timing attack over a network within two hours. And that is for a case of using 1000 digit numbers. Clay S. Turner
"Clay Turner" <physics@bellsouth.net> wrote in message news:aAktd.38809$Dm2.10619@bignews1.bellsouth.net...> > Karl, Bryan et. al., > > The guys at Stanford, were able to break the RSA code via a timing attack > over a network within two hours. And that is for a case of using 1000digit> numbers. >Their attack used a timing difference of 10^7 cpu cycles over a local area network. Professor Bernstein's attack uses a timing difference of 1 cpu cycle. karl m
