On 13 Apr 2006 12:43:04 -0700, forums_mp@hotmail.com wrote:> >Rick Lyons wrote: >> Hi, >> If I remember correctly, a four-point DFT >> requires no multiplications. >> So if you memorize the simple 4-pt DFT >> algorithm, you could compute a 4-pt >> DFT in your head. >> >> I also have this vague recollection that you can >> compute the magnitudes-squared for an 8-pt >> DFT with no multiplications. >> >> Don't take my word for any of this. >> As Ronny Reagan would say, "Trust, but verify." >> >> [-Rick-] > >Yes, I'm in the process of trying to get a good grasp on all this. I >think part of the problem surrounds the fact that I'm running FFT using >two sets of programs and comparing the results to Matlab. So I run an >FFT on the data set > data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; > >Program 1. > >(6,0) >(-2,-2) >(-2,0) >(-2,2) > >Program 2 >6 >0 >-2 >-2 >-2 >0 >-2 >2 > >Matlab states the same. >So all three match. > >So I run an FFT on the results i.e 6, 0, -2, -2, -2, 0, -2 , 2 and the >result from program 1 > >Program 1 >(0,0) >(12,-4.66966e-016) >(8,0) >(4,4.66966e-016) > >Program 2 >0 >0 >12 >0 >8 >0 >4 >0 > >The results from Matlab match that of Program 2. > >I begin to ask myself. How could the imaginaries be zero given the >data set - 6, 0, -2, -2, -2, 0, -2 , 2. Doesn't make sense to me.. >I'll need to delve into the math because in my mind program 2 and >matlab ( i didn't say that too load ) have accuracy issues.Wait wait. Now you have two issues to deal with here. (1) Are your FFT results "scrambled" in order? (That's the "bit reversal" property of radix-2 FFTs.) Make sure you account for that. (2) It looks like you performed a forward FFT, and then performed another forward FFT instead of an inverse FFT. (Although I'm not exactly sure what you're trying to accomplish.) In any case, if a sequence has symmetric real parts and antisymmetric imaginary parts, then the FFT (or inverse FFT) will result in a sequence that will have zero-valued imaginary parts. (Do a Google search "hermitian symmetry") Values like 4.66966e-016 are interpretted as zero because that super small value is a result of computational errors. [-Rick-]
FFT computation
Started by ●April 13, 2006
Reply by ●April 13, 20062006-04-13
On Thu, 13 Apr 2006 19:22:45 GMT, R.Lyons@_BOGUS_ieee.org (Rick Lyons) wrote:>On 13 Apr 2006 05:41:54 -0700, forums_mp@hotmail.com wrote: > > >Hi, > I think I screwed up in my last post. > >I think you can compute DFT magnitudes >(not magnitudes-squared) for an 8-pt >DFT using no multiplications. > >Again, check this for yourself. >Excuse me while I struggle to remove two separate feet from my mouth. I no longer believe that you can compute DFT magnitudes for an 8-pt DFT using no multiplications. [-Rick-]
forums_mp@hotmail.com wrote:> Rick Lyons wrote: > >>Hi, >> If I remember correctly, a four-point DFT >>requires no multiplications. >>So if you memorize the simple 4-pt DFT >>algorithm, you could compute a 4-pt >>DFT in your head. >> >>I also have this vague recollection that you can >>compute the magnitudes-squared for an 8-pt >>DFT with no multiplications. >> >>Don't take my word for any of this. >>As Ronny Reagan would say, "Trust, but verify." >> >>[-Rick-] > > > Yes, I'm in the process of trying to get a good grasp on all this. I > think part of the problem surrounds the fact that I'm running FFT using > two sets of programs and comparing the results to Matlab. So I run an > FFT on the data set > data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; > > Program 1. > > (6,0) > (-2,-2) > (-2,0) > (-2,2) > > Program 2 > 6 > 0 > -2 > -2 > -2 > 0 > -2 > 2 > > Matlab states the same. > So all three match. > > So I run an FFT on the results i.e 6, 0, -2, -2, -2, 0, -2 , 2 and the > result from program 1 > > Program 1 > (0,0) > (12,-4.66966e-016) > (8,0) > (4,4.66966e-016) > > Program 2 > 0 > 0 > 12 > 0 > 8 > 0 > 4 > 0 > > The results from Matlab match that of Program 2. > > I begin to ask myself. How could the imaginaries be zero given the > data set - 6, 0, -2, -2, -2, 0, -2 , 2. Doesn't make sense to me.. > I'll need to delve into the math because in my mind program 2 and > matlab ( i didn't say that too load ) have accuracy issues.Ask yourself if you would see the difference between graphs of (12,0) and (12,-4.66966e-016) if each unit square were a kilometer on a side. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
stevenj@alum.mit.edu wrote:> Nope. An unscaled 8-point DFT requires at least 4 real > multiplications. > > In general, the absolute minimum number of irrational real > multiplications for a complex-input DFT of size N = 2^m has been proved > to be 4*N - 2*m^2 - 2*m - 4. (The algorithms that achieve this minimum > are, unfortunately, impractical for large N because the number of > additions explodes.)So 20 irrational real multiplications for an m of 4. A factor of five difference. Wow!! Where is this proof so I can read up on some of this stuff?
