Hai, To test and verify the FIR filter Wat r all the test inputs as samples x(n) ....i can apply in addition to the following: Impulse,step,sine,triangular,sawtooth,rectangular pulse,gaussian white noise.. 1.whether the above test generation signals are sufficient?? 2.r still i have to add more??? 3.wat r the other corner test cases?? regards, faz
Testing FIR filter design
Started by ●June 2, 2008
Reply by ●June 2, 20082008-06-02
Dnia 02-06-2008 o 16:25:24 faz <fazulu.vlsi@gmail.com> napisa�(a):> Hai, > > To test and verify the FIR filter Wat r all the test inputs as samples > x(n) ....i can apply in addition to the following: > Impulse,step,sine,triangular,sawtooth,rectangular pulse,gaussian white > noise.. > > 1.whether the above test generation signals are sufficient?? > 2.r still i have to add more??? > 3.wat r the other corner test cases?? > > regards, > fazA good training will be verifying an apple first. Can you verify an apple? I'm serious. -- Mikolaj
>A good training will be verifying an apple first. >Can you verify an apple? >I'm serious. > >-- >MikolajHi Mikolaj, How does one verify apple?? Maybe Newton used Gravity to Verify Falling Apple.... or was is vice-versa?? And as someone rightly said: An apple a day keeps the the doctor away and if the doctor is beautiful you should keep the apple away.... Regards Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company.
On 02-06-2008 at 17:54:26 bharat pathak <bharat@arithos.com> wrote:> >> A good training will be verifying an apple first. >> Can you verify an apple? >> I'm serious. >> >> -- >> Mikolaj > > Hi Mikolaj, > > How does one verify apple?? >(...) This is a just question to *faz*. And this is also his answer. -- Mikolaj
On Jun 2, 2:04 pm, Mikolaj <sterowanie_komputer...@hahapoczta.onet.pl> wrote:> On 02-06-2008 at 17:54:26 bharat pathak <bha...@arithos.com> wrote: > > > > >> A good training will be verifying an apple first. > >> Can you verify an apple? > >> I'm serious. > > >> -- > >> Mikolaj > > > Hi Mikolaj, > > > How does one verify apple?? > > (...) > > This is a just question to *faz*. > And this is also his answer. >what is this? some kinda insider point? or inside joke? i test FIRs by using MATLAB or Octave to FFT the impulse response to make sure the frequency response is what i was aiming for. if you mean testing the real-time computation, then i dunno what the answer is. general FIRs are pretty simple and straight-forward. ("fast convolution" ain't so simple.) it's pretty easy to calculate what the largest possible output sample could be, so you can have an idea for how to scale your FIR coefs. r b-j
On 02-06-2008 at 23:35:42 robert bristow-johnson <rbj@audioimagination.com> wrote: (...) It seems you would be able to verify an apple. Let's wait till tomorrow. Let's wait for 'faz'. If he would manage to verify an apple he would be able to verify enything. He even would be able to verify such words as: to verify, optimal, best, how and why. -- Mikolaj
On 2 Jun, 23:35, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jun 2, 2:04 pm, Mikolaj <sterowanie_komputer...@hahapoczta.onet.pl> > wrote: > > > > > > > On 02-06-2008 at 17:54:26 bharat pathak <bha...@arithos.com> wrote: > > > >> A good training will be verifying an apple first. > > >> Can you verify an apple? > > >> I'm serious. > > > >> -- > > >> Mikolaj > > > > Hi Mikolaj, > > > > � �How does one verify apple?? > > > (...) > > > This is a just question to *faz*. > > And this is also his answer. > > what is this? �some kinda insider point? �or inside joke?Nah, probably frustration or something like that. This guy 'faz' has asked the same question with minor variations for a few days now, without showing evidence that he actually contemplates the responses. Rune
Reply by ●June 3, 20082008-06-03
Can u please make a comment on watever work i am doing and suggest for the same... This guy 'faz' has asked the same question with minor variations for a few days now I am helpless i am unable to get proper answer i even tried books and various resources Mikolaj wrote:> On 02-06-2008 at 23:35:42 robert bristow-johnson > <rbj@audioimagination.com> wrote: > > (...) > > It seems you would be able to verify an apple. > Let's wait till tomorrow. Let's wait for 'faz'. > If he would manage to verify an apple > he would be able to verify enything. > He even would be able to verify such words as: > to verify, optimal, best, how and why. > > -- > Mikolaj
On 03-06-2008 at 06:45:15 faz <fazulu.vlsi@gmail.com> wrote:> Can u please make a comment on watever work i am doing and suggest for > the same... >(...) Step by step. How would you verify an apple? -- Mikolaj
Step by step. How would you verify an apple? I am already confused and i dont know wat your r trying to explain here.. On Jun 3, 12:31�pm, Mikolaj <sterowanie_komputer...@hahapoczta.onet.pl> wrote:> On 03-06-2008 at 06:45:15 faz <fazulu.v...@gmail.com> wrote: > > > Can u please make a comment on watever work i am doing and suggest for > > the same... > > (...) > > Step by step. How would you verify an apple? > > -- > Mikolaj
