Jerry Avins <jya@ieee.org> writes:> Randy Yates wrote: > > > ... If the output values are asymmetrical (e.g., 0/1), then > > you will have a DC offset, but that's not relevent to the upper part of the > > spectrum where the quantization noise will be. > > Hmmm... If there are no transitions at all, there will be lots of DC > offset and no noise at all. Something doesn't hang together and at the > moment, I don't see what.Jerry, If there are no transitions at all, then the input must be precisely at one of the two binary output levels, thus the output is following the input exactly and in this case there is no quantization noise. When the input moves off of either of the two binary output values, then the modulator will start "modulating," i.e., moving back and forth between the two output values in a manner such that the average output value equals the input value. Doesn't that hang together perfectly? -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Please help me in understanding "Decimation filter"
Started by ●September 10, 2004
Reply by ●September 13, 20042004-09-13
Randy Yates <randy.yates@sonyericsson.com> writes:> [blah blah blah]Wait. I think maybe I see the unhanging you (Jerry) spoke of now. I brought up a bastard case - one in which there are two outputs from the quantizer. One output feeds the summing junction at the front-end and must be "correct" (e.g., 0x7FFF and 0x8001, in two's complement). However, note that this output is "multibit" even though there are only two values used. Herein lies the (potential) confusion - many folks take the MSB (the sign) bit can call *THAT* the output (e.g., for input to a Matlab routine). Then THAT output will have a DC offset that is not "really" there. That's the scenario I meant to address, in any case. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Randy Yates wrote:> Jerry Avins <jya@ieee.org> writes: > > >>Randy Yates wrote: >> >> >>> ... If the output values are asymmetrical (e.g., 0/1), then >>>you will have a DC offset, but that's not relevent to the upper part of the >>>spectrum where the quantization noise will be. >> >>Hmmm... If there are no transitions at all, there will be lots of DC >>offset and no noise at all. Something doesn't hang together and at the >>moment, I don't see what. > > > Jerry, > > If there are no transitions at all, then the input must be precisely > at one of the two binary output levels, thus the output is following > the input exactly and in this case there is no quantization noise. > > When the input moves off of either of the two binary output values, > then the modulator will start "modulating," i.e., moving back and > forth between the two output values in a manner such that the average > output value equals the input value. > > Doesn't that hang together perfectly?It does. I'm not sure how it ties in with the high-frequency noise being independent of the DC offset. I accept my "counterexample" as an exceptional case. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
hswnetin@yahoo.com (hswnetin) wrote in message news:<a4d4dd49.0409100158.333eb072@posting.google.com>...> Hi All, > > I thank all of you, for your support, which I got previously. I am > hardware design engineer and working on sigma delta ADC. And my role > is to design decimation filter, basically I have to design a blocks > which converts single bit to multi bits output. I surveyed lots of > literature. > > I referred "An Economical Class of Digital Filters for Decimation and > Interpolation" by Eugine B Hogenauer too. I could able to understand > the following things like, decimator receives single bit (or 2 or 3 > bit output depending on modulator). And there are integrator stage and > comb stage. etc. I am unable to understand how the single bit is > converted to multi bits. I could not understand the concept of number > of stages. Also I could not understand the logic behind dropping of > bits after calculating the Bmax. > > Please help me in understanding the issues in decimator filter. > > Thanks in advance. > > Regards, > hswnetinMaybe a trivially simple example can help: Let's say your "filter" is just accumulating the bit stream. Let's also say your decimation factor is four - meaning you are sampling the "filter" (accumulator) output four times slower that the filter input rate. So, after four samples, with four 1s and/or zeros coming in, your "filter" output (remember we are summing) can be either 000, 001, 010, 011 or 100 (binary). So, you can see that your one bit of INPUT resolution has magically increased to three bits of OUTPUT resolution! Basically, you use many tiny values over time to make one big value. Does that help or is it too simplistic?
picnic wrote: ...> So, after four samples, with four 1s and/or zeros coming in, your > "filter" output (remember we are summing) can be either 000, 001, 010, > 011 or 100 (binary).Almost correct. You have 5 values there. The possible output can be 00, 01, 10, or 11. To get 3 bits, you would need to accumulate 8 samples. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●September 14, 20042004-09-14
Hi All, Thanks for your replies. I will consider all your inputs for my groundwork. I will come back to you when I arrive at some stage of design. Thanks again to all of you. Regards, hswnetin Jerry Avins <jya@ieee.org> wrote in message news:<4145efd4$0$2659$61fed72c@news.rcn.com>...> picnic wrote: > > ... > > > So, after four samples, with four 1s and/or zeros coming in, your > > "filter" output (remember we are summing) can be either 000, 001, 010, > > 011 or 100 (binary). > > Almost correct. You have 5 values there. The possible output can be 00, > 01, 10, or 11. To get 3 bits, you would need to accumulate 8 samples. > > ... > > Jerry
Reply by ●September 16, 20042004-09-16
Jerry Avins <jya@ieee.org> wrote in message news:<4145efd4$0$2659$61fed72c@news.rcn.com>...> picnic wrote: > > ... > > > So, after four samples, with four 1s and/or zeros coming in, your > > "filter" output (remember we are summing) can be either 000, 001, 010, > > 011 or 100 (binary). > > Almost correct. You have 5 values there. The possible output can be 00, > 01, 10, or 11. To get 3 bits, you would need to accumulate 8 samples. > > ... > > JerryOkay... So, let's say we are accumulating FOUR values, and they are all ones: After sample #1: Sum = 1 After sample #2: Sum = 10 After sample #3: Sum = 11 After sample #4: Sum = 100 That looks a lot like three bits to me.
picnic wrote:> Jerry Avins <jya@ieee.org> wrote in message news:<4145efd4$0$2659$61fed72c@news.rcn.com>... > >>picnic wrote: >> >> ... >> >> >>>So, after four samples, with four 1s and/or zeros coming in, your >>>"filter" output (remember we are summing) can be either 000, 001, 010, >>>011 or 100 (binary). >> >>Almost correct. You have 5 values there. The possible output can be 00, >>01, 10, or 11. To get 3 bits, you would need to accumulate 8 samples. >> >> ... >> >>Jerry > > > Okay... > > So, let's say we are accumulating FOUR values, and they are all ones: > > After sample #1: Sum = 1 > After sample #2: Sum = 10 > After sample #3: Sum = 11 > After sample #4: Sum = 100 > > That looks a lot like three bits to me.You're right. Something is a bit amiss, though. First off, if we're going to use three bits, we might as well count up to seven. Another issue troubles me more. I think it's a case of a carry bit, but that could be a silly way to put it. If the count were sixteen, five bits would be needed, and 15 out of a possible 32 numbers would go unused. That's too dumb to live long. Someone must have invented a better way. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