Rick Lyons wrote:> >So I run an FFT on the results i.e 6, 0, -2, -2, -2, 0, -2 , 2 and the > >result from program 1 > > > >Program 1 > >(0,0) > >(12,-4.66966e-016) > >(8,0) > >(4,4.66966e-016) > > > >Program 2 > >0 > >0 > >12 > >0 > >8 > >0 > >4 > >0 > > > >The results from Matlab match that of Program 2. > > > >I begin to ask myself. How could the imaginaries be zero given the > >data set - 6, 0, -2, -2, -2, 0, -2 , 2. Doesn't make sense to me.. > >I'll need to delve into the math because in my mind program 2 and > >matlab ( i didn't say that too load ) have accuracy issues. > > Wait wait. > Now you have two issues to deal with here. > > (1) Are your FFT results "scrambled" in order? > (That's the "bit reversal" property of > radix-2 FFTs.) Make sure you account for that.Scrambled? For a data set of R I -6 0 -2 -2 -2 0 -2 2 Matlab tells me I should get. Matlab of course 'ignores' the 0 imaginaries. 0 0 12 0 8 0 4 0> > (2) It looks like you performed a forward > FFT, and then performed another forward > FFT instead of an inverse FFT. (Although > I'm not exactly sure what you're trying to > accomplish.)Indeed. I did a forward, then another forward. I was just trying to understand the _accuracy_ if you will. I asked myself. If I did a>1000 forwards FFTs on 8 samples at what point do I see a QNAN or IND or .. ? The next question then was why?I dont think I can answer the why yet but .. just learning the _hard_ way right now. Beyond the theory in the texts, playing with software and matlab helps me envision things alot better.> In any case, if a sequence has symmetric real > parts and antisymmetric imaginary parts, then > the FFT (or inverse FFT) will result in a > sequence that will have zero-valued imaginary parts. > > (Do a Google search "hermitian symmetry")Will do.> > Values like 4.66966e-016 are interpretted > as zero because that super small value is a > result of computational errors.This boils down to - for me - whose more accurate. In fact, I stumbled across fftw and one of the key benchmarks from the numbers shown is 'accuracy'. I haven't downloaded the code from site yet but I'm curious to get a better feel for how one measures the _accuracy_ of FFTs/IFFTs.
[..]> Ask yourself if you would see the difference between graphs of (12,0) > and (12,-4.66966e-016) if each unit square were a kilometer on a side.Makes sense, but as mentioned in a response to Rick. I think I might have gotten side tracked with 'accuracy'. This after perusing a few texts/the web, in addition to observing fftw's benchmarks highlighting the importance (my take on it) of accuracy. In the end you're correct. Will I _see the difference_? No. Does that mean one result is more accurate that the other.. ? Being a newbie. Not sure to make of that :)
<forums_mp@hotmail.com> wrote in message news:1144932114.957314.185830@z34g2000cwc.googlegroups.com...> > For starters, pardon my simplicity. That said, given - an array of > sample data such that: data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. }; > > If I ran an FFT on that via matlab - so now: > a = [0+0i 1+0i 2+0i, 3+0i] > b= fft( a ); > > The result: > 6.000 > -2.000 - 2.000i > -2.000 > -2.000 + 2.00i...> The question. For the simple data set ( and perhaps more compilcated ) > shown can I literally look at the data and obtain the results ( knowing > the formula of course ) withouth much pen and paper?You're adoing a 4 point fft of a real valued time series, with your array "a" above. So yes, it is really easy. Just write out on a piece of paper the transformation matrix for a N=4 DFT. Assume the time series is [A,B,C,D] First of all, the (zeroth point) DC value is just the total of the points (as you point out). The first point is the first harmonic, which is [A - C, B-D] Second point is the nyquist point (since N is even, you know it has a zero imaginary part). The real part is A -B +C -D The third and final point is the symmetric reflection (i.e. with phase flip) of the first point. (A-C, -B + D). So you have the result in the form (real,imag) A+B+C+D, 0 A-C, B-D A-B+C-D, 0 A-C, D-B or putting in your values of a=0,b=1,c=2,d=3 6,0 -2,-2 -2,0 -2,2 Cheers, bob
forums_mp@hotmail.com wrote:> For starters, pardon my simplicity. That said, given - an array of > sample data such that: data [ 8 ] = { 0., 0., 1., 0., 2., 0., 3., 0. };Is this a sawtooth wave? Whose periodic form is used as an example for DFT and FT spectrums in a few, perhaps many, standard textbooks? All you'd need to guess might be the scale factor (applying Parseval theorem in ones head?) IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
See the introduction of http://fftw.org/newsplit.pdf for references regarding bounds on the number of arithmetic operations required by the DFT. (In particular, for the multiplicative bounds see refs. [16-17].)
forums_mp@hotmail.com wrote:> Indeed. I did a forward, then another forward. I was just trying to > understand the _accuracy_ if you will. I asked myself. If I did a > >1000 forwards FFTs on 8 samples at what point do I see a QNAN or IND or .. ? The next > question then was why?If your FFT is unnormalized, then you will probably see Inf because each unnormalized FFT of length N increases the L2 norm (the rms magnitude) of the data by sqrt(N)...and sqrt(8)^1000 overflows double precision. Most FFT routines, including Matlab's, use an unnormalized forward transform. If you normalize the FFT by 1/sqrt(N), then it is a unitary (norm-preserving) operation, and repeatedly FFTing the array will simply oscillate between the input, its DFT, the input in reverse order, and the DFT in reverse order (with small deviations due to the finite precision). e.g. in Matlab if you do fft(fft(x))/length(x) you get x in reverse order (except for the first element). This can be proved easily from the DFT definition.> This boils down to - for me - whose more accurate. In fact, I stumbled > across fftw and one of the key benchmarks from the numbers shown is > 'accuracy'. I haven't downloaded the code from site yet but I'm > curious to get a better feel for how one measures the _accuracy_ of > FFTs/IFFTs.In general, you compare it to an FFT computed in greater precision. What input data you use and how you do the comparison (e.g. what norm) depends somewhat on the application. The method used for the FFTW accuracy graphs is described at: http://www.fftw.org/accuracy/method.html and some references can be found at http://www.fftw.org/accuracy/comments.html Cordially, Steven G. Johnson
