For starters, pardon my simplicity. That said, given - an array of
sample data such that: data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. };
If I ran an FFT on that via matlab - so now:
a = [0+0i 1+0i 2+0i, 3+0i]
b= fft( a );
The result:
6.000
-2.000 - 2.000i
-2.000
-2.000 + 2.00i
I'm going through a matlab couse and the individual who's teaching the
course happens to be fairly acclimated with image/signal processing.
At issue. Prior to executing the test via matlab - he was able to give
the answer in advance. Obviously I suspect he's done this a million
times utilizing I suspect this same example. I was intrigued though
that and asked myself is that possible? i.e Give the data points
above, could I obtain the result - in my head - if you will.
I realized quickly I could get - the first line -
6.000 + 0i by simply summing the real and imaginary components.
The second third and fourth lines I'm not seeing withouth diving into
the formula ( though I haven't done this yet ).
The question. For the simple data set ( and perhaps more compilcated )
shown can I literally look at the data and obtain the results ( knowing
the formula of course ) withouth much pen and paper?
Of course I could ask the individual but it's more of a curiosity
question for someone who's just staring to dive into this DSP business
heavily.
FFT computation
Started by ●April 13, 2006
Reply by ●April 13, 20062006-04-13
> >For starters, pardon my simplicity. That said, given - an array of >sample data such that: data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; > >If I ran an FFT on that via matlab - so now: > a = [0+0i 1+0i 2+0i, 3+0i] > b= fft( a ); > >The result: > 6.000 > -2.000 - 2.000i > -2.000 > -2.000 + 2.00i > >I'm going through a matlab couse and the individual who's teaching the >course happens to be fairly acclimated with image/signal processing. >At issue. Prior to executing the test via matlab - he was able to give >the answer in advance. Obviously I suspect he's done this a million >times utilizing I suspect this same example. I was intrigued though >that and asked myself is that possible? i.e Give the data points >above, could I obtain the result - in my head - if you will. > >I realized quickly I could get - the first line - > 6.000 + 0i by simply summing the real and imaginary components. > >The second third and fourth lines I'm not seeing withouth diving into >the formula ( though I haven't done this yet ). >The question. For the simple data set ( and perhaps more compilcated ) >shown can I literally look at the data and obtain the results ( knowing >the formula of course ) withouth much pen and paper? > >Of course I could ask the individual but it's more of a curiosity >question for someone who's just staring to dive into this DSP business >heavily. >Do you know the FFT algorithm? If so, for the sequence given by you, you can calculate a 4 point FFT in mind. Add everything for the first term. Add odd terms and subtract even terms to get the third one. The other two involves complex number calculations. It all depends on how fast you can add and subtract numbers. Actually, I never tried computing FFT in mind. You need not have to compute FFT in mind to be a DSP enthusiast. - Krishna
krishna_sun82 wrote:> > Do you know the FFT algorithm?Workign through some basics in a course here once again :) - will get there soon.> If so, for the sequence given by you, you > can calculate a 4 point FFT in mind. Add everything for the first term. > Add odd terms and subtract even terms to get the third one. The other two > involves complex number calculations. It all depends on how fast you can > add and subtract numbers.Lets see something here: I add the real and imaginaries for the first set of values: Real: 0 + 1 + 2 + 3 = 6; Imag: 0 + 0 + 0 + 0 = 0i; The second set of values... From the sound of it ( based on your reply ), I could do: Real : 1 + 3 ( odd ) - 2 = ( 4 - 2 ) = 2 ( I suspect I need to do this backwards to get the minus 2 ) Imaginary : ? The third set of value: ? Fourth set ?> > Actually, I never tried computing FFT in mind. You need not have to > compute FFT in mind to be a DSP enthusiast.Understood.. I was just trying to do this just to get a feel for it if you will
My mental arithmetic is notoriously bad, and I don't use MATLAB, but your data just tells you that you have a sum of three sine waves (OK, complex exponentials..) of amplitudes 1, 2 and 3 respectively at frequencies 1, 2 and 3. So you only need to know trigonometry, and the angles involved come out easily at multiples of pi/2 so the sine values are readily known. The FT coefficients in your data set are just telling you the amplitude and phase of sine wave components. Granted, these are expressed as complex numbers but still each is just: cos(2.pi.k.p/N) + j.sin(2.pi.k.p/N) where k is the coefficient's index, p is the index of the transformed rsult, and N is the number of coefficients. For a 4-point FT this is: cos(pi.k/2) + j.sin(pi.k/2) Since your imaginary parts are all zero, the phase of each sine wave is the same. So to calculate the FT you just need to add four of these together based on the given values. You need to calculate the sum of these sine waves at times 0, 1, 2, 3 and you are done. It helps that (pi.0/2) = 0, (pi.1/2) = pi/2, (pi.3/2) = 3.pi/2 so the sine values are known. I probably mae some mistaked in there somewhere, but when I last did this (25 years ago) it seemed easy. Chris ================= Chris Bore www.bores.com
