Hello, I'm a computer engineering student and I'm new to the world of DSPs. I've decided for a major project to design a digital audio effects proccesor, so that I can plug my guitar into it and have it add some effect in real-time and play it out. I'm having some trouble understanding how and where to do the actual processing of the audio signal. So far I've just been doing lots of reading, and using the example code dsk_app.c below, I can have my audio signal pass through from line input to line output. I have a couple algorithms that I've created using Matlab for delay and distortion, I just don't know how to implement it within this code or if that's possible, though it seems to me like a template of sorts for this reason. Any information that anyone could provide me with on this is extremely helpful and appreciated, as I have to get an understanding of this in a timely manner for school deadlines. Thanks! -Fons /* * Copyright 2003 by Spectrum Digital Incorporated. * All rights reserved. Property of Spectrum Digital Incorporated. */ /* * ======== dsk_app.c ======== * * Version 1.00 * * This example digitally processes audio data from the line input on the * AIC23 codec and plays the result on the line output. It uses the McBSP * and EDMA to efficiently handle the data transfer without intervention from * the DSP. * * Data transfer * * Audio data is transferred back and forth from the codec through McBSP2, * a bidirectional serial port. The EDMA is configured to take every 16-bit * signed audio sample arriving on McBSP1 and store it in a buffer in memory * until it can be processed. Once it has been processed, the EDMA * controller sends the data back to McBSP1 for transmission. * * A second serial port, McBSP0 is used to control/configure the AIC23. The * codec receives serial commands through McBSP0 that set configuration * parameters such as volume, sample rate and data format. * * In addition to basic EDMA transfers, this example uses 2 special * techniques to make audio processing more convenient and efficient: * * 1) Ping-pong data buffering in memory * 2) Linked EDMA transfers * * Applications with single buffers for receive and transmit data are * very tricky and timing dependent because new data constantly overwrites * the data being transmitted. Ping-pong buffering is a technique where two * buffers (referred to as the PING buffer and the PONG buffer) are used for * a data transfer instead of only one. The EDMA is configured to fill the * PING buffer first, then the PONG buffer. While the PONG buffer is being * filled, the PING buffer can be processed with the knowledge that the * current EDMA transfer won't overwrite it. This example uses ping-pong * buffers on both transmit and receive ends for a total of four buffers. * * The EDMA controller must be configured slightly differently for each * buffer. When a buffer is filled, the EDMA controller generates an * interrupt. The interrupt handler must reload the configuration * for the next buffer before the next audio sample arrives. An EDMA * feature called linked transfers is used to make this event less time * critical. Each configuration is created in advance and the EDMA * controller automatically links to the next configuration when the * current configuration is finished. An interrupt is still generated, * but it serves only to signal the DSP that it can