Hi all Today I get JTAG xds510pp_plus but I have find a problem to install it. I have the system: ______________ |TMS320C6711DSK|<----- Printer port ----->PC and the new one: ______________ |TMS320C6711DSK| (<---) JTAG Interface(??) --- Printer port ----->PC(??) so have I use 2 Printer port to connect JTAG,DSP and PC ? DSP<-------->JTAG \ / \ / <------printer port ? PC ? or I should disconnect the Printer port connection from DSP ? Suggest me please Thanking you Regards Dibyendu Mondal
Install JTAG XDS510pp_plus
Started by ●February 11, 2005
Reply by ●February 11, 20052005-02-11
Hi, like this: |TMS320C6711DSK| (<---) XDS510ppplus --- Printer port ----->PC Connect the PC and the XDS via a parallel cable. And the XDS is plugged into the DSK-board. Simone
Simone Winkler wrote:> Hi, > like this: > > > |TMS320C6711DSK| (<---) XDS510ppplus --- Printer port ----->PC > > Connect the PC and the XDS via a parallel cable. And the XDS isplugged into> the DSK-board. > > > SimoneHi Simon Is it bother which version of code composer studio i have use. (during the XDS510ppplus installation?) My code composer studio version is 1.23 (i.e. ccs dsk v1.23) And the DSK-board not responding bye the process of installation which you and Spectrum Digital installation guid said. Thanking you Regards Dibyendu Mondal
hi, i have two ideas of possible solutions: * you need a driver for the emulator, which you can download at http://emulators.spectrumdigital.com/c6000/. I am quite sure that there's already an available configuration driver for the 6711 DSK inside the Setup Tool of Code Composer Studio. You need to start the Setup tool and add a board of C6711 DSK to your system configuration. Then you can change the settings, you probably need to enter 0x378 for your parallel port, as well as you need to select a single processor and a startup-gel file (the gel-file might be found by browsing...at my place it is called DSK6211_6711.gel ) Maybe, that's already everything you need to do, but I'm not sure. Me, I used a different board and processor (C6713 on a D.SignT module), and so I had to perform the following step as well. * I had to use SDConfig.exe which you can download at their page too. Their I selected 378 as the printer port and at the folder EMU I had to select the XDS510pp_plus with ECP, port speed 0. You can then try to verify your connection to the emulator with this tool too. You seem to own a very old version of Code Composer Studio. I hope everything's the same for this version, I only use version 2.21. :) Hope this helps! Yours Simone
Reply by ●February 15, 20052005-02-15
Dear Simon I am very much thank full of you for your cooperation. Look I have only CCSDSK(C6711) of varsion 1.23, and all the driver for JTAG in http://emulators.spectrumdigital.com/c6000/ are upper then the version 2.x or 3.x, so the driver hade not matched, and it is still a problem for me coz I can't buy CCSDSK C6000 v2.x . I know that you can guide me properly. Thanking you Dibyendu Mondal Simone Winkler wrote:> hi, > > i have two ideas of possible solutions: > * you need a driver for the emulator, which you can download at > http://emulators.spectrumdigital.com/c6000/. I am quite sure thatthere's> already an available configuration driver for the 6711 DSK inside theSetup> Tool of Code Composer Studio. You need to start the Setup tool andadd a> board of C6711 DSK to your system configuration. Then you can changethe> settings, you probably need to enter 0x378 for your parallel port, aswell> as you need to select a single processor and a startup-gel file (the > gel-file might be found by browsing...at my place it is called > DSK6211_6711.gel ) > > Maybe, that's already everything you need to do, but I'm not sure.Me, I> used a different board and processor (C6713 on a D.SignT module), andso I> had to perform the following step as well. > > * I had to use SDConfig.exe which you can download at their page too.Their> I selected 378 as the printer port and at the folder EMU I had toselect the> XDS510pp_plus with ECP, port speed 0. You can then try to verify your> connection to the emulator with this tool too. > > > You seem to own a very old version of Code Composer Studio. I hope > everything's the same for this version, I only use version 2.21. > > :) > > Hope this helps! > > Yours > Simone
Reply by ●February 16, 20052005-02-16
Hi, do you have a Setup tool for your code composer studio? It is called cc_setup.exe in the \bin directory at my version of code composer studio. If you have it, open it. There you can install a configuration, and it is possible, that you can find a DSK6711 configuration available to install. Try to do that and write again... Simone <dib_mon@yahoo.co.in> schrieb im Newsbeitrag news:1108477362.639584.72310@c13g2000cwb.googlegroups.com...> Dear Simon > I am very much thank full of you for your cooperation. > Look I have only CCSDSK(C6711) of varsion 1.23, and all the driver for > JTAG in > http://emulators.spectrumdigital.com/c6000/ are upper then the version > 2.x or 3.x, so the driver hade not matched, and it is still a problem > for me coz I can't buy CCSDSK C6000 v2.x . > I know that you can guide me properly. > > Thanking you > > Dibyendu Mondal > > > Simone Winkler wrote: >> hi, >> >> i have two ideas of possible solutions: >> * you need a driver for the emulator, which you can download at >> http://emulators.spectrumdigital.com/c6000/. I am quite sure that > there's >> already an available configuration driver for the 6711 DSK inside the > Setup >> Tool of Code Composer Studio. You need to start the Setup tool and > add a >> board of C6711 DSK to your system configuration. Then you can change > the >> settings, you probably need to enter 0x378 for your parallel port, as > well >> as you need to select a single processor and a startup-gel file (the >> gel-file might be found by browsing...at my place it is called >> DSK6211_6711.gel ) >> >> Maybe, that's already everything you need to do, but I'm not sure. > Me, I >> used a different board and processor (C6713 on a D.SignT module), and > so I >> had to perform the following step as well. >> >> * I had to use SDConfig.exe which you can download at their page too. > Their >> I selected 378 as the printer port and at the folder EMU I had to > select the >> XDS510pp_plus with ECP, port speed 0. You can then try to verify your > >> connection to the emulator with this tool too. >> >> >> You seem to own a very old version of Code Composer Studio. I hope >> everything's the same for this version, I only use version 2.21. >> >> :) >> >> Hope this helps! >> >> Yours >> Simone >