Chris Bore wrote:> My mental arithmetic is notoriously bad, and I don't use MATLAB, but > your data just tells you that you have a sum of three sine waves (OK, > complex exponentials..) ...Chris, To you mean that because of the (nearly) formal identity of the direct and inverse transforms, one can construe the time samples as frequencies and obtain correct results? I think that's clever enough to have been made explicit. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 13 Apr 2006 05:41:54 -0700, forums_mp@hotmail.com wrote:> >For starters, pardon my simplicity. That said, given - an array of >sample data such that: data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; > >If I ran an FFT on that via matlab - so now: > a = [0+0i 1+0i 2+0i, 3+0i] > b= fft( a ); > >The result: > 6.000 > -2.000 - 2.000i > -2.000 > -2.000 + 2.00i > >I'm going through a matlab couse and the individual who's teaching the >course happens to be fairly acclimated with image/signal processing. >At issue. Prior to executing the test via matlab - he was able to give >the answer in advance. Obviously I suspect he's done this a million >times utilizing I suspect this same example. I was intrigued though >that and asked myself is that possible? i.e Give the data points >above, could I obtain the result - in my head - if you will. > >I realized quickly I could get - the first line - > 6.000 + 0i by simply summing the real and imaginary components. > >The second third and fourth lines I'm not seeing withouth diving into >the formula ( though I haven't done this yet ). >The question. For the simple data set ( and perhaps more compilcated ) >shown can I literally look at the data and obtain the results ( knowing >the formula of course ) withouth much pen and paper? > >Of course I could ask the individual but it's more of a curiosity >question for someone who's just staring to dive into this DSP business >heavily.Hi, If I remember correctly, a four-point DFT requires no multiplications. So if you memorize the simple 4-pt DFT algorithm, you could compute a 4-pt DFT in your head. I also have this vague recollection that you can compute the magnitudes-squared for an 8-pt DFT with no multiplications. Don't take my word for any of this. As Ronny Reagan would say, "Trust, but verify." [-Rick-]
On 13 Apr 2006 05:41:54 -0700, forums_mp@hotmail.com wrote: Hi, I think I screwed up in my last post. I think you can compute DFT magnitudes (not magnitudes-squared) for an 8-pt DFT using no multiplications. Again, check this for yourself. [-Rick-]
Rick Lyons wrote:> Hi, > If I remember correctly, a four-point DFT > requires no multiplications. > So if you memorize the simple 4-pt DFT > algorithm, you could compute a 4-pt > DFT in your head. > > I also have this vague recollection that you can > compute the magnitudes-squared for an 8-pt > DFT with no multiplications. > > Don't take my word for any of this. > As Ronny Reagan would say, "Trust, but verify." > > [-Rick-]Yes, I'm in the process of trying to get a good grasp on all this. I think part of the problem surrounds the fact that I'm running FFT using two sets of programs and comparing the results to Matlab. So I run an FFT on the data set data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; Program 1. (6,0) (-2,-2) (-2,0) (-2,2) Program 2 6 0 -2 -2 -2 0 -2 2 Matlab states the same. So all three match. So I run an FFT on the results i.e 6, 0, -2, -2, -2, 0, -2 , 2 and the result from program 1 Program 1 (0,0) (12,-4.66966e-016) (8,0) (4,4.66966e-016) Program 2 0 0 12 0 8 0 4 0 The results from Matlab match that of Program 2. I begin to ask myself. How could the imaginaries be zero given the data set - 6, 0, -2, -2, -2, 0, -2 , 2. Doesn't make sense to me.. I'll need to delve into the math because in my mind program 2 and matlab ( i didn't say that too load ) have accuracy issues.
Nope. An unscaled 8-point DFT requires at least 4 real multiplications. In general, the absolute minimum number of irrational real multiplications for a complex-input DFT of size N = 2^m has been proved to be 4*N - 2*m^2 - 2*m - 4. (The algorithms that achieve this minimum are, unfortunately, impractical for large N because the number of additions explodes.) Cordially, Steven G. Johnson