process the data. * The only time constraint is that all the audio data must be processed * before the the active buffer fills up, which is much longer than the * time between audio samples. It is much easier to satisfy real-time * constraints with this implementation. * * Program flow * * When the program is run, the individual DSP/BIOS modules are initialized * as configured in dsk_app.cdb with the DSP/BIOS configuration tool. The * main() function is then called as the main user thread. In this example * main() performs application initialization and starts the EDMA data * transfers. When main exits, control passes back entirely to DSP/BIOS * which services any interrupts or threads on an as-needed basis. * * The edmaHwi() interrupt service routine is called when a buffer has been * filled. It contains a state variable named pingOrPong that indicates * whether the buffer is a PING or PONG buffer. dmaHwi switches the buffer * state to the opposite buffer and calls the SWI thread processBuffer to * process the audio data. * * Other Functions * * The example includes a few other functions that are executed in the * background as examples of the multitasking that DSP/BIOS is capable of: * * 1) blinkLED() toggles LED #0 every 500ms if DIP switch #0 is depressed. * It is a periodic thread with a period of 500 ticks. * * 2) load() simulates a 20-25% dummy load if DIP switch #1 is depressed. * It represents other computation that may need to be done. It is a * periodic thread with a period of 10ms. * * Please see the 6713 DSK help file under Software/Examples for more * detailed information on this example. */ /* * DSP/BIOS is configured using the DSP/BIOS configuration tool. Settings * for this example are stored in a configuration file called dsk_app.cdb. * At compile time, Code Composer will auto-generate DSP/BIOS related files * based on these settings. A header file called dsk_appcfg.h contains the * results of the autogeneration and must be included for proper operation. * The name of the file is taken from dsk_app.cdb and adding cfg.h. */ #include "dsk_appcfg.h" /* * These are include files that support interfaces to BIOS and CSL modules * used by the program. */ #include <std.h> #include <swi.h> #include <log.h> #include <c6x.h> #include <csl.h> #include <csl_edma.h> #include <csl_irq.h> #include <csl_mcbsp.h> #include "echocfg.h" #include "echo.h" /* * The 6713 DSK Board Support Library is divided into several modules, each * of which has its own include file. The file dsk6713.h must be included * in every program that uses the BSL. This example also uses the * DIP, LED and AIC23 modules. */ #include "dsk6713.h" #include "dsk6713_led.h" #include "dsk6713_dip.h" #include "aic23.h" /* Global declarations */ int cancelerLoad = 0; int decoderLoad = 0; int encoderLoad = 0; int echoInFrame = 0; /* current input echo frame number */ int echoOutFrame = 2; /* current output echo frame number */ int encoderFrame = 0; /* current input audio frame number */ int decoderFrame = 0; /* current output audio frame number */ int audioInBuf[AUDIOBUFLEN]; /* audio input data */ int audioOutBuf[AUDIOBUFLEN]; /* audio output data */ int codeInBuf[CODEBUFLEN]; /* encoded input data */ int codeOutBuf[CODEBUFLEN]; /* encoded output data */ /* Function prototypes */ void initIrq(void); void initMcbsp(void); void initEdma(void); void copyData(Int16 *inbuf, Int16 *outbuf, Int16 length); void processBuffer(void); void edmaHwi(void); void echo(int argc, char *argv[]); extern Void ECHO_load(int load); static Void cancelerAlg(int *input, int *output); static Void decoderAlg(int *input, int *output); static Void encoderAlg(int *input, int *output); /* Constants for the buffered ping-pong transfer */ #define BUFFSIZE 1000 #define PING 0 #define PONG 1 /* * Data buffer declarations - the program uses four logical buffers of size * BUFFSIZE, one ping and one pong buffer on both receive and transmit sides. */ Int16 gBufferXmtPing[BUFFSIZE]; // Transmit PING buffer Int16 gBufferXmtPong[BUFFSIZE]; // Transmit PONG buffer Int16 gBufferRcvPing[BUFFSIZE]; // Receive PING buffer Int16 gBufferRcvPong[BUFFSIZE]; // Receive PONG buffer EDMA_Handle hEdmaXmt; // EDMA channel handles EDMA_Handle hEdmaReloadXmtPing; EDMA_Handle hEdmaReloadXmtPong; EDMA_Handle hEdmaRcv; EDMA_Handle hEdmaReloadRcvPing; EDMA_Handle hEdmaReloadRcvPong; MCBSP_Handle hMcbsp1; // McBSP1 (codec data) handle Int16 gXmtChan; // TCC codes (see initEDMA()) Int16 gRcvChan; /* * EDMA Config data structure */ /* Transmit side EDMA configuration */ EDMA_Config gEdmaConfigXmt = { EDMA_FMKS(OPT, PRI, HIGH) | // Priority EDMA_FMKS(OPT, ESIZE, 16BIT) | // Element size EDMA_FMKS(OPT, 2DS, NO) | // 2 dimensional source? EDMA_FMKS(OPT, SUM, INC) | // Src update mode EDMA_FMKS(OPT, 2DD, NO) | // 2 dimensional dest EDMA_FMKS(OPT, DUM, NONE) | // Dest update mode EDMA_FMKS(OPT, TCINT, YES) | // Cause EDMA interrupt? EDMA_FMKS(OPT, TCC, OF(0)) | // Transfer complete code EDMA_FMKS(OPT, LINK, YES) | // Enable link parameters? EDMA_FMKS(OPT, FS, NO), // Use frame sync? (Uint32)&gBufferXmtPing, // Src address EDMA_FMK (CNT, FRMCNT, NULL) | // Frame count EDMA_FMK (CNT, ELECNT, BUFFSIZE), // Element count EDMA_FMKS(DST, DST, OF(0)), // Dest address EDMA_FMKS(IDX, FRMIDX, DEFAULT) | // Frame index value EDMA_FMKS(IDX, ELEIDX, DEFAULT), // Element index value EDMA_FMK (RLD, ELERLD, NULL) | // Reload element EDMA_FMK (RLD, LINK, NULL) // Reload link }; /* Receive side EDMA configuration */ EDMA_Config gEdmaConfigRcv = { EDMA_FMKS(OPT, PRI, HIGH) | // Priority EDMA_FMKS(OPT, ESIZE, 16BIT) | // Element size EDMA_FMKS(OPT, 2DS, NO) | // 2 dimensional source? EDMA_FMKS(OPT, SUM, NONE) | // Src update mode EDMA_FMKS(OPT, 2DD, NO) | // 2 dimensional dest EDMA_FMKS(OPT, DUM, INC) | // Dest update mode EDMA_FMKS(OPT, TCINT, YES) | // Cause EDMA interrupt? EDMA_FMKS(OPT, TCC, OF(0)) | // Transfer complete code EDMA_FMKS(OPT, LINK, YES) | // Enable link parameters? EDMA_FMKS(OPT, FS, NO), // Use frame sync? EDMA_FMKS(SRC, SRC, OF(0)), // Src address EDMA_FMK (CNT, FRMCNT, NULL) | // Frame count EDMA_FMK (CNT, ELECNT, BUFFSIZE), // Element count (Uint32)&gBufferRcvPing, // Dest address EDMA_FMKS(IDX, FRMIDX, DEFAULT) | // Frame index value EDMA_FMKS(IDX, ELEIDX, DEFAULT), // Element index value EDMA_FMK (RLD, ELERLD, NULL) | // Reload element EDMA_FMK (RLD, LINK, NULL) // Reload link }; /* McBSP codec data channel configuration */ static MCBSP_Config mcbspCfg1 = { MCBSP_FMKS(SPCR, FREE, NO) | MCBSP_FMKS(SPCR, SOFT, NO) | MCBSP_FMKS(SPCR, FRST, YES) | MCBSP_FMKS(SPCR, GRST, YES) | MCBSP_FMKS(SPCR, XINTM, XRDY) | MCBSP_FMKS(SPCR, XSYNCERR, NO) | MCBSP_FMKS(SPCR, XRST, YES) | MCBSP_FMKS(SPCR, DLB, OFF) | MCBSP_FMKS(SPCR, RJUST, RZF) | MCBSP_FMKS(SPCR, CLKSTP, DISABLE) | MCBSP_FMKS(SPCR, DXENA, OFF) | MCBSP_FMKS(SPCR, RINTM, RRDY) | MCBSP_FMKS(SPCR, RSYNCERR, NO) | MCBSP_FMKS(SPCR, RRST, YES), MCBSP_FMKS(RCR, RPHASE, SINGLE) | MCBSP_FMKS(RCR, RFRLEN2, DEFAULT) | MCBSP_FMKS(RCR, RWDLEN2, DEFAULT) | MCBSP_FMKS(RCR, RCOMPAND, MSB) | MCBSP_FMKS(RCR, RFIG, NO) | MCBSP_FMKS(RCR, RDATDLY, 0BIT) | MCBSP_FMKS(RCR, RFRLEN1, OF(1)) | MCBSP_FMKS(RCR, RWDLEN1, 16BIT) | MCBSP_FMKS(RCR, RWDREVRS, DISABLE), MCBSP_FMKS(XCR, XPHASE, SINGLE) | MCBSP_FMKS(XCR, XFRLEN2, DEFAULT) | MCBSP_FMKS(XCR, XWDLEN2, DEFAULT) | MCBSP_FMKS(XCR, XCOMPAND, MSB) | MCBSP_FMKS(XCR, XFIG, NO) | MCBSP_FMKS(XCR, XDATDLY, 0BIT) | MCBSP_FMKS(XCR, XFRLEN1, OF(1)) | MCBSP_FMKS(XCR, XWDLEN1, 16BIT) | MCBSP_FMKS(XCR, XWDREVRS, DISABLE), MCBSP_FMKS(SRGR, GSYNC, DEFAULT) | MCBSP_FMKS(SRGR, CLKSP, DEFAULT) | MCBSP_FMKS(SRGR, CLKSM, DEFAULT) | MCBSP_FMKS(SRGR, FSGM, DEFAULT) | MCBSP_FMKS(SRGR, FPER, DEFAULT) | MCBSP_FMKS(SRGR, FWID, DEFAULT) | MCBSP_FMKS(SRGR, CLKGDV, DEFAULT), MCBSP_MCR_DEFAULT, MCBSP_RCER_DEFAULT, MCBSP_XCER_DEFAULT, MCBSP_FMKS(PCR, XIOEN, SP) | MCBSP_FMKS(PCR, RIOEN, SP) | MCBSP_FMKS(PCR, FSXM, EXTERNAL) | MCBSP_FMKS(PCR, FSRM, EXTERNAL) | MCBSP_FMKS(PCR, CLKXM, INPUT) | MCBSP_FMKS(PCR, CLKRM, INPUT) | MCBSP_FMKS(PCR, CLKSSTAT, DEFAULT) | MCBSP_FMKS(PCR, DXSTAT, DEFAULT) | MCBSP_FMKS(PCR, FSXP, ACTIVEHIGH) | MCBSP_FMKS(PCR, FSRP, ACTIVEHIGH) | MCBSP_FMKS(PCR, CLKXP, FALLING) | MCBSP_FMKS(PCR, CLKRP, RISING) }; /* Codec configuration settings */ AIC23_Params config = { 0x0017, // 0 DSK6713_AIC23_LEFTINVOL Left line input channel volume 0x0017, // 1 DSK6713_AIC23_RIGHTINVOL Right line input channel volume 0x00ff, // 2 DSK6713_AIC23_LEFTHPVOL Left channel headphone volume 0x00ff, // 3 DSK6713_AIC23_RIGHTHPVOL Right channel headphone volume 0x0011, // 4 DSK6713_AIC23_ANAPATH Analog audio path control 0x0000, // 5 DSK6713_AIC23_DIGPATH Digital audio path control 0x0000, // 6 DSK6713_AIC23_POWERDOWN Power down control 0x0043, // 7 DSK6713_AIC23_DIGIF Digital audio interface format 0x0001, // 8 DSK6713_AIC23_SAMPLERATE Sample rate control 0x0001 // 9 DSK6713_AIC23_DIGACT Digital interface activation }; /* --------------------------- main() function -------------------------- */ /* * main() - The main user task. Performs application initialization and * starts the data transfer. */ void main() { /* Initialize Board Support Library */ DSK6713_init(); /* Initialize LEDs and DIP switches */ DSK6713_LED_init(); DSK6713_DIP_init(); /* Clear buffers */ memset((void *)gBufferXmtPing, 0, BUFFSIZE * 4 * 2); AIC23_setParams(&config); // Configure the codec initMcbsp(); // Initialize McBSP1 for audio transfers IRQ_globalDisable(); // Disable global interrupts during setup initEdma(); // Initialize the EDMA controller initIrq(); // Initialize interrupts IRQ_globalEnable(); // Re-enable global interrupts } /* ------------------------Helper Functions ----------------------------- */ /* * initMcbsp() - Initialize the McBSP for codec data transfers using the * configuration define at the top of this file. */ void initMcbsp() { /* Open the codec data McBSP */ hMcbsp1 = MCBSP_open(MCBSP_DEV1, MCBSP_OPEN_RESET); /* Configure the codec to match the AIC23 data format */ MCBSP_config(hMcbsp1, &mcbspCfg1); /* Start the McBSP running */ MCBSP_start(hMcbsp1, MCBSP_XMIT_START | MCBSP_RCV_START | MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC, 