Hi, I am relatively new to this DSP field. I've explained my problem below and please bear with me incase the question or my observation is absurd. Let me explain clearly what am I doing and what is the problem. The filter design was done using Matlab. Once I got the coefficients, I had to take it inside my DSP as a fixed point number. So, I had to find out a scaling factor for that. I found out the scaling factor using the following relation, max(coefft) * 2^s <= 2^(M-1) where max(coefft) is the maximum value of the filter coefficients, s is the scaling factor and M is the number of bits I want my coefficents to be. Since I use signed arithmetic, it becomes M-1. Currently I've designed for M = 16. I am using TMS320F2812, it has 32 bit accumulator and every memory location is 16 bits wide. My input to the filter is 12 bits and the coefficients will be 16 bits. Filter implemented is a second order IIR high pass filter. The DAC which converts the filter output to analog is a 16 bit DAC. Inside the DSP, I make use of the scaled filter coefficients, that is, I take the coefficients inside like this, say, b0 = round(b00*2^s) where b00 is the coefficent as obtained from the Matlab. Then the output is computed using the equation, y(n) = b0x(n) + b1x(n-1) + b2x(n-2) - a1y(n-1) - a2y(n-2) Finally, once I get y(n), I do a right shift of s bits as I've multiplied the coefficents by 2^s when I took them inside the DSP. This right shift of the output always does a "floor"ing operation. This flooring operation works fine if the filter input is positive, works fine in the sense the difference between the expected output and the floored output ( say delta ) is minimum. For negative inputs, delta is too high. (This fact I verified using Matlab also. I gave positive and negative inputs to the filter and observed the expected output and the floored output. ) On the other hand, "ceil"ing of the final filter output( for negative input values) seems to provide a better response, that is delta here again is minimum. But I dunno how to do a ceil operation in my DSP. My code is written completely in assembly language, so it would be better if someone could guide me how to do this in assembly. Any help in this regard is highly appreciated. Thanks. Kalki
Rounding off problems in IIR filters
Started by ●August 9, 2004
Reply by ●August 19, 20042004-08-19
kalki wrote:> Hi, > > I am relatively new to this DSP field. I've explained my problem below > and please bear with me incase the question or my observation is > absurd.Not absurd, but common enough for dealing with it to be a standard technique, and for DSP chips to have hardware that facilitates the solution. ...> Any help in this regard is highly appreciated. Thanks.Are you familiar with what is known as Q format? You need to be. The bits in your computers can represent integers and text characters. They can also represent fractions. Q format does that. There are integer multiply and fractional multiply instructions. They use the same multiplier hardware, but return different parts of the double-precision result. From Mathworks: http://www.mathworks.com/access/helpdesk/help/toolbox/tic2000/2using_5.html From Randy Yates: http://home.earthlink.net/~yatescr/fp.pdf ... Familiarize yourself with one or both and find your processor's support for fixed-point (or whatever it's called) operations. The way to do what you want may then become clear. If it doesn't, you will at least have the vocabulary you need to understand an answer you get here. Jerry -- ... the worst possible design that just meets the specification - almost a definition of practical engineering. .. Chris Bore ������������������������������������������������������������������������
