Hi, all, TI C6x platform. Could I create STS objects and use them to monitor system run-time information while at the same time disabling RTA and RTDX in the DSP/BIOS configuration tool? I don't want the RTA and RTDX modules to use up too much memory and CPU cycles. Thanks! Rose
Can I use STS module of DSP/BIOS while disabling RTA & RTDX at the same time?
Started by ●September 9, 2004
Reply by ●September 9, 20042004-09-09
Yes, you can but you will only see your CCS window update when the processor halts (i.e. hits a breakpoint, etc.). Brad "rose" <axlrose@263.net> wrote in message news:6ff10342.0409082252.62db8eca@posting.google.com...> Hi, all, > > TI C6x platform. Could I create STS objects and use them to monitor > system run-time information while at the same time disabling RTA and > RTDX in the DSP/BIOS configuration tool? I don't want the RTA and RTDX > modules to use up too much memory and CPU cycles. > > Thanks! > > Rose
Reply by ●September 10, 20042004-09-10
Thanks a lot. I have another question: As you have said, I can only see CCS window update when the processor halts. Then in such a situation (with RTA and RTDX disabled), if I set up some displays in the View -> Graph tools (for example, I want to see the constellation graph of a stream of continuous incoming wireless data frames), can I refresh the graph window while program is running, without enabling breakpoints, to obtain the graph view whenever I want? "Brad Griffis" <bradgriffis@hotmail.com> wrote in message news:<5uY%c.7205$Dv2.4322@newssvr31.news.prodigy.com>...> Yes, you can but you will only see your CCS window update when the processor > halts (i.e. hits a breakpoint, etc.). > > Brad >
What DSP are you using? What version of CCS? "rose" <axlrose@263.net> wrote in message news:6ff10342.0409092053.42fb79c2@posting.google.com...> Thanks a lot. I have another question: > > As you have said, I can only see CCS window update when the processor > halts. Then in such a situation (with RTA and RTDX disabled), if I set > up some displays in the View -> Graph tools (for example, I want to > see the constellation graph of a stream of continuous incoming > wireless data frames), can I refresh the graph window while program is > running, without enabling breakpoints, to obtain the graph view > whenever I want? > > "Brad Griffis" <bradgriffis@hotmail.com> wrote in message > news:<5uY%c.7205$Dv2.4322@newssvr31.news.prodigy.com>... >> Yes, you can but you will only see your CCS window update when the >> processor >> halts (i.e. hits a breakpoint, etc.). >> >> Brad >>
Reply by ●September 11, 20042004-09-11
DSP chip is 6416 or 6202 and the version CCS is 2.2. "Brad Griffis" <bradgriffis@hotmail.com> wrote in message news:<Kph0d.442$Qv5.149@newssvr33.news.prodigy.com>...> What DSP are you using? What version of CCS?
Reply by ●September 12, 20042004-09-12
I'm not really sure about refreshing data on the 6202. However, the 6416 has a cool feature called "real-time mode". If you go to Debug -> Real-Time Mode and then right-click on your graph (or watch window or memory window) and select "continuous refresh" then you will get exactly that. The 6202 won't allow for real-time mode but I think you can manually refresh the window. Brad "rose" <axlrose@263.net> wrote in message news:6ff10342.0409110236.10ac9097@posting.google.com...> DSP chip is 6416 or 6202 and the version CCS is 2.2. > > "Brad Griffis" <bradgriffis@hotmail.com> wrote in message > news:<Kph0d.442$Qv5.149@newssvr33.news.prodigy.com>... >> What DSP are you using? What version of CCS?
Thanks. So it is to say that refreshing graph window during program running time don't rely on the presence of RTDX? "Brad Griffis" <bradgriffis@hotmail.com> wrote in message news:<SGQ0d.1047$Qv5.424@newssvr33.news.prodigy.com>...> I'm not really sure about refreshing data on the 6202. However, the 6416 > has a cool feature called "real-time mode". If you go to Debug -> Real-Time > Mode and then right-click on your graph (or watch window or memory window) > and select "continuous refresh" then you will get exactly that. The 6202 > won't allow for real-time mode but I think you can manually refresh the > window. > > Brad > > "rose" <axlrose@263.net> wrote in message > news:6ff10342.0409110236.10ac9097@posting.google.com... > > DSP chip is 6416 or 6202 and the version CCS is 2.2. > > > > "Brad Griffis" <bradgriffis@hotmail.com> wrote in message > > news:<Kph0d.442$Qv5.149@newssvr33.news.prodigy.com>... > >> What DSP are you using? What version of CCS?
Correct. "rose" <axlrose@263.net> wrote in message news:6ff10342.0409120412.701dc4d1@posting.google.com...> Thanks. So it is to say that refreshing graph window during program > running time don't rely on the presence of RTDX? > > "Brad Griffis" <bradgriffis@hotmail.com> wrote in message > news:<SGQ0d.1047$Qv5.424@newssvr33.news.prodigy.com>... >> I'm not really sure about refreshing data on the 6202. However, the 6416 >> has a cool feature called "real-time mode". If you go to Debug -> >> Real-Time >> Mode and then right-click on your graph (or watch window or memory >> window) >> and select "continuous refresh" then you will get exactly that. The 6202 >> won't allow for real-time mode but I think you can manually refresh the >> window. >> >> Brad >> >> "rose" <axlrose@263.net> wrote in message >> news:6ff10342.0409110236.10ac9097@posting.google.com... >> > DSP chip is 6416 or 6202 and the version CCS is 2.2. >> > >> > "Brad Griffis" <bradgriffis@hotmail.com> wrote in message >> > news:<Kph0d.442$Qv5.149@newssvr33.news.prodigy.com>... >> >> What DSP are you using? What version of CCS?
