huhua wrote:> > "jim" <"sjedgingN0sp"@m@mwt.net> wrote in message > news:1212070084_3372@isp.n... > > > > > > huhua wrote: > >> > >> "bharat pathak" <bharat@arithos.com> wrote in message > >> news:x-ydnb2qdvrRjKPVnZ2dnUVZ_srinZ2d@giganews.com... > >> > matlab has a function called dct2 > >> > use it. > >> > > >> > bharat pathak > >> > > >> > arithos designs > >> > www.Arithos.com > >> > > >> > >> Do I need to cut the 100 x 100 image into 8x8 first? > > > > If you want to go from 100X100 to 10X10 you need to make each DCT > > transform 10X10 (instead of 8X8). Then when you have 100 transforms > > results with 100 frequency elements in each. Then you need iterate thru > > the 100 elements in each by discarding and quantizing some or all. Usually > > the scheme for doing that affects the higher frequencies the most the > > lower frequencies less and usually leaves the DC element alone). That is > > the lossy part. After that you get data reduction by standard data > > compression techniques which are usually lossless. > > In other words, if you do the quantization and/or discarding part as > > just zeroing bits you will after doing that have the same size data as the > > original (with a lot of bits zeroed). If you then run that data thru a > > typical compression scheme (e.g. zip it) you will get much greater data > > reduction than just compressing the original. Or you can create your own > > compression scheme based on your knowledge of where the data is dense and > > where it is sparse. > > To reverse the process you would uncompress (e.g. unzip) and then do the > > inverse transform. > > > > -jim > > > > Is it possible to run 2D DCT on my 100x100 image directly and select the > top-left panel (approx. 10x100) which are the dominating ones and neglect > the rest?I don't know what problem you are trying to solve so it's difficult make suggestions on how to perfect your solution. If you are just trying to develop a compression algorithm, You shouldn't need to worry about where the image has the most information. Areas that are blank won't take up much storage space once it is compressed. -jim ----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= - Total Privacy via Encryption =---
how do I do DCT on a 100x100 image?
Started by ●May 28, 2008
Reply by ●May 30, 20082008-05-30
