On Oct 17, 12:28 pm, "Gery" <g...@ddd.com> wrote:> I have an idea. > > Could I do it like this? If I sample 100 samples at say 10 kHz, multiply > them with a window function and then zero pad them with 900 zeros. Then I > make an FFT of the band in interest. I repeat this 10 times and accumulate > the bins (100 bins). Would I get a frequenzy resolution of 10 Hz with this > method?If you repeat non-zero-padded FFTs on successive windows of data, and use phase vocoder analysis instead of just accumulating, you might be able to get a much higher frequency resolution of any well seperated spectra. You won't be able to resolve multiple spectra in one bin using phase vocoder analysis, but you might be able to resolve a far more precise (sub-bin resolution) frequency of a sinusoid spaced several bins apart from interfering signals and surrounded by a low enough noise floor, by using sequences of shorter DFT/FFTs this way. IMHO. YMMV. -- Ron N. http://www.nicholson.com/rhn
How to make FFT when having small amount of RAM?
Started by ●October 17, 2006
Reply by ●October 17, 20062006-10-17
Viognier wrote:> Another technique, called the Chirp Z transform, may be of use. The > technique can compute the z transform of N points on the unit circle. > Unlilke the FFT, the N points can be any number and can reside at any > interval in the band.No, the chirp-z algorithm (Bluestein's FFT algorithm) requires a buffer of length >= 2N-1, so it requires *more* storage than doing the full FFT (which only requires a buffer of length N to store the input and output). Steven
Eric Jacobsen wrote:> Depending on how many output samples (bins) you want, you could > compute the DFT for just the bins of interest. You'll need an input > buffer of length N, and an output buffer of only the length needed.Actually, you don't need an input buffer at all, which is the whole advantage of this technique. Since the DFT/DTFT formula (or Goertzel and similar) requires only a single sequential pass through the input, you can compute it on the fly and discard each input after you have used it. Steven
Reply by ●October 18, 20062006-10-18
stevenj@alum.mit.edu wrote:> > No, the chirp-z algorithm (Bluestein's FFT algorithm) requires a buffer > of length >= 2N-1, so it requires *more* storage than doing the full > FFT (which only requires a buffer of length N to store the input and > output). > > StevenPerhaps, but with the Chirp Z algorithm I can pick N to be just the quantity needed (even a prime number) rather than some power of 2 as is required by the FFT. I also have more control of the resolution of the frequency spacing of these N points with the CZT. Again, If you don't need to do a full FFT, a CZT may be of use.
Viognier wrote:> Perhaps, but with the Chirp Z algorithm I can pick N to be just the > quantity needed (even a prime number) rather than some power of 2 as is > required by the FFT.FFTs don't require the size to be a power of two; this is a scurrilous rumor. Many FFT algorithms, most notably the ubiquitous Cooley-Tukey algorithm, work for any composite size (although many FFT *implementations* are limited to powers of two), and a couple of algorithms (Bluestein's and Rader's) work for prime sizes (but are slower and take more memory). If you use e.g. FFTW (www.fftw.org) or the Intel MKL, it will automatically use a composite-size algorithm when possible and a prime-size algorithm when not.> I also have more control of the resolution of the > frequency spacing of these N points with the CZT. Again, If you don't > need to do a full FFT, a CZT may be of use.Careful, the CZT doesn't actually give you more "resolution"...it only allows you to *interpolate* a portion of the spectrum, which is not the same thing. And the CZT is *not* faster that a full FFT if you only need a few of the frequency bins but with the same spacing. Even if you want 2-3 times the "resolution" it would be faster to do a full FFT with zero padding. (A CZT requires two FFTs of length >= 2N-1, or three FFTs if you include initialization time.) And, in any case, as I pointed out, the original poster asked for a way to compute a few frequency bins with *less memory* than a full FFT, and the CZT will certainly not do that. The only way to save memory is to use a method that does not require you to store the input, such as applying the DTFT formula directly. Steven
Reply by ●October 19, 20062006-10-19
Thank you all for your answers. Now I have more informatin about different methods. I think the zoom-FFT sounds like the most apropriate for my project if it manages to run the low pass filter at the sampel rate. Or else I must add a RAM memory to the microcontroller to buffer my sampels. Thank you all. <stevenj@alum.mit.edu> wrote in message news:1161184757.717044.53510@k70g2000cwa.googlegroups.com...> Viognier wrote: >> Perhaps, but with the Chirp Z algorithm I can pick N to be just the >> quantity needed (even a prime number) rather than some power of 2 as is >> required by the FFT. > > FFTs don't require the size to be a power of two; this is a scurrilous > rumor. Many FFT algorithms, most notably the ubiquitous Cooley-Tukey > algorithm, work for any composite size (although many FFT > *implementations* are limited to powers of two), and a couple of > algorithms (Bluestein's and Rader's) work for prime sizes (but are > slower and take more memory). If you use e.g. FFTW (www.fftw.org) or > the Intel MKL, it will automatically use a composite-size algorithm > when possible and a prime-size algorithm when not. > >> I also have more control of the resolution of the >> frequency spacing of these N points with the CZT. Again, If you don't >> need to do a full FFT, a CZT may be of use. > > Careful, the CZT doesn't actually give you more "resolution"...it only > allows you to *interpolate* a portion of the spectrum, which is not the > same thing. And the CZT is *not* faster that a full FFT if you only > need a few of the frequency bins but with the same spacing. Even if > you want 2-3 times the "resolution" it would be faster to do a full FFT > with zero padding. (A CZT requires two FFTs of length >= 2N-1, or > three FFTs if you include initialization time.) > > And, in any case, as I pointed out, the original poster asked for a way > to compute a few frequency bins with *less memory* than a full FFT, and > the CZT will certainly not do that. The only way to save memory is to > use a method that does not require you to store the input, such as > applying the DTFT formula directly. > > Steven >