220); } /* * initIrq() - Initialize and enable the DMA receive interrupt using the CSL. * The interrupt service routine for this interrupt is edmaHwi. */ void initIrq(void) { /* Enable EDMA interrupts to the CPU */ IRQ_clear(IRQ_EVT_EDMAINT); // Clear any pending EDMA interrupts IRQ_enable(IRQ_EVT_EDMAINT); // Enable EDMA interrupt } /* * initEdma() - Initialize the DMA controller. Use linked transfers to * automatically transition from ping to pong and visa-versa. */ void initEdma(void) { /* Configure transmit channel */ hEdmaXmt = EDMA_open(EDMA_CHA_XEVT1, EDMA_OPEN_RESET); // get hEdmaXmt handle and reset channel hEdmaReloadXmtPing = EDMA_allocTable(-1); // get hEdmaReloadXmtPing handle hEdmaReloadXmtPong = EDMA_allocTable(-1); // get hEdmaReloadXmtPong handle gEdmaConfigXmt.dst = MCBSP_getXmtAddr(hMcbsp1); // set the desination address to McBSP1 DXR gXmtChan = EDMA_intAlloc(-1); // get an open TCC gEdmaConfigXmt.opt |= EDMA_FMK(OPT,TCC,gXmtChan); // set TCC to gXmtChan EDMA_config(hEdmaXmt, &gEdmaConfigXmt); // then configure the registers EDMA_config(hEdmaReloadXmtPing, &gEdmaConfigXmt); // and the reload for Ping gEdmaConfigXmt.src = EDMA_SRC_OF(gBufferXmtPong); // change the structure to have a source of Pong EDMA_config(hEdmaReloadXmtPong, &gEdmaConfigXmt); // and configure the reload for Pong EDMA_link(hEdmaXmt,hEdmaReloadXmtPong); // link the regs to Pong EDMA_link(hEdmaReloadXmtPong,hEdmaReloadXmtPing); // link Pong to Ping EDMA_link(hEdmaReloadXmtPing,hEdmaReloadXmtPong); // and link Ping to Pong /* Configure receive channel */ hEdmaRcv = EDMA_open(EDMA_CHA_REVT1, EDMA_OPEN_RESET); // get hEdmaRcv handle and reset channel hEdmaReloadRcvPing = EDMA_allocTable(-1); // get hEdmaReloadRcvPing handle hEdmaReloadRcvPong = EDMA_allocTable(-1); // get hEdmaReloadRcvPong handle gEdmaConfigRcv.src = MCBSP_getRcvAddr(hMcbsp1); // and the desination address to McBSP1 DXR gRcvChan = EDMA_intAlloc(-1); // get an open TCC gEdmaConfigRcv.opt |= EDMA_FMK(OPT,TCC,gRcvChan); // set TCC to gRcvChan EDMA_config(hEdmaRcv, &gEdmaConfigRcv); // then configure the registers EDMA_config(hEdmaReloadRcvPing, &gEdmaConfigRcv); // and the reload for Ping gEdmaConfigRcv.dst = EDMA_DST_OF(gBufferRcvPong); // change the structure to have a destination of Pong EDMA_config(hEdmaReloadRcvPong, &gEdmaConfigRcv); // and configure the reload for Pong EDMA_link(hEdmaRcv,hEdmaReloadRcvPong); // link the regs to Pong EDMA_link(hEdmaReloadRcvPong,hEdmaReloadRcvPing); // link Pong to Ping EDMA_link(hEdmaReloadRcvPing,hEdmaReloadRcvPong); // and link Ping to Pong /* Enable interrupts in the EDMA controller */ EDMA_intClear(gXmtChan); EDMA_intClear(gRcvChan); // clear any possible spurious interrupts EDMA_intEnable(gXmtChan); // enable EDMA interrupts (CIER) EDMA_intEnable(gRcvChan); // enable EDMA interrupts (CIER) EDMA_enableChannel(hEdmaXmt); // enable EDMA channel EDMA_enableChannel(hEdmaRcv); // enable EDMA channel /* Do a dummy write to generate the first McBSP transmit event */ MCBSP_write(hMcbsp1, 0); } /* * copyData() - Copy one buffer with length elements to another. */ void copyData(Int16 *inbuf, Int16 *outbuf, Int16 length) { Int16 i = 0; for (i = 0; i < length; i++) { outbuf[i] = inbuf[i]; } } /* ---------------------- Interrupt Service Routines -------------------- */ /* * edmaHwi() - Interrupt service routine for the DMA transfer. It is * triggered when a complete DMA receive frame has been * transferred. The edmaHwi ISR is inserted into the interrupt * vector table at compile time through a setting in the DSP/BIOS * configuration under Scheduling --> HWI --> HWI_INT8. edmaHwi * uses the DSP/BIOS Dispatcher to save register state and make * sure the ISR co-exists with other DSP/BIOS functions. */ void edmaHwi(void) { static Uint32 pingOrPong = PING; // Ping-pong state variable static Int16 xmtdone = 0, rcvdone = 0; /* Check CIPR to see which transfer completed */ if (EDMA_intTest(gXmtChan)) { EDMA_intClear(gXmtChan); xmtdone = 1; } if (EDMA_intTest(gRcvChan)) { EDMA_intClear(gRcvChan); rcvdone = 1; } /* If both transfers complete, signal processBufferSwi to handle */ if (xmtdone && rcvdone) { if (pingOrPong==PING) { SWI_or(&processBufferSwi, PING); pingOrPong = PONG; } else { SWI_or(&processBufferSwi, PONG); pingOrPong = PING; } rcvdone = 0; xmtdone = 0; } } /* ------------------------------- Threads ------------------------------ */ /* * processBuffer() - Process audio data once it has been received. */ void processBuffer(void) { Uint32 pingPong; /* Get contents of mailbox posted by edmaHwi */ pingPong = SWI_getmbox(); /* Copy data from transmit to receive, could process audio here */ if (pingPong == PING) { /* Toggle LED #3 as a visual cue */ DSK6713_LED_toggle(3); /* Copy receive PING buffer to transmit PING buffer */ copyData(gBufferRcvPing, gBufferXmtPing, BUFFSIZE); } else { /* Toggle LED #2 as a visual cue */ DSK6713_LED_toggle(2); /* Copy receive PONG buffer to transmit PONG buffer */ copyData(gBufferRcvPong, gBufferXmtPong, BUFFSIZE); } } /* * blinkLED() - Periodic thread (PRD) that toggles LED #0 every 500ms if * DIP switch #0 is depressed. The thread is configured * in the DSP/BIOS configuration tool under Scheduling --> * PRD --> PRD_blinkLed. The period is set there at 500 * ticks, with each tick corresponding to 1ms in real+- * time. */ void blinkLED(void) { /* Toggle LED #0 if DIP switch #0 is off (depressed) */ if (!DSK6713_DIP_get(0)) DSK6713_LED_toggle(0); } /* * load() - PRD that simulates a 20-25% dummy load on a 225MHz 6713 if * DIP switch #1 is depressed. The thread is configured in * the DSP/BIOS configuration tool under Scheduling --> PRD * PRD_load. The period is set there at 10 ticks, which each tick * corresponding to 1ms in real time. */ void load(void) { volatile Uint32 i; if (!DSK6713_DIP_get(1)) // for (i = 0; i < 30000; i++); echo(void, void); }
c6713 audio project
Started by ●December 6, 2007
Reply by ●December 12, 20072007-12-12
On Dec 6, 6:20 am, "finnyfin" <ska...@hotmail.com> wrote:> So far I've just been doing lots of reading, and using the > example code dsk_app.c below, I can have my audio signal pass through from > line input to line output. I have a couple algorithms that I've created > using Matlab for delay and distortion, I just don't know how to implement > it within this code or if that's possible> /* > * copyData() - Copy one buffer with length elements to another. > */ > void copyData(Int16 *inbuf, Int16 *outbuf, Int16 length) > { > Int16 i = 0; > > for (i = 0; i < length; i++) { > outbuf[i] = inbuf[i]; > } > > }I have used the C6416 DSK, which is very similar, and I think the function that you might want to reimplement is the copyData function. In the code you posted, it just passes the input to the output. Keith
