On Fri, 20 Apr 2007 13:23:26 -0500, "philgo" <philgo@gmail.com> wrote:>Let me try to rephrase the question. > >In traditional beam-forming, we are always talking about angles, angle of >arrival, angle of departure, beam pattern pointing to a certain angle, >etc. >However, when we talk about the MRC, the concept of angle disappears and >what we cared is only maximizing the SNR (or some other related metric). > >Why we do not see/talk about the angles any more in MRC? I try to answer >this question. Please share your comments and criticism.I'll share my intuitive perspective and see whether it helps anything: Beamforming requires coherence (i.e., phase alignment) between the inputs to form and steer the beam as desired. MRC only adjusts the inputs with a scale factor, so no beamforming is taking place. That's good because, as you've stated, each antenna may be collecting energy from different reflected directions, so forming a coherent beam may reduce the total amount of energy collected and hurt rather than help. Beamforming discriminates the direction in which energy is collected by adjusting relative phases. Some energy may be rejected in the process. MRC uses all of the energy collected by all antennas combined to maximize SNR. They're two very different techniques, but each have their purpose and place. I like the simplicity and elegance of MRC, though. The fact that it's more or less optimal in some conditions is just icing on the cake. ;) Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Difference between maximum ratio combing and adaptive beamforming
Started by ●March 22, 2007
Reply by ●April 21, 20072007-04-21
