R.G. Stockwell wrote:> <forums_mp@hotmail.com> wrote in message[..]> > The question. For the simple data set ( and perhaps more compilcated ) > > shown can I literally look at the data and obtain the results ( knowing > > the formula of course ) withouth much pen and paper? > > You're adoing a 4 point fft of a real valued time series, with your array > "a" above. > So yes, it is really easy. Just write out on a piece of paper > the transformation matrix for a N=4 DFT. Assume the time series > is [A,B,C,D] > > First of all, the (zeroth point) DC value is just the total of the points > (as you point out). > > The first point is the first harmonic, which is [A - C, B-D] > > Second point is the nyquist point (since N is even, you know it > has a zero imaginary part). The real part is A -B +C -D > > The third and final point is the symmetric reflection (i.e. with phase flip) > of the first point. (A-C, -B + D). > > So you have the result in the form (real,imag) > A+B+C+D, 0 > A-C, B-D > A-B+C-D, 0 > A-C, D-BIncredible.. Thanks.
FFT computation
Started by ●April 13, 2006
Reply by ●April 13, 20062006-04-13
stev...@alum.mit.edu wrote:> If your FFT is unnormalized, then you will probably see Inf because > each unnormalized FFT of length N increases the L2 norm (the rms > magnitude) of the data by sqrt(N)...and sqrt(8)^1000 overflows double > precision. Most FFT routines, including Matlab's, use an unnormalized > forward transform.I see...> > If you normalize the FFT by 1/sqrt(N), then it is a unitary > (norm-preserving) operation, and repeatedly FFTing the array will > simply oscillate between the input, its DFT, the input in reverse > order, and the DFT in reverse order (with small deviations due to the > finite precision). e.g. in Matlab if you do fft(fft(x))/length(x) you > get x in reverse order (except for the first element). This can be > proved easily from the DFT definition.I'll try that in a few .. will have more questions I'm sure. [...]> In general, you compare it to an FFT computed in greater precision. > What input data you use and how you do the comparison (e.g. what norm) > depends somewhat on the application. The method used for the FFTW > accuracy graphs is described at: > http://www.fftw.org/accuracy/method.html > and some references can be found at > http://www.fftw.org/accuracy/comments.htmlIndeed. I've got print -outs here I'm perusing, trying to get my head around the approach and the various numbers.
Reply by ●April 14, 20062006-04-14
forums_mp@hotmail.com wrote: ...> Indeed. I did a forward, then another forward. I was just trying to > understand the _accuracy_ if you will. I asked myself. If I did a > >>1000 forwards FFTs on 8 samples at what point do I see a QNAN or IND or .. ? The next question then was why? > > I dont think I can answer the why yet but .. just learning the _hard_ > way right now. Beyond the theory in the texts, playing with software > and matlab helps me envision things alot better....> This boils down to - for me - whose more accurate. ...You aren't seeing the accuracy. You're seeing how many significant figures the print routine was set to show. A number like -4.66966e-016, displayed to 12 significant figures, will print as '0'. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●April 15, 20062006-04-15
> >krishna_sun82 wrote: > >> >> Do you know the FFT algorithm? >Workign through some basics in a course here once again :) - will get >there soon. > >> If so, for the sequence given by you, you >> can calculate a 4 point FFT in mind. Add everything for the firstterm.>> Add odd terms and subtract even terms to get the third one. The othertwo>> involves complex number calculations. It all depends on how fast youcan>> add and subtract numbers. > >Lets see something here: >I add the real and imaginaries for the first set of values: > Real: 0 + 1 + 2 + 3 = 6; > Imag: 0 + 0 + 0 + 0 = 0i; > >The second set of values... From the sound of it ( based on your reply >), I could do: > Real : 1 + 3 ( odd ) - 2 = ( 4 - 2 ) = 2 ( I suspect I need to do >this backwards to get the minus 2 ) > Imaginary : ?The thing you did is the calculation for the third term. I did not talk about second and fourth. And when I said that you have add odd and subtract even, I meant zero based indexing in time domain. Sorry for that confusion.> >The third set of value: > ? >Fourth set > ? > >>For a 4pt FFT, just given terms, treating them as row matrix and multiply with the following 4 x 4 1 1 1 1 1 -j -1 j 1 -1 1 -1 1 j -1 -j You will get the result as a column matrix. - Krishna
