Hi, Can some one please tell me how (32,10) subcode of 2nd order reed muller code is derived. I need to understand the coding theory behind this code as its used in Layer 1 UMTS 3GPP 25.212 specification to encode TFCI. What are its special properties and why this code was choosen for TFCI encoding. It would be of great help if someone can give me technical papers published on the same. Regards Kiran _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
(32,10) 2nd order reed muller code generation
Started by ●April 3, 2007
Reply by ●April 4, 20072007-04-04
>Hi, > >Can some one please tell me how (32,10) subcode of 2nd order reed muller >code is derived. I need to understand the coding theory behind this code >as its used in Layer 1 UMTS 3GPP 25.212 specification to encode TFCI.What>are its special properties and why this code was choosen for TFCIencoding.>It would be of great help if someone can give me technical paperspublished>on the same. > >Regards > >Kiran > > > > >_____________________________________ >Do you know a company who employs DSP engineers? >Is it already listed at http://dsprelated.com/employers.php ? >Kiran, This is a good document to get you started. http://www.3gpp.org/ftp/tsg_ran/WG1_RL1/TSGR1_06/Docs/Pdfs/r1-99913.pdf It talks about the basis of using FHT correlators for decoding the bi-orthogonal first order RM codes. And then how to update the decoding algorithm for this modified RM code. It also talks about the weight distribution of the code which has all the information on the coding gain. To play with more error correcting codes and the FHT algorithm you can go to http://signals.thingsconnect.com/ Hope this helps Sele _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
